#57 | |
thanks for the input. glad im running stock thru the summer so i can make use of the warranty... gave me an opportunity to name my twin tho, named her "the moisture" because she gets wet when you hit the turns extra hard |
#58 |
Fyi. After market mods will not void warranty unless they are related to ac components failure. Example. Wheels will not void warranty with ac issues.
Sent from a Motorola DynaTAC 8000X |
#59 | |
Drives: Whiteout fR-S
It IS infact because my drain tubes are clogged. My driveway has a big-ass tree next to it. No wouldn't doubt some leaves and debris got into the system and is now blocking off the hole. If the water does not drain properly from your hvac system, you will get that smell again. Water can either various ways: -using your A/C which creates the condensation -washing your car and having water spill into the black plastic thing around your wipers (cowl screen) -rain. I went under the car to suck out all the water from the drain tube with a vacuum, and then blew out all what ever was clogging the drain tube with the air pressure tank.. Within about 30 seconds, the smell disappeared. The bad news is... If I want to permanantly get rid of the smell.. I'll need to clean out the debris or get a new hvac. Does anyone know if this would be covered under warranty? Or will they charge me up the butt? I would hate to have to blow out the clog each and every time. |
#60 |
#61 |
Omg the smell is horrendous now that the humidity is high from it raining. I thought I smelled it on my clothes the other day. Gotta go to the dealership anyways for a cel.v
#63 | |
#64 |
Drives: Nevermorange FRS
Rubbing Alcohol does a damn fine job with mold.
PRO86 | WTCC | STL
#65 | |
Drives: 2013 frs
change the cabin filter
#66 |
Drives: Whiteout
How easy is it to access the evaporator in this car? You would need a good view of the fins etc...I'm wondering if you could get some coil cleaner on the fins(commercial grade)http://www.johnstonesupply.com/store...ep?pID=B81-133 this is what I've used inside homes..of course it's not the best smelling and need to air things out for a while I'd use with caution in a car...just an idea
this stuff kills mold and cleans like crazy for evaps for air handlers
#67 |
Drives: 2013 FRS/01 Tacoma
Didn't read all the post as I wasn't that interested but have you tried dropping the blower motor
| The Following User Says Thank You to 20valvewynn83 For This Useful Post: | thebus (09-09-2013) |
#68 |
Drives: Scion FR-S
Gf had this issue in her Camry. Put it on max heat for about a 20 minute drive and it went away for now.
#69 |
Some guy in a white car
Drives: 2013 SWP BRZ Limited
this happened to me, but it turned out it was my stinky ass golfshoes stinking the car up
2013 Subaru BRZ Limited 6MT - Satin White Pearl![]() |
#70 |
Sprayed the ac cleaner spray I got from amazon. Yay. Will see how it goes over the next couple days. Updated my thread with details and pics
| strong odor @ higher rpm's | mRdeMs83 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 91 | 05-31-2021 08:07 PM |
| Damn odor wont go away | Yruyur | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 05-05-2015 10:41 PM |
| Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
| Anyone getting an intermittent isopropyl odor? | FRiSson | Issues | Warranty | Recalls / TSB | 10 | 04-29-2013 11:07 AM |
| how do you remove odor from fabric? | prest1ge | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 07-03-2012 08:45 AM |
