#267 |
Kuruma Otaku
@ZDan
Wheel rate formula? Does this cover the strut not being exactly 1 (assuming that it's leverage is 1)? (leverage)^2 * ((lower pivot to instant center distance)/(tire center to instant center distance))^2 Since strut and LCA angles affect instant center location, is this sufficient?
Because titanium. |
#268 |
i'm sorry, what?
Drives: Canada
you either make the lower control arm longer or the upper control arm shorter
personally i believe that if you can, extending the lower arm is better because you are increasing your track width while adjusting your camber.
#269 | |
I will be using my BRZ for primarily road use with limited track and auto-x use. I will put approx. 10k per year on the car. I want to improve it's cornering ability without sacrificing ride comfort. If anything, I'd like to improve ride comfort over the stock dampers! The roads in New England are terrible; buncha broke-ass towns that can't budget to fix their streets. I've had fairly hardcore suspension setups before and they're nice for auto-x but terrible for street duty. I would like camber adjustment at least for the front. Tire wear is not a concern as I'm running staggered directional tires with low treadwear and plan to replace them annually or bi-annually. The car will not be driven in winter. The car will have over 300bhp in the future, if that makes any difference. Currently I'm runnng Eibach Sportline springs on stock dampers, and to say that it's over-sprung and under-damped is an understatement. I've heard good things about KW and not a whole lot about anything else. I'd be interested in knowing the differences between the KW Variant 3 and Clubsport systems, and what advantages the KW-based RCE coilovers offer. One other quick question: poly bushings or spherical bushings for a mostly-street car, and why? I'm assuming poly is better but I could be wrong? Thanks guys!!! :happy0180:
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#270 | |
i'm sorry, what?
Drives: Canada
read these two articles from start to finish. You will then udnerstand the theory behind what makes a good suspension and what makes a bad suspension. 1st this: http://farnorthracing.com/autocross_secrets23.html then this: http://farnorthracing.com/autocross_secrets18.html i cannot stress enough the importance of reading these two articles, and not just reading them but comprehending what you're reading. because if you can, then the rest of your suspension journey will be much clearer.
#271 | |
Reading? This is America gawddammit! Who reads anyways? j/k
#272 |
i'm sorry, what?
Drives: Canada
It’s a sad state of affairs that you would even make such a joke.. which is becoming increasingly mainstream.
#273 |
Drives: FR-S Whiteout
#274 | |
Kuruma Otaku
Because titanium. |
#275 | |
#276 |
Ground Control with Koni dampers and Cusco camber plates. Thought they would've been softer; in fact the guy who sold them to me said they were too soft for his setup. I didn't mean "hardcore" in the sense of quintuple-adjustable Motons if that's what you were thinking
#277 |
Drives: Vortech Supercharged FR-S
@CSG Mike
Would u plz give me some advices on my staggered setup? I build it for street and DD, track on more than twice a year, but I drive crazy on the street. I want a tail happy car that can allow me to slide at some corner at 20mph. I go staggered only for look. I order a set of 18X8.5 +43 and 18X9.5 +38 rims with 225/40 and 245/40 tires(May go 235/40 front for my next set). Do you think I can still build a tail-happy fr-s? I planned to do -2.5 camber front and -1.5 rear by top mount, LCA, and swift lowing spring. Do you think these are good camber? Maybe a stiffer sway bar will also be recommended? ALso, how about sticky UHP 225 tire on the front, and regular ALL SEASON 245 tire on the back? Thanks
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#278 |
i'm sorry, what?
Drives: Canada
if you want big tires and wheels and low grip then just buy crappy tires and overinflate them
done.
#279 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
#280 |
For the look of rims.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
