Old 09-10-2013, 01:16 AM   #1
Aceler8
Aceler8's Avatar
Drives: Scion FRS 10 series
I know its been covered but 10 series idle problems :(
Hey guys just joined and loving the forum so far.
Ive had the 10 series for about a month in 4 days time. Odometer is barely at 860 so still in break-in period. But a persistent problem i see is that the idle hunts alot. I know that there was the problem on the original frs last year but i thought it was fixed by a ECU flash.
All of the threads i saw on the topic were from last year and none of them on frs so im at a standstill here.
Problem:
Throttle is hunting at idle. it will be around 600rpm and dips down to 4-500 rpms every few seconds. When i open the engine compartment i can hear a clicking consistent with the idle and the compressor fan(i think its the compressor fan, white fan in the very front of engine compartment), is turning on and off with the clicking. Any ideas? i know its not normal for it to be constantly going that low and the fan to be constantly going on and off every few seconds.
Thanks for any help guys
#138 of #2500
Aceler8 is offline   Reply With Quote
Old 09-10-2013, 01:22 AM   #2
fatoni
youll have better luck posting in the scion forum instead of the subaru forum
Old 09-10-2013, 01:31 AM   #3
Scoobybrz
Scoobybrz's Avatar
I'd would take it into the dealer to have them check it out. Keep us updated.
Scoobybrz is offline   Reply With Quote
Old 09-10-2013, 01:33 AM   #4
mush
mush's Avatar
he did post on the wrong forum, BUT the engine is still the same
Old 09-10-2013, 01:37 AM   #5
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
It's normal.
husker741 is offline   Reply With Quote
Old 09-10-2013, 02:37 AM   #6
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Is the a/c on?
G_Ride is offline   Reply With Quote
Old 09-10-2013, 03:13 AM   #7
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
Are you running 93 octane fuel? I know my BRZ idled a bit rough when it was on 92, smoothed out once I put in 93 for the first time.
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
Old 09-10-2013, 03:39 AM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Check if you Air Conditioning is on. The fan will kick in to blow at the A/C condenser cooling fins which are located right in front of the radiator.
The reason for the constant dip in RPM is also because the A/C compressor is belt driven by your engine;
The reason for the constant "on and off" is because when the cabin temperature is too "warm", it "kicks in" and idles again once it reaches the selected temperature.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-10-2013, 03:56 AM   #9
Luis_GT
Normal, mine drops to 500 RPM very often, and I'm at 1600+ miles.
Old 09-10-2013, 07:30 AM   #10
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
i believe that's normal while the HVAC is set to Auto with the A/C on, because mine does that too.
although one problem i do have is when the HVAC is set to Auto with the A/C switch on and is set at a temperature that is warmer than cabin temperature, the A/C compressor still cycles to turn on and off every few seconds. you'd expect that while in Auto, the A/C compressor should automatically come on when it needs to, not because the A/C light is on.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 09-10-2013, 10:08 AM   #11
bestwheelbase
Drives: 1985 P-Type
@Aceler8 welcome to the forum. Congrats on the 10.
Old 09-10-2013, 10:28 AM   #12
DantKR
Drives: Subaru BRZ LT
Because there is SO... MANY...differences... Oh wait.
DantKR is offline   Reply With Quote
The Following User Says Thank You to DantKR For This Useful Post:
CAMBAM_6 (09-10-2013)
Old 09-10-2013, 12:45 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Mine does it too, awkward but intermittent and 'normal'.
ineedyourdiddly
Old 09-10-2013, 10:37 PM   #14
Aceler8
Aceler8's Avatar
Thanks for the insight especially from a fellow 10 series owner. I just wasnt sure if it was a impending problem but i guess its normal.
#138 of #2500
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 12:08 AM
JPM Alcantara Covered Steering Wheel Alabang 86 Cosmetic Modification (Interior/Exterior/Lighting) 11 05-31-2013 01:35 PM
>>>Oil Change?<<< We have you covered. Oil --- Filters --- Drain Plugs FT-86 SpeedFactory Mechanical Maintenance and Tools 7 11-14-2012 10:56 AM
Condensation in taillights are covered under warrenty cjdriiiiift Northwest 1 10-24-2012 09:40 PM
ft-86 (covered) at the geneva autoshow! mcheddadi FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 02-28-2011 09:08 AM
