Old 09-11-2013, 10:29 PM   #43
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by xjohnx View Post
yeah, no.
it happened to one person, on one car. That car probably receives more beatings than the rest of the cars on this forum combined.
Got it, I just saw someone else link it in another thread, and the write-up looked pretty in-depth. From what I understood before that our cars were one good tune away from handling E85 glad to see it's an isolated case.
DoomsdayJesus is offline   Reply With Quote
Old 09-12-2013, 07:52 AM   #44
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
This looks nice. Once the data logging is there, it will definitely have me interested.
I didn't see any info on this while skimming through the thread and the website. But is there / will there be a way to bring in a wideband AFR signal to the device for data logging? I'd like to be able to tune my car while logging real-world values on the road as well as using a dyno.
And is the tablet necessary? Or could the software be made to work on a laptop using the same cable used with the tablet?
I'll be following this thread for sure.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 09-12-2013, 08:37 AM   #45
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Rombinhood@OpenFlash View Post
Good post and info! Below is some feedback from Shiv@vishnu
Yes, the dip was reduced in both duration and severity by advancing the exhaust came. Running 40deg of advance down there. Looks like the factory mapping makes some concessions in that respect. Perhaps for fuel economy or emissions.
I'll be tuning some stock header/stock exhaust cars tonight this week on the dyno. So then I'll be able to quantify the differences in mapping requirements between a stock and fully modified set-up. I agree that the first tuning step would be advancing the exhaust timing (and intake). Seems to pick up great power with no real downsides that we care about.
I'm glad you found the same thing. My first tune attempt was also met with marginal success when I tuned for AFR that was clearly too lean for this engine. It really needs to be rich in the low end/midrange. Especially with the VVT changes. Without enough fuel, the engine will sound hollow and not make max torque.
I'm looking forward to calibrating the E85 map. Thank you for sending me good starting points for injection calibration. It should save a lot of time!
Cheers,
shiv
Mad_SB wasn't the only person who asked a question.
Specifically mine was does the stage2 tune with mods show less tip-in knock than stock ?
Thanks
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-12-2013, 08:43 AM   #46
ft_sjo
Drives: GT86
I've asked a couple of questions and been ignored so I won't waste my keyboard strokes asking any more, which is a shame.
Old 09-12-2013, 03:02 PM   #47
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Stevo22 View Post
From the FAQ page:
Will the OpenFlash Tablet work on a BRZ/FR-S with an Ecutek tune?
At this time, no. The Ecutek tune locks the ECU from being read. We are working on a solution for this issue. We should have it soon.
So does this means if you have ever used Ecutek you can not use this at all right now or does it mean if you flash back to stock with Ecutek you can use this now?
Disappointed in reading this. I thought this question had been asked early on in the other thread, and it was confirmed that EcuTek users could swap over. I now understand why they haven't done any testing on forced induction cars since we are almost all running EcuTek currently.
ngabdala (09-13-2013)
Old 09-12-2013, 03:17 PM   #48
Drives: FRS
With the permission of the owner, we we able to read an EcuTek file off his car this morning. It also turns out that it compatible with our current XDF file which means it can be edited. And boy does it need to be edited according to Shiv. He went off on it as if someone insulted his mother.
So I think EcuTek owners looking for custom tuning/tune fixing should rejoice.
Rombinhood@OpenFlash is offline   Reply With Quote
The Following 3 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
DJCarbine (09-12-2013), ngabdala (09-13-2013), pmccut (09-12-2013)
Old 09-12-2013, 03:21 PM   #49
DJCarbine
Thupercharged
DJCarbine's Avatar
I just threw some cash at my screen, but it doesn't seem to be working properly.
I will try faxing it next.
On a side note, was the information pulled from the ECUTEK flashed ECU somehow "messy" compared to a stock rom? You mentioned it needed editing...
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 09-12-2013, 03:25 PM   #50
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not all EcuTek tunes are locked is my understanding. Perhaps the one you pulled was not locked. All I care about is knowing that if I purchase this, I will be able to flash a basemap to it to get my car running so that I can start the tuning process. It sounds like your current process is to get the product and use it to pull the factory ROM file and then mail it to you guys, but I don't have my factory ROM file, I have a modified EcuTek ROM.
Old 09-12-2013, 03:27 PM   #51
DJCarbine
Thupercharged
DJCarbine's Avatar
Hopefully we can just pull the ECUTEK rom, and do editing from there.
With the creator of the ECUTEK tunes permission, of course....
If so, this is exactly what I was looking for.
2013 FRS
Vortech V3 11psi
Old 09-12-2013, 03:37 PM   #52
pmccut
Drives: Blue Subarus
I don't have a factory ROM either. I talked to shiv about this last week - we should be able to get a stock ROM from FullBlown or whomever tuned the car, flash it on, then start from there with the openflash tablet. I'm down for dyno tuning my car with shiv..
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 09-12-2013, 03:43 PM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My Full Blown basemaps are not locked, and I got an OEM rom from either LJ or Visconti so that I could datalog my car when it was still stock as a comparison prior to installing my fuel pump and injectors.
Old 09-12-2013, 03:49 PM   #54
Drives: FRS
That may be exactly what you get. Unless ecutek makes a change with an upcoming software update. For those who are looking to edit your ecutek file, I recommend not doing any new Ecutek updates to your ECU. I'm not trying to cause problems with ecutek or ecutek tuners. It's just my opinion that the ecutek tune in the customer ecu belongs to them. And since it is theirs, they an do what they want with it.
DJCarbine (09-12-2013), jamesm (09-12-2013), pmccut (09-12-2013)
Old 09-12-2013, 04:03 PM   #55
Sing4LTS
Drives: 13' FR-S
Who's gonna be the first to adapt the FA20club flex fuel?
Sing4LTS is offline   Reply With Quote
Old 09-12-2013, 04:06 PM   #56
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
WOW!! Now that is some nice tuning.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
