Old 09-13-2013, 12:38 PM   #379
Racecomp Engineering
See his last post...
Highways with evenly spaced large seams (like he mentioned in his post) are going to be difficult for any coilover to master.
- Andy
Old 09-13-2013, 03:19 PM   #380
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
- Andy
Sounds like a perfect marketing opportunity for Koni's FSD dampers. Because, you know, frequency select?
KKaWing is offline   Reply With Quote
Old 09-13-2013, 03:28 PM   #381
I like Koni FSDs but they are almost always REALLY soft and not intended for sporty driving. Sometimes the road is just bad!
- Andy
Old 09-13-2013, 04:25 PM   #382
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
As I did mention the bounciness has gone away with the breaking in. Plus it was the seams in the road at a constant interval that probably caused it. But the same section of highway the ride is much better now.
And a photo just because.
Lowered on RCE Tarmac 0s using SPC LCA with 245/35x18 on 18x8.5 et 38 all the way around.
Overland'n'5thGEN is offline   Reply With Quote
The Following 2 Users Say Thank You to Overland'n'5thGEN For This Useful Post:
mfbmike (09-14-2013), Racecomp Engineering (09-13-2013)
Old 09-14-2013, 05:11 AM   #383
mfbmike
Drives: 2013 FRS, 2008 R32
Nice ^
Gotta find some of those conical washers to get mine installed, sooner than later.
mfbmike is offline   Reply With Quote
Old 09-14-2013, 10:48 PM   #384
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by mfbmike View Post
Nice ^
Should have asked, I didn't include them as I thought you were re-using the stock top hats.
I can always drop them in the mail for you.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-15-2013, 04:44 AM   #385
mfbmike
I was under the impression you need the conical washers, regardless if you're re-using stock top hats or not. I am going to be re-using my stock top hats.
Hey, if you'd be willing to do that for me, I'd greatly appreciate it as it would save me the hassle.
Old 09-15-2013, 09:19 PM   #386
Overland'n'5thGEN
I used my stock top hats and I used the conical washer. That is what I was told numerous times.
The Following User Says Thank You to Overland'n'5thGEN For This Useful Post:
mfbmike (09-16-2013)
Old 09-15-2013, 09:51 PM   #387
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There are certain camber plates that do not require them but rest assured the OEM top hats do require them.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 09-16-2013, 07:32 AM   #388
FR-S Matt
Installed my SPC LCA's. Butchered my rear alignment again, lol. Steering wheel is not centered and my rear left coil magically dropped some more. I'll get an alignment sheet today. The LCA's were pretty easy to install. Aiming for low toe in the rear, 0 in front, and about -1.5 camber in front and close to -1.8 in the rear.
Old 09-16-2013, 11:10 AM   #389
This. Use them.
- andy
Sportsguy83 (09-16-2013)
Old 09-16-2013, 11:10 AM   #390
Sounds perfect for you!
- Andy
Old 09-16-2013, 07:08 PM   #391
FR-S Matt
- Andy
Here are my alignment specs. Decided not to go with the more negative camber route. I think I'll be just fine and I am happy with the outcome. It does handle extremely well now. Let me know your thoughts on it.
Old 09-16-2013, 07:13 PM   #392
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You're 18x9.5" all way around correct? How you getting away with near zero camber up front and so on...? Or am I reading your finals wrong?
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
