go_a_way1
Old 09-14-2013, 01:00 AM   #631
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Originally Posted by Cxlumpy View Post
XXR 527?
The Following 2 Users Say Thank You to ChandlerSwyng For This Useful Post:
chris x sway (10-23-2013), Pinky (09-14-2013)
Old 09-14-2013, 01:38 AM   #632
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by mrauburnhd View Post
XXR 527?
yes
Old 09-14-2013, 02:34 AM   #633
Kwise1
Kwise1's Avatar
Drives: Raven FRS
XXR 527?
What size and offset?
Kwise1 is offline   Reply With Quote
Old 09-14-2013, 03:26 PM   #634
ChandlerSwyng
Originally Posted by Wes View Post
yes
Where did you order from to get white?
Old 09-14-2013, 03:47 PM   #635
Wes
Wes's Avatar
That wasn't my post, I was just answering your question. From what I heard it was a colored that was offered by nlmotoring before.
Old 09-15-2013, 02:41 PM   #636
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Judging from his valve stems they look like he rattle canned them and didn't tape off the stems.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-16-2013, 02:24 AM   #637
Cxlumpy
Drives: Frs s13 s14
yep got really lazy and didnt want to mask them off.
Cxlumpy is offline   Reply With Quote
Old 09-16-2013, 09:07 AM   #638
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
whats the offset and tire size?
also did you do any prep work before painting the wheels? I was going to get the same wheels and then get them powder coated. But decided to change my mind because it can supposedly weaken the wheel. And cheaper to just paint it anyway.
Enraged21 is offline   Reply With Quote
Old 09-16-2013, 01:57 PM   #639
xxscaxx
Drives: 2013 SWP BRZ
Got her trained well
OC Clean Culture Meet by xxscaxx, on Flickr
My BRZ by xxscaxx, on Flickr
xxscaxx is offline   Reply With Quote
The Following 3 Users Say Thank You to xxscaxx For This Useful Post:
636 (09-16-2013), 86TruenoFRS (09-16-2013), Wes (09-21-2013)
Old 09-16-2013, 08:29 PM   #640
E46toFT86
Drives: IB '05 E46 M3 ZCP
^^^ Such a sweet ride. EAsily my Fav.
'05 Interlagos Blue
E46toFT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to E46toFT86 For This Useful Post:
Kilos6 (06-07-2014), xxscaxx (09-16-2013)
Old 09-17-2013, 01:04 AM   #641
Jarumie42172
Drives: 1992 BMW E36 325i, 2013 Scion Frs
What specs on the ccw's?
Jarumie42172 is offline   Reply With Quote
Old 09-17-2013, 01:10 AM   #642
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by BlueDubbinTDI View Post
this has probably been posted a bunch of times but what is the most aggressive wheel specs (with proper fit not stretched tires) that can fit with lowering springs and not coilovers? I think the 1.4" drop Sportlines are my next purchase.
What do you mean by aggressive? Do you mean flush or poked?
Unless you stagger the rear you are going to be very limited by the front clearance.
Old 09-17-2013, 09:02 AM   #643
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
How limited? I just mean how wide/low offset can springs allow
Old 09-17-2013, 01:13 PM   #644
xxscaxx
18x9.5 +38 up front, 5mm spacer so +33
18x10 +38 rear
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
