#1597 |
Make love
Drives: H8R.. Not really
#1598 |
Drives: 2013 White Out FR-S
The Following 3 Users Say Thank You to FA20Club.com For This Useful Post: |
#1599 |
I Love custom Turbo kits
Drives: Limited BRZ
WTQ? Nice that is BRZEdit tuned!
The Following User Says Thank You to Sportsguy83 For This Useful Post: | evo4g63 (09-14-2013) |
#1600 |
Make love
The Following User Says Thank You to tech4pdx For This Useful Post: | Sportsguy83 (09-13-2013) |
#1601 |
You head the nail on the head. power gains werent our main goal in testing this thing; it was extending the fun factor by eliminating as much heat soak as possible. What i saw was allot more consistent numbers while testing on the dyno and no more 10+whp drop from ignition retard dropping my total power out put. TIP-IN knock even with 130 degree inlets on the maf located sensor didnt create the drastic Knock Retard we saw from our work out in the desert.
#1602 | |
Grip>Slip
#1603 |
Lets clear up a couple things.
As with all our other products we WILL cover our own warranty on items. You will not be left out to dry because we stand behind all our products. We have always offered not only our own products but done our best to improve our competitions offerings. As far as packages go we will continue to offer this to those who previously purchased their chargers from either ourselves or another vendor. This kit was developed on a USDM vehicle dont think this is a simple RHD kit we imported. We are using our own improved capacity heat exchanger, larger capacity reservoir and reinforced nylon braided lines. what this equates out to you is a system that holds more fluid for better heat dissipation as well as a fill-able tank that allows you to load ice for those glory runs on the Dyno or on the track. This might be considered gray market but its got our full support as always. |
#1604 |
Make love
Dyno sheet attached
Dyno sheet, pump/meth/70mm/EL header, full exhaust (with both cats(aftermarket) in place)/bolt-ons.
edit: this is not the final tune either. my tuner is working on another one that should smooth things out further. Last edited by tech4pdx; 09-25-2013 at 11:19 PM. |
The Following 4 Users Say Thank You to tech4pdx For This Useful Post: |
#1605 |
#1606 | |
I know @moto-mike was up to ~285 with e85; 70mm pulley and with OEM header. I think with nameless header it might push it up to ~300whp? |
The Following User Says Thank You to Sonolin For This Useful Post: | tech4pdx (09-13-2013) |
#1607 | |
Make love
edit: with my p&l (which fit like shit btw), I barely gained any peak hp, but midrange felt stronger. |
#1608 |
AutoX-10/10ths every run
Make it look like this and it'll be perfect.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | tech4pdx (09-13-2013) |
#1609 |
Make love
I miss V8 small/big blocks just for stuff like that.
![]() Last edited by tech4pdx; 09-25-2013 at 11:19 PM. |
The Following 2 Users Say Thank You to tech4pdx For This Useful Post: | Sonolin (09-13-2013), whataboutbob (09-13-2013) |
#1610 | |
Drives: Limited BRZ
![]() ![]() ![]() ![]() Love it!
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
