#43 |
Drives: 2013 Scion FRS "Raven"
Ill throw this out there is there a differance between the stock Exedy clutch and a stage one? I have not looked into it. But I know that there is a sc owner that is running the stock clutch and won't change. We (AVO at 5psi) currently are at 189 tq and the stock clutch is not having any problems.
So which clutch do you pick, we'll in the 7 years of racing i have had and ran several different clutches. No one clutch felt the same on a differant car. You will always have a weak link you just need to pick where you want it. I can and have finished a race with out a clutch, but a broken axle or drive shaft makes for a long weekend. Just a way of looking at it. In the frs I have driven an fx300 and an AVO clutch on a BRZ with an AVO kit. The AVO engagement was smooth felt close to stock and I really liked it. The fx300 was new in the car took some getting use to. Felt stiffer then stock both kits grabbed nicely. I spoke to the owner of the fx300 and he said the clutch felt better after break in. Just a bit of info hope it helps |
| The Following User Says Thank You to DAMotorsports For This Useful Post: | Sportsguy83 (09-14-2013) |
#44 | |
Drives: frs
#45 | |
Drives: AE86, 2x GT86, TE27
Exedy have a stock replacement, stage 1, stage 2, and the twin plate. That's what is available from exedy Nz anyway. I'll try and get around to putting pics up tomorrow. The clutches were almost exactly the same weight as well. There was about 40g in it. I can't remember which way, but again I took pics of that as well. |
#46 |
Drives: S1000RR
| The Following User Says Thank You to Mrc@ptuning For This Useful Post: | Sportsguy83 (09-16-2013) |
#47 |
Drives: frs
#48 |
Drives: S1000RR
| The Following 3 Users Say Thank You to Mrc@ptuning For This Useful Post: |
#49 | |
Thanks
I'm looking at it more like I want it to be easy to drive not "it's tolerable" type of solution, hopefully it exists. If I can't get a few rides I'll probably just try to organic and make sure I have $ allocated if it fails. |
#50 | |
Drives: S1000RR
Link to stage 1: http://www.ptuning.com/subdir/partno...=PTEXE-15805FW FYI, the oem clutch will start to slip around ~260whp/220ft/tq (dyno dynamics) = ~290whp (dynojet) on the dyno. MrC |
#51 | |
Drives: Blue Subarus
My car is getting some power upgrades courtesy of @FullBlown and we're a little worried it's going to blow up on the dyno with some added boost. It was at 300wtq on a dynapack prior. I switched from the CM FX300 to the exedy stage 1 based on your posts...trying to get opinions now incase it happens
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#52 | |
Drives: S1000RR
What hp/tq are you shooting for, on e85 I presume. MrC |
#53 | |
If it starts slipping I'll either have to swallow the $2500 for the twin disc or pull back the power. I'm certainly not chasing a #. I want it be somewhat reliable (will see track time) and FUN. I really appreciate your honest review of these clutches. The comments I've seen stating the FX series clutches are "just like OEM!" couldn't be farther from the truth from my experience.
| The Following User Says Thank You to pmccut For This Useful Post: | Mrc@ptuning (10-09-2013) |
#54 | |
Drives: S1000RR
400whp on 91 with low compression piston is definitely possible. 400whp on 91 or even 93 alone on stock compression is not going to happen
![]() So sounds like you're going all out with a motor build and all Sorry for getting off topic. Keep us updated on your progress with the power and clutch. MrC Quote:
#55 | |
Drives: Subaru BRZ Limited
So more insight from someone who doesnt sell them. I was looking for a new clutch and I actually reached out to @ptuning. They recommended the Exedy Stage 1. My stock was slipping pretty bad as soon as I put on my avo kit 300whp/250tq. I made it clear i needed a new clutch and was going to be around 300wtq and they said to get this clutch. "This is the clutch kit that we're using for our turbo FR-S. It's had no problems holding 400whp and 300wtq." So I purchased from them the clutch based on their recommendation. It went in fine, and is indeed, very oem feeling. Mine does have the slightest chatter, but its barely noticeable. It seemed fine and felt great. I just worked on my new tune....im at 350hp and about 320tq. So we will see how it does. I have a feeling its not going to hold up all that well, as it has already slipped once on me. To be fair, they did say 300wtq, and i am a bit over that. So my advice, go with a bit overkill and dont push right to the limit of your power. If you are planning 300whp, that will probably put you around 240-260tq. which this clutch felt great with. Very OEM. You think you will push it more, or add-on in the future, just upgrade the clutch now, and be done with it. If you are doing a supercharger, then i am sure this will work also, as that will probably be even less torque. I will keep this updated as i drive it more and see how it performs/lasts. Last edited by gdrider77; 10-10-2013 at 11:39 AM. |
| The Following User Says Thank You to gdrider77 For This Useful Post: | Mrc@ptuning (10-10-2013) |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 10:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
