Old 09-09-2013, 07:59 PM   #17333
wrxgoose
WUB WUB
Drives: 2013 Firestorm
so anyone else taking off next tuesday for GTAV?
wrxgoose is offline
The Following User Says Thank You to wrxgoose For This Useful Post:
M-17 (09-10-2013)
Old 09-09-2013, 08:35 PM   #17334
Hindi
Hindi's Avatar
Drives: Frs
I did that for iv and was very let down
-Robert
Hindi is offline
Old 09-09-2013, 10:52 PM   #17335
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Got sick laying on bed... Recieved a call from my parent telling me, one of my old friend got in auto accident & has passed away...
Fuck, I can official say, today is shitty Monday... Orz
Rest in peace my old friend, Austin.
ichitaka05 is offline
Old 09-09-2013, 10:53 PM   #17336
kanundrum
Drives: 2013 Whiteout FR-S
^^ Sorry to hear man >_<
kanundrum is offline
The Following User Says Thank You to kanundrum For This Useful Post:
ichitaka05 (09-10-2013)
Old 09-09-2013, 11:06 PM   #17337
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Starting p90x next week. Funeral the following.
Kiske is offline
The Following 2 Users Say Thank You to Kiske For This Useful Post:
Guff (09-10-2013), kanundrum (09-09-2013)
Old 09-09-2013, 11:10 PM   #17338
Dimman
Kuruma Otaku
Dimman's Avatar
1360 lbs from the factory... I'm thinking it'll be around 1500 with our setup. I'm sure we will get it corner balanced once its done...
What are doing for suspension? I read they originally used rubber springs???
With well setup suspension it will be like a FWD Exige...
Because titanium.
Dimman is offline
Old 09-09-2013, 11:14 PM   #17339
wrxgoose
WUB WUB
Ug. Upset stomach and nowhere near home. Have to make it 45 minutes. Gonna be a shitty night. hopefully not literally. Lol
Ug. Feel miserable. Atleast i can make myself my soup, lay down on the couch and relax now
wrxgoose is offline
Old 09-09-2013, 11:15 PM   #17340
kanundrum
Thinking about doing the same...
Old 09-10-2013, 12:14 AM   #17341
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I've been easing into it. Bit the bullet and bought it 2 fridays ago. I've been doing a bit of the work out (10min stretching and 10min of the work outs) on a few of the dvds (really like the kempo x one. Even still I doubt I'll be able to *fully* do the workouts come next week.
Kiske is offline
Old 09-10-2013, 12:43 AM   #17342
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Front has coilovers and the rear is the stock trumpet setup. Apparently the stock setup isn't too bad, but if we find that the rears are bad/weird, we can get a kit to convert them to coilover as well. Fully adjustable up front and we are getting new cones and trumpets for the rears...
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 09-10-2013, 12:52 AM   #17343
Dimman
Kuruma Otaku
Dimman's Avatar
It's like a foreign language...
Because titanium.
Dimman is offline
The Following User Says Thank You to Dimman For This Useful Post:
Guff (09-10-2013)
Old 09-10-2013, 01:29 AM   #17344
Guff
Guff's Avatar
Drives: BRZ LZR
It's fairly simple. Instead of a Spring, you have a Cone, which is basically a big lump of rubber. The material property of rubber is such that, when compressed, it increases in resistance. So it's perfect as a "spring".
The top piece here is the Cone.
The bottom piece is the trumpet, and that is your basic, run-of-the-mill hydraulic damper which contains fluid and a piston (I believe).
Below is a photo of the rear subrframe:
The Cone/Trumpet unit sits inside the subframe and is connected to the radius arm (control arm) and when the radius arm pivots up, it compresses the Cone/Trumpet.
Using this setup, the Mini had a very nice and fairly advanced fully independent suspension setup which made it a very fun car to drive!
by Zaku
Guff is offline
The Following User Says Thank You to Guff For This Useful Post:
Dimman (09-10-2013)
Old 09-10-2013, 03:09 AM   #17345
serialk11r
Drives: '06 AM V8V Coupe
Thought it was a handwind only you picked up. My bad. Problem seemed to be the crown twisting of its stem with the low end winders. Better and cheaper than breaking a mainspring, but still annoying. Don't know if it's from people over winding or metal fatigue over time. Or a combination.
The hand winding on my SARB's 6R15 is so light and smooth I thought it wasn't working. But that's because some of my vintage winders are geared pretty high. You hear tictictictic-CLICK, when winding, the loud click is the mechanism kicking back when released.
Also, for fun, do the math on the accuracy of your watch's 1 minute/week. Mind blowingly awesome...
Yea no, Seagull handwinds are exclusively higher end models I believe. ST19s and handwind tourbillons are the only ones I can recall, both high end in house movements.
The ST21 handwind is geared so high that when you twist it, it sounds like you're sliding sandpaper against something; the clicks are indistinguishable. I saw on watchuseek that someone complained about his ETA2824 watch breaking, and turns out he was winding it by hand every morning and the mechanism broke.
1 minute/week is good, but left alone it would probably stray much more. It's also brand new so this is the best it'll ever run.
serialk11r is offline
Old 09-10-2013, 03:34 AM   #17346
Giccin
Giccin's Avatar
Oh yes.
Things are now starting to look better! woo woo WOOO.
On a side note.. anyone else hear about the new Yaris Hybrid that's punching 420HP? lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Giccin is offline
