Old 09-08-2013, 05:37 AM   #15
FirestormFRS
Originally Posted by Frost View Post
Probably heat soak, your car had a lot of excessive heat and since you came to a stop or much slower speeds, your cooling capability plummeted and your car stopped itself to prevent more heat building.
Word of advice - after running laps BEFORE you lose a lot of speed (eg: rolling into the pits or safety areas) put your HVAC on HIGH HEAT and put the fans on FULL.
The car draws air across the hot engine to heat it up going into the cabin and it will help cool off your car faster. It will make you uncomfortable but you can sweat it out with the car.
Also, an oil cooler is definitely needed if heavy track use is a possibility.
Wait you're saying this car has not heater core with coolant by pass hoses supplying heated water for the heater?
FirestormFRS is offline   Reply With Quote
Old 09-08-2013, 10:41 AM   #16
(fr-s)
Drives: 2013 fr-s 6sp
Get an oil cooler, bruh.
(fr-s) is offline   Reply With Quote
Old 09-08-2013, 09:31 PM   #17
DarkSunrise
DarkSunrise's Avatar
Car was great today, even though ambient temps were hotter (about 87-89 degrees). Car was feeling so good I even let my instructor run an extra session during one of my cool-down periods. No issues. Will continue to run 100 octane as insurance.
Oil cooler and tune are on my list of mods for sure.
2022 BRZ Build
2013 FR-S Build
Old 09-10-2013, 06:55 PM   #18
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
The heater core is heated by the same coolant from the engine which is too hot at the time after racing no?
Using the HVAC to draw heat off the hot coolant (heat goes from coolant to the air which goes into cabin) and thus results in cooler (not cold but cooler) coolant back to the reservoir which can then be accessed by the engine to cool itself.
In the end, the key thing is that we are trying to find a venue to dump heat - the heater core is one way (albeit small) to dump that heat into the cabin air.
The car doesn't magically generate heat from nothing.
Frost is offline   Reply With Quote
Old 12-08-2013, 09:16 PM   #19
Itsjusdame
Itsjusdame's Avatar
Drives: Asphalt
Has any one experienced this in autocross session , my were pretty far apart , I was stalling when I left
Itsjusdame is offline   Reply With Quote
Old 12-08-2013, 10:29 PM   #20
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
nope never experienced this in autox. I didnt experience this at track either on both my cars. So idk lol
bkblitzed is offline   Reply With Quote
Old 12-08-2013, 10:51 PM   #21
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I have never experienced it after an autox event, but if it was a hot enough day I wouldn't be surprised that it overheated. These cars are iffy when it comes to staying cool it seems.
campy is offline   Reply With Quote
Old 12-08-2013, 11:10 PM   #22
Lonewolf
Lonewolf's Avatar
Drives: Moped
Especially with that wimpy little radiator...it seems that if you are going to push this car you need a bigger radiator and/or oil cooler...
Old 12-13-2013, 02:34 PM   #23
Itsjusdame
Itsjusdame's Avatar
Drives: Asphalt
Oh yea found out my was due to a loosened vacuum hose from a wild run .. don't want to scare people from autocrossing stock
(Sorry to thread jack)
The Following User Says Thank You to Itsjusdame For This Useful Post:
BRZ21 (12-13-2013)
Full Report: Road & Track tests stickier FR-S/BRZ tires poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 74 08-15-2013 02:10 AM
Not stalling? grgonium Scion FR-S / Toyota 86 GT86 General Forum 24 11-17-2012 11:26 AM
Shannonville Motorsports Park Full Track August 11, 2012 funcheung CANADA 5 08-13-2012 12:54 PM
Mine started stalling today Rob_g Scion FR-S / Toyota 86 GT86 General Forum 18 07-20-2012 11:27 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 01:20 AM
