#365 |
One of the guys here did color match it with his asphalt. Looked amazing. Headlight just looked like a seamless part of the car.
Sent from a Motorola DynaTAC 8000X |
#366 | |
Drives: Audi A3 2012
pic of last year when I've removed the plastidip of my old tail lights
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
#367 | |
Just my .02 Nick C.
#368 |
Drives: '13 Raven FR-S, MT
Did this over the weekend following the DIY tutorial by @DarrenDriven
In total, took me about 8 hours. A few notes/tips: 1. Materials: VHT Epoxy Satin Black spray paint (1 can), 320 grit sanding block, dish washer soap and Grease Grizzly Degreaser 2. Sidemarkers - there's a notch along the bottom you press up on first, then stick the screwdriver in behind the other notch and pry outwards 3. ORGANIZE ALL OF THE CLIPS, maybe it's because I like to think I have A.D.D. There are a lot of clips and bolts that need to come off, EVERYONE hates it when you're missing or ending up with an extra bolt. (see 2nd attachment) 4. Oven heat - I baked my lights at 220 degrees for 14 minutes. Took some effort to pry apart the housings, but it saved the risk of melting anything 5. BE PATIENT, this takes a lot of time. Don't even think about skipping any of the steps, do it right, and do it 100% 6. The highbeam rubber seal does not simply pull off like the lowbeam rubber seal, you need to remove the 3 screws, pull off the plate, then twist the seal until it "clicks" off. Clip Organization I really like the finish of the VHT Epoxy satin black, can withstand up to 250 degrees, plus it doesn't require a primer. I'd suggest you sand off the chrome coating using 320 grit sandpaper, it'll help with the spray-on paint. Once done, I sprayed on the Grease Grizzly Degreaser, then washed again with dish washing soap; hang-dry and wipe off with a cloth. Go easy on the first few coats, I waited about 10 minutes between coats out in the sun. Once done, I followed all the steps in reverse order and applied some Permatex Black Silicon adhesive sealant around the edges as a "just in case"
#369 |
Drives: Fr-s 2013 Hot Lava
#370 | |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
http://Automotivetouchup.com Results Best pic I have of mine in asphalt ![]() Best picture of the black ![]() The white out ![]() ![]() Again, these are all perfect color match paint.. The black and the asphalt have the perfect amount of metallic Also a customer asked me to do his headlights in plastidip ![]() ![]() Then later decided to go quad projectors, because of the epoxy the halos tear the plastidip and I had to peal it all off both lights.. I never took a picture after but the lights came out like they never had anything on them. Chrome and everything came out great ![]() ![]() I've never touched the chrome with anything but fresh gloves.. I don't clean, sand, wipe, anything to the chrome housings.. I use krylon paint, usually satin black and in over a year have not had one problem.. ![]() My first retrofit, after sanding and cleaning I always had fish eyes or other problems.. Since then I've just sprayed them how they come out of the assembly and have not had a issue yet |
| The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post: | GaN-MaN (04-17-2014), retrosmiths (09-10-2013) |
#371 |
Drives: Scion FR-S Whiteout
What projectors did you use for the retrofit?
2013 Scion FR-S
#372 |
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | retrosmiths (09-11-2013) |
#373 |
So TRS now includes 6.0's instead of 5.0's in the FR-S Retroquick Kit?
2013 Scion FR-S
#374 |
No, I got those kits from headlightsquick.com, those FRS on there I did.. I got with TRS to see if they would take my template to have them all cut the same.. Then a 5.0 or 6.0 would work
#375 |
Blacked out BRZ lights I did yesterday
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | retrosmiths (09-12-2013) |
#376 |
Can you post said template?
![]() I always thought the mounting points/screw holes are the same for both 5.0 and 6.0..
2013 Scion FR-S
#377 |
They are the exact same, the problem is the 6.0 is wider and taller, so some minor trimming is required, problem is the metal is so think I have to use a dremel with a cutoff wheel. Yeah, I'll get a picture and post it.. The template is one of the brackets I haven't used, I just traced off of it for awhile, I've done so many since the group buy Vegas86 did that I don't need it any more, I know the cuts by heart now
#378 |
Cool man, let me know, I'm planning to upgrade to 6.0.
2013 Scion FR-S
| HID Headlight Upgrade KIT - 1st MOD completed | SpecPer | Exterior Parts - The Rest | 76 | 08-03-2012 10:13 AM |
| Is Anyone Else Tired of SOA Information Blackout | geb2391 | BRZ First-Gen (2012+) — General Topics | 23 | 04-21-2012 09:37 PM |
| Headlight Swap Question | nogaroblues4 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-07-2012 02:45 AM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| TRS headlight mod | RRnold | Other Vehicles & General Automotive Discussions | 0 | 12-24-2011 04:20 PM |
