Old 08-27-2013, 06:49 PM   #1
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
ps request: swp gt86 with brz front bumper
Hello
Just a simple request, I wish if I was good at photoshop but I was wondering if someone can make one for me.
I always wanted a brz cuz of its front end looks so much butter than the 86 but since its so much more expensive than a gt86 here I guess I will end up with the 86 (base brz cost $37k while nur spec 86 cost only $33k)
EJ20 is offline   Reply With Quote
Old 08-27-2013, 07:04 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
The Following 14 Users Say Thank You to ZionsWrath For This Useful Post:
alphasaur (10-14-2021), Ammonia (09-09-2013), campy (08-28-2013), CBR600RR (09-09-2013), chaoskaze (09-09-2013), charged86 (08-29-2013), DarkCard (08-27-2013), DGMBRZ (08-27-2013), Enraged21 (09-09-2013), Killerbee (08-28-2013), Shipwreck (09-09-2013), SkAsphalt (09-09-2013), Squishy86 (08-27-2013), stanm (09-09-2013)
Old 08-27-2013, 07:45 PM   #3
EJ20
EJ20's Avatar
Wow so much work involved lol
Old 08-28-2013, 08:41 AM   #4
Basket Case
Drives: 2013 Raven fr-s
I don't really see the point...just look at a brz, it's the same car.
Basket Case is offline   Reply With Quote
The Following User Says Thank You to Basket Case For This Useful Post:
BentAnat (08-28-2013)
Old 09-09-2013, 12:03 AM   #5
EJ20
EJ20's Avatar
Front end is not the same! different head lights and different bumper..... what I wanted to see how it looks in "gt86 headlighs with brz bumper"
not expert in PS but after spending almost 2 hours here what I ment (I know its crappy PS)
Old 09-09-2013, 12:58 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I thought the headlights weren't compatible.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-09-2013, 03:00 AM   #7
DIM
They are, a few members did the swap already.
DIM is offline   Reply With Quote
The Following User Says Thank You to DIM For This Useful Post:
Anthony (09-09-2013)
Old 09-09-2013, 06:00 AM   #8
SwedishLlama
SwedishLlama's Avatar
Drives: MY03 Forester - Saving for BRZ :D
As far as I'm aware putting 86 headlights into a BRZ bumper would require a slight amount of cutting. This is because the 86 headlights are slightly longer in the inner corners.
You can see this in the photos above ^ There's a bit of black rubber exposed on the inner corner of the BRZ lights because the BRZ bumper would normally cover that.
But yes, the lights are 99% compatible
SwedishLlama is offline   Reply With Quote
Old 09-09-2013, 10:58 AM   #9
frslee
Just drive it
Drives: 13' FR-S
Now this is the true ToyoBaru...
frslee is offline   Reply With Quote
Old 09-09-2013, 11:44 AM   #10
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Sounds like you just need to save your money for awhile and buy the BRZ and call it a day. All of this extra swap stuff is going to cost almost the same in parts and labor anyways (cheaper if you do the work yourself ofcourse)
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 09-09-2013, 12:56 PM   #11
Bach415
Bach415's Avatar
Drives: Whiteout FRS
I don't think cutting will be required. If I'm correct, the headlights are both the same dimensions and size. The only difference is that the exposed plastic you see on the BRZ headlights is just covering the rest of the headlight from getting scratched when it's under the bumper. I'm sure that plastic can be removed somehow.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Old 09-09-2013, 01:09 PM   #12
SnapOv3st3r
Drives: 400whp Scion tC
Yes, the headlights are the same size. The bumper has a covering over the rest of the headlight on the BRZ.
SnapOv3st3r is offline   Reply With Quote
Old 09-09-2013, 01:10 PM   #13
SnapOv3st3r
You have a link to the builds?
Old 09-09-2013, 02:42 PM   #14
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Hello
The lux motion frs has a BRZ front bumper.
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Wtb brz headlights and a white front frs front bumper post to Australia. jet86 Want-To-Buy Requests 0 08-20-2013 08:27 AM
removing front grille (fr-s) request Andyx5044 DIY (Do-It-Yourself) Guides 6 01-26-2013 01:42 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 03:30 PM
Photoshop Experts..have a request (BRZ with GT86 Front Bumper) swift996 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 12-06-2011 03:41 AM
BRZ/GT86 Photoshop request mhj555 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-30-2011 10:20 AM
