Old 09-07-2013, 07:55 PM   #1
HowL
Drives: WRB BRZ
Which is the most comfortable coilover on brz/frs??
I am looking for coil overs which are more comfortable than stock on street but holds better than stock at corners and once or twice on tract every year. Wife hate the ride saying is too bumpy on the road!! My tuning shop guy told me if I go for kw v3 it might be a little bit more comfortable on street for daily drive.
I searched over the forum, but doesn't look like any coilover will be more comfortable but holds better at corner than the stock.
Anybody can help me??
2013 brz wrb
HowL is offline   Reply With Quote
Old 09-07-2013, 11:51 PM   #2
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
kw v3, tarmac 0s or 2s, ST, or RS*R. just my .02 from reading and searching on these forums.
Enraged21 is offline   Reply With Quote
Old 09-07-2013, 11:54 PM   #3
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I'd agree w/ KW based on reviews. ST might be close, I don't think RSR will be a good choice though.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 09-08-2013, 12:00 AM   #4
Enraged21
#RememberTheBuster
Enraged21's Avatar
Why you say that? Reading their posts, they boast the Sport-i coilovers can handle the track and Black-i coilovers can be slammed all while retaining some of the ride quality of the stock suspension.
Old 09-08-2013, 12:01 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
oooohlins!
86_ZN6 is offline   Reply With Quote
Old 09-08-2013, 12:02 AM   #6
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Ive never heard anything focusing on comfort from rsr. Ive never used them. just speculation.
My BRZ
Old 09-08-2013, 12:06 AM   #7
Enraged21
#RememberTheBuster
Enraged21's Avatar
http://www.ft86club.com/forums/showp...44&postcount=3
Old 09-08-2013, 01:49 AM   #8
HowL
Drives: WRB BRZ
Any one knows about bilstein b14 euro spec, was reading their Japanese site and thet have a diagram shows its more comfy on street and little bit more sporty than the stock, but it looks the rear doesn't come with the springs. Wonder why?? Also I think the price will be high compare with the kw v3.
Old 09-08-2013, 01:55 AM   #9
HowL
Drives: WRB BRZ
Originally Posted by 86_ZN6 View Post
oooohlins!
From the thread with the Ohlins on, doesn't sound like it is comfy on the daily drive!!
Any reasons why Ohlins!! I've never had Ohlins before.
Old 09-08-2013, 07:54 AM   #10
mike the snake
I had the Ohlins R&T on my BMW 135i. They are super nice. They have a special DFV (dual flow valve) that makes them not so harsh over bumps and potholes, but I ran with spring rates that were so high that the ride was still too rough for me.
I also never utilized the adjustments or tracked that car like i had intended.
With my BRZ I decided this time around that I'd not make the same mistake and researched and found the ST coilovers had basically the softest spring rates, AND they were just about the best priced at $850.
ST coilovers are supposed to be the same as the KW V1 coilovers, made by KW, so I knew they were at least quality, and I couldn't be happier.
Ride is great, not too stiff, lowered my car 1.5" and can go lower if I want, handling is much improved.
Old 09-08-2013, 08:22 AM   #11
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
also important to consider which coilovers use the factory rubber top mounts, they make a substantial difference to NVH
86•BRZ is offline   Reply With Quote
Old 09-08-2013, 08:28 AM   #12
BRZ-y
Drives: Brz limited
I've got the bilstein euro spec b14s. Their r&d department here in SoCal tuned them for me. I can say this: AMAZING!!
body roll is completely eliminated making for wonderful flat turns and easy transitions.
Ride quality is as follows, and my wife agrees....
You can feel approximately 5% more of the bumps on the road, but they are all 10% less harsh. This is on our renowned Los Angeles freeways that make cobblestone feel like a roller rink......
Just my input.
BRZ-y is offline   Reply With Quote
Old 09-08-2013, 09:38 AM   #13
djdnz
1337
Drives: 2013 BRZ WRB S/C
I have RCE Tarmac 0's. They are valved a bit stiffer than the ST's apparently. They are not comfier than stock.
In your case my vote would be KW V3 (then you can adjust the comfort level to your liking by adjusting compression/rebound). It won't be more comfortable than stock, but you can probably get it pretty close. Make sure to use the stock mounts, don't buy camber plates.
Second bet would be the cheaper ST's which are not adjustable (if you don't live somewhere with salty winters they're fine), these are likely more harsh than stock, but less than the RCE's.
djdnz is offline   Reply With Quote
Old 09-08-2013, 01:21 PM   #14
mike the snake
"Make sure to use the stock mounts, don't buy camber plates".
Agreed. Camber plates will make the ride a bit harsher and can knock and rattle when they wear.
You can use camber bolts to adjust camber to an extent.
I had stiff springs and camber plates on my last car, and between the stiff ride, and the camber plates knocking over every bump, I got to really dislike the car.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
What coilover should i get ric342 Scion FR-S / Toyota 86 GT86 General Forum 3 06-18-2013 12:36 AM
Coilover Help Legacy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-18-2013 03:30 PM
Lowering gear, AND keeping comfortable MarkMash Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-17-2012 02:12 PM
