| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 DGM BRZ M/T
Storing Car For 9 Months
I'm traveling to Japan for a year long study abroad program and will be storing my car at my parents house for the next 9 months... I have a few questions though..
Would it be better to put it in full storage mode i.e. jack stands, d/c battery, top off fuel etc. Or Have someone start it every 4-5 weeks ( or whatever the recommended duration is ). I would much prefer if they didn't drive it since my father is horrible at driving stick and I fear for the worst. lol. Fist time ever storing a car so any advice is much appreciated.
#2 |
I'd probably go full storage mode with all of the things you mentioned, except topping the fuel off. You need to add a fuel stabilizer to prevent the gas from going bad.
If it sits too long the tires will develop flat spots Nick C.
#3 |
Drives: 2013 SWP BRZ Limited
im interested in this as well because i will be putting the car away for winter.
#4 |
Drives: WRB BRZ Sport Tech
Same as diode dynamics but I suggest driving it for a tank on on non-ethonal fuel, and fill up again with non-ethonal. Ethonal will turn into water and gunk up your fuel system if left sitting too long....at least that's what I've been told and I stored my car last winter with ethonal free gas and had no issues when bringing it out of storage. And a fresh oil change. Google classic car storage those guys have it down to a science.
| The Following User Says Thank You to Gords_zenith For This Useful Post: | Diode Dynamics (09-10-2013) |
#5 | |
Also, I currently don't have 4 jack stands. Don't have a problem buying some but, I was wondering if I could just throw on my stockies (I have aftermarket tire/wheel setup) or would that still cause wear on the springs from sitting that long?
#6 |
Drives: 2013 Raven FR-S, 1991 MR2 Turbo
been storing my MR2 for the last 12 winters...
disconnect the battery, put fuel stabilizer in the tank and park it without the handbrake engaged. If you don't want any surface rust on the brake rotors you can spay some wd40 on them but then you will need to spray brake cleaner when you get the car out of storage. That's it. Do not put the car on jackstands. Tires will not develop flat spots and the springs will not sag anymore than if you used the car everyday... |
| The Following User Says Thank You to MR2TOY For This Useful Post: | Calum (09-09-2013) |
#7 | |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
If however I could store it away in the garage for up to 12 months with the necessary prep work (trickle charger, put stockies back on (don't really care if they get flat spots), fuel stabiliser, non E85 in tank etc), that would be great. |
#8 |
Drives: 87 Supra, 13 FRS, 05 FXT
I had my Supra stored for 3 years in Govt. storage while I was in Japan. They added Seafoam to the gas tank and the engine. They drove my car around once a month as well. When I picked up the car nothing was wrong (no flat spots or hard starts), but they also didn't accept the car unless it had a 1/4 tank.
#9 |
Professional Smartass
Drives: White Out FRS
#10 | |
That Guy
Drives: 2013 asphalt FRS MT
#11 |
+1 on adding seafoam to the fuel. It prevents the 10% ethanol found in today's gasoline from becoming water and damaging your fuel lines etc...
Nick C.
#12 | |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
Here is the official long-term vehicle storage guidelines for all Scions.
SC10N FR-S #435 of 2500
| The Following User Says Thank You to azian_advanced For This Useful Post: | RallySport Direct (09-23-2013) |
#13 |
JDM JUNKY
Drives: NSX
very cool document. gotta love the internet
#14 |
Poor College Kid
Drives: ~.~
I would have my parents drive it around a little bit, just so they can get something out of it.
Good luck with your program
| Storing my car | SmsAlSuwaidi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 06-22-2013 06:38 PM |
| She was only 3 months old | Kinickie | Mid-Atlantic | 50 | 03-29-2013 07:15 PM |
| Six Months With My BRZ | brbrz | BRZ First-Gen (2012+) — General Topics | 18 | 03-20-2013 10:29 AM |
| Anyone storing their aftermarket parts until... | ScionFrsFan | Issues | Warranty | Recalls / TSB | 6 | 01-07-2013 07:01 PM |
| Storing an unused car? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-21-2012 10:51 PM |
