Old 08-08-2013, 03:20 PM   #85
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Thank you very much, JD. I really appreciate your help. My car is really running great - I could not be happier. It is the first AVO turbocharged customer car in the UK. I have managed to wire up my gauge ( with the exception of the RPM wire - that is my task for this weekend). Once I sort it out, I will repay your help and kindness by letting you know how I do it. I took my +12v from the fuse box, which is ideally placed right under the RHS vent, where my gauge is fitted.
Dave
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
Sportsguy83 (08-08-2013)
Old 08-09-2013, 05:31 AM   #86
JD86
Drives: 2013 Toyota 86 GT
Tuned... I think
So after a few glitches I think I have a tuned car. Think being the operative word. We're a little short on tuners here in Western Australia with ECUtek... By that I mean there is one. So I'm reserving judgment for now until I've run the results through a few litmus tests. But the numbers are fantastic.
I'll admit I was initially a little underwhelmed with the results of the AVO kit. See previous dyno posts and description of car behaviour for why. However I had a few glitches with my kit (exhaust leaks at the headers and the original light spring actuator). Early on Tuesday I had it in at my workshop and changed out the headers and the actuator... What a difference that made. Boost was instantaneous and a serious kick in the pants... Could be because the new actuator was dialled up with waaaaay too much preload. The actuator wasn't opening at all so the car was over boosting majorly. However even once I got that sorted it was a huge difference in boost.
To begin with I was running on the AVO stage 1 base map until I got the car retuned. Bearing in mind that I hadn't replaced the map sensor or anything along the lines... It ran brilliantly. Even the tuner who has since turned the car up was very impressed with it. We used it as a base run to see how the car was behaving prior to turning up the boost. With the 7psi actuator, no upgraded sensor and just wastegate pressure the AVO kit on basemap ran 180kw or 240hp at the hubs.
Following on from that I've added an ECUtek controlled boost solenoid into the car and turned the boost up a little further as well. It's now running about 10Psi of boost on 98 octane. Not sure how I feel about this yet (still on stock injectors/pump etc). I'm having someone independently dyno it and will be logging how it's behaving before pushing it hard... But it seems to be behaving alright.
The numbers everyone's been reading this post for... 200kw (268hp) at the hubs, 340Nm of Torque. This is on a different sort of dyno from my other posts so I'm not 100% on the figures yet. When I've run it on Platinum's dyno I'll throw that graph up as well.
Just to avoid confusion... Green line is torque, Blue line is power in KW, Yellow line is boost in KPa. Platinum's graphs when I get them will be in HP/Nm/Psi for the imperial system users amongst the forums!
JD86 is offline   Reply With Quote
Old 08-14-2013, 12:32 PM   #87
Pitman
Living the dream
Pitman's Avatar
Hi JD
As promised, I have found where to connect the green wire on a RHD car. If you still need to know, I will send you a PM if you like, so as not to clutter up your thread.
Dave
Old 08-21-2013, 07:00 PM   #88
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by JD86 View Post
This is what part of my office looks like at the moment, yes this is all to go on my car...
my office is jealous of your office.
great build thanks for sharing!
ftc~brz is offline   Reply With Quote
Old 08-22-2013, 03:11 AM   #89
JD86
Thanks mate! I should do an update soon, but I'm waiting on bits and pieces to arrive.
The Following User Says Thank You to JD86 For This Useful Post:
ftc~brz (08-22-2013)
Old 08-22-2013, 10:17 AM   #90
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Behind this you can see I currently have the green wire on hand for easy access as I haven't found where to wire it in. The grey wire I've spliced to the purple wire for dimming (it works for me)
Did you get your green wire hooked up yet? I made posts about where you need to tap in to get RPM.
Old 08-22-2013, 10:30 AM   #91
JD86
Hey mate,
Not yet. I think I've found where it goes though. I really need to get it hooked up though as I was running tonight and my boost gauge wasn't actually reading boost. Maybe I'm just not driving hard enough haha.
Old 08-22-2013, 10:42 AM   #92
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If it doesn't read boost then either the vacuum line isn't hooked up anymore, but then you wouldn't get vacuum either or you tapped into a vacuum source after a check valve that prevents it from seeing boost.
Old 09-03-2013, 09:11 AM   #93
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Looks good man good to see it all coming along well
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 09-09-2013, 11:36 AM   #94
JD86
Thanks mate, and thanks for the oil cooler! You're car is looking good too. I see you're getting closer to the TRD Griffon concept in looks haha.
Still have a lot of work to do on the car, and I am currently sorting through some issues (read my car has been in the workshop not working for over a week ) Hopefully it will be back up and running and better than new shortly.
GC GTS Aero Kit (09-10-2013)
Old 09-10-2013, 05:04 AM   #95
GC GTS Aero Kit
Yeah I have been sick lately so not alot of work on the car
BONKRS for life
Old 09-10-2013, 06:40 AM   #96
nix
nix's Avatar
Drives: AVO BRZ
I miss your car
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
GC GTS Aero Kit (09-11-2013)
Old 09-11-2013, 05:47 AM   #97
GC GTS Aero Kit
Originally Posted by nix View Post
I miss your car
Soon buddy soon there will be another squirt
BONKRS for life
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
How reliable is a boosted FRS/BRZ? wootwoot Forced Induction 123 07-22-2016 03:18 PM
GT86 with aero kit and high wing spoiler from Australian drive event Nafe FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 08-26-2013 11:15 AM
Australian GT86 Commercial (have you seen this) slidethis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 42 12-29-2012 10:21 PM
Australian GT86 WATER666 Scion FR-S / Toyota 86 GT86 General Forum 3 06-15-2012 04:25 AM
