#351 |
i'm sorry, what?
Drives: Canada
they spring up every day, i swear
http://www.ft86club.com/forums/showthread.php?t=46660 time to make a catch-all demotivational meme or something
| The Following User Says Thank You to 7thgear For This Useful Post: | Dimman (09-13-2013) |
#352 |
Drives: EVO
Is droop travel overrated?
For a long time, I had the opinion that a tire in the air meant you were losing grip. My world was rocked though when I was told to think more about what is going on when that tire comes off the ground. The weight cantilevers across the car, thus picking up the front inside tire means it's also trying to lift weight off the rear outside tire. Obviously mass doesn't disappear so the front outside and rear inside tires have to pick up this weight difference. More weight to the front outside isn't desirable, but keeping weight on the rear inside is going to help the diff out on corner exit. Will lifting the front inside tire potentially help the corner exit under power? On the other side of this, would lifting the rear inside tire on corner entry help balance out the front by removing weight from the front outside tire? This only works if the tire physically comes off the ground though so you can turn that corners unsprung weight into sprung weight for the other 3 corners. Ideally, you'd want just enough lift to get it barely of the ground. Tons of droop travel would prevent this from ever happening. Any thoughts on this? |
#353 | |
#354 | |
- Andy |
#355 | |
Kuruma Otaku
Another problem is tire grip:load isn't linear, so you may be sacrificing more grip than is necessary.
Because titanium. |
#356 |
Lesser priced coilovers VS higher priced ones. The alignment is not an issue, found the knowledgeable shop to do that. The differences they found and what they suggest I may look for, is now the realm. 3 days of spirited drives after and a new set of tires sooner than later, I'm looking at either coilovers or build the grip with arms, camber kits, etc...
#357 |
Drives: Whiteout
Can you recommend camber arms? My rear camber is at -3.7 and -2.9 from lowering on ST coilovers. Car is a daily and need less camber so my tires won't die on me so quickly. Shop recommended GT specs, but they are so damn expensive. I'd like to be at something like -1.5 to -2.0 for the rear. Thanks in advance.
#358 | |
That Guy
Drives: 2013 asphalt FRS MT
Enjoy... |
#359 | |
Drives: FR-S Whiteout
I'm sure there is a lot more going on than what I described above, such as having the rear wheels slip with throttle to help the RWD car rotate, but that's what I think about that from my limited understanding of the physics going on.
Intent > Content
cowardice is the mother of cruelty. |
#360 | ||||
Drives: '23 BRZ
That's not what happens when you are cornering hard enough to pick up the inside front tire. At that point you will begin to add load to the outside rear and unload the inside rear at a greater rate, as you've gone from having significant roll stiffness up front to having NO roll stiffness up front. So now ALL your incremental roll stiffness is at the rear. Quote:
Ideally, you'd like to keep the load even on all four tires, as this maximizes total grip due to the nonlinear relationship between grip and load (add 75% to the load on a tire and you'll get something less than 75% more grip). Picking up a tire will cost you overall grip, but it's not like turning off a light switch. Most likely you won't even notice (I never did notice it in the 240Z, and it would always pick up the outside front exiting some corners). Quote:
Think of it like this: if you use a jack to lift up the left rear corner of the car, what happens to the load at the opposite corner? Quote:
But anyway, there's an overall grip disadvantage to lifting tires, but given the nature of some cars the optimal setup might cause this to happen, as other things than "total lateral grip" also have importance, like the ability to put all the power down on corner exit. But again, lifting a tire isn't even noticeable from the driver's seat. As load on the tire goes down from 100 lb., 50 lb., 0 lb. nothing abrupt happens when it is totally unloaded and begins to come off the ground. |
#361 |
Kuruma Otaku
Has anyone here ever got a hold of a tire's efficiency diagrams? Or know how to generate on experimentally?
Because titanium. |
#362 |
Drives: EVO
Zdan, I would disagree with your assessment on where the weight goes. Your "jack the car up" outlook is flawed in that you are pyhsically lifting weight on the back of the car. Yes, in that case, it's trying to push the opposing corner into the ground. This is dynamics though, not a jack. Gravity is still trying to pull that corner down and inertia is the only thing keeping it up there. Lifting the wheel, you move the sprung mass center of the gravity towards the corner of the car that's in the air which means it is further from the opposing corner.
Either way, it's a theory that works well for lots of chassis out there, including FWD, RWD and AWD. It's likely more biased towards the autoX guys though that take this approach. |
#363 | |
Say you are running a mix of hardened used tires you got from 'jose's tires' down the street while running massive sway bars that does not allow any independent droop while cornering. You will more likely spin out trying to lift that inside tire while throwing it around a bend. Also, if you are at a track that favors more long high speed turns and have zero amount of low speed tight turns, aside from being a very boring track, your car that's set up to lift a tire probably will not go as fast as it is capable of while using a different suspension setup. Though you are right about auto-x setups like this. It might work very well.
Intent > Content
#364 | ||||
Drives: '23 BRZ
Here's what happens, with a theoretical 50/50 rwd car weighing 3000 lb. (statically 750 lb each wheel), with 2/3 of its roll stiffness up front, 60" track, 20" c.g. height: 1g right cornering lateral load transfer = 1g*3000*20"/60" = 1000 lb (2/3 front roll stiffness => 667F/333R) Load distribution LF 750+667 = 1417, RF = 750-667 = 83 LR 750+333 = 1083, RR 750-333 = 417 front/rear = 1500/1500 (pure cornering, front/rear weight balance doesn't change) left-right = 2500/500 (purely a function of cornering g's, c.g. height, and track width) Only 83 lb. load on the inside front. Corner much harder than this and the inside front will begin to lift off, and the load does NOT go to the INside rear. At 1.125g, load transfer = 1.125*3000*20/60 = 1125 (750/375) LF = 1500, RF = 0 LR = 1125, RR = 375 front/rear = 1500/1500 left/right = 1625/375 Increase cornering beyond this, and *all* additional load from cornering g's goes to the outside rear as the inside rear continues to unload. Load on the outside front remains at 1500 lb., since we're still in pure cornering, and there's no front roll stiffness with the inside front off the ground. So incremental roll stiffness is all from the rear, the front is limited to 750 lb. of the lateral load transfer. 1.2g load transfer = 1.2*3000*20/60 = 1200 lb. (750/450) LF = 1500, RF = 0 LR = 1200, LF = 300 front/rear = 1500/1500 left/right = 2700/300 With forces balanced, increasing cornering g's with the inside front in the air adds load to the OUTSIDE rear, it *does not* magically tranfer more load to the inside rear. This is the law... Quote:
If you could lower the c.g. or add track width to keep all four on the ground, overall grip would improve. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | RJasonKlein (08-30-2015), solidONE (09-16-2013) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
