Old 09-07-2013, 08:41 AM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Question Have a tire pressure gauge you really like?
I have 3 tire pressure gauges - two built into pumps and a handheld cheap one. The cheap one is hard to read and I don't trust it because it's just that cheap. I was just reading the tire pressure thread and it reminded me I've been meaning to buy a reliable gauge that's easy to read specific numbers, and preferably has a 90° connector so it's easy to use on bicycles too.
So does anyone have a gauge they realized was a really good buy after having it for a while?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-07-2013, 09:14 AM   #2
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Not cheap, but I bought a Longacre Magnum several years ago, and you'll be hard-pressed to find a better analog gauge - unless it's another Longacre for twice as much money. The large face makes it easy to dial in pressures in less than 1psi increments. Since it is analog, no batteries to worry about, and it has a glow in the dark face. Plus it comes with a nice metal storage case.
http://www.racerpartswholesale.com/p...FQyk4AodPUIAeA
neurokinetik is offline   Reply With Quote
The Following 2 Users Say Thank You to neurokinetik For This Useful Post:
Anthony (09-07-2013), Doborder (09-09-2013)
Old 09-07-2013, 09:49 AM   #3
Anthony
Weight Nazi
Anthony's Avatar
Hell yeah. I'll be considering this one as my number one choice until and if someone recommends another one. I suppose it's good quality, huh? I totally don't mind dropping $80 on a badass gauge for my whole life.
Old 09-07-2013, 10:13 AM   #4
neurokinetik
Very good quality. I worked as a tire man for a Grand Am team last summer (setting pressures for all their tires - on a three car team), and they were using the same gauges. So if it's good enough for a professional race team, it's good enough for us amateurs. I've been using mine for at least five years now, after getting tired of the $20 ones that would read 3psi different, for the exact same model.
Old 09-07-2013, 10:30 AM   #5
Anthony
Weight Nazi
Anthony's Avatar
Aw man, I just realized they stop at 60 psi. I need one that goes to at least 110 for my bicycle. Preferably 120 just to have some room. That's not a deal breaker though, my bike's pressure isn't that important. This would be great for my car.
Old 09-07-2013, 11:00 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
lol I use this, says 5-150 PSI
http://www.ebay.com/itm/Eddie-Bauer-...74dc1d&vxp=mtr
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 09-07-2013, 11:07 AM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Use a different gauge for your bicycle. The error ranges are maximum at the ends of the pressure ranges. Accuracy for your car will be poor if you try to use a bicycle pressure gauge.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
RehabJeff86 (09-07-2013)
Old 09-07-2013, 11:18 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
Dang! Digital LCD screen AND compact design!? Sign me up!
The Following User Says Thank You to Anthony For This Useful Post:
ZionsWrath (09-07-2013)
Old 09-07-2013, 11:19 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
lol my mom gave it to me. Good enough for me, I'm no F1 driver ^_^
Old 09-07-2013, 11:48 AM   #10
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I use Joes Racing tire gauge with the hold valve, cost about $50 from Amazon
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following 2 Users Say Thank You to RehabJeff86 For This Useful Post:
Old 09-07-2013, 12:16 PM   #11
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Joe's racing gauge with bleed valve, $20 right now on amazon:
http://tinyurl.com/kgp33mv
I bought one of these a couple weeks ago, it works great.
I use high pressure pencil type gauges for bikes.
Ralph Spoilsport is offline   Reply With Quote
Old 09-07-2013, 05:13 PM   #12
clintavo
After reading a positive review of its accuracy, I bought this one:
[ame="http://www.amazon.com/Accutire-MS-4021B-Digital-Pressure-Gauge/dp/B00080QHMM/ref=sr_1_1?ie=UTF8&qid=1378588213&sr=8-1&keywords=tire+pressure+gauge"]Accutire MS-4021B Digital Tire Pressure Gauge : Amazon.com : Automotive[/ame]
Tested it against a buddy's $100 analog gauge, and it was spot on.
clintavo is offline   Reply With Quote
Old 09-07-2013, 05:23 PM   #13
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
this guage and a bike pump works for me.
[ame="http://www.amazon.com/Accu-Gage-Air-Check-Inflate-Tires/dp/B000Z33Y1E/ref=sr_1_19?s=automotive&ie=UTF8&qid=1378588935&sr =1-19&keywords=tire+gauge"]Accu-Gage EZ Air Check and Inflate Tires : Amazon.com : Automotive[/ame]
garfull is offline   Reply With Quote
Old 09-07-2013, 05:30 PM   #14
ayau
Drives: Some rust bucket
I use this Longacre one.
http://www.saferacer.com/longacre-ti...gauge-0-60-psi
0-60 PSI. Perfect for car tire pressures since you're usually around the middle. The gauge is less accurate at the maximum and minimum ranges.
There's a pressure release valve to relieve air without having to "reset" the gauge. This is really important if you take your car to the track because it will save you time. Almost everyone will run without the valve stem cover to save even more time.
Only thing I wish it had was a dial that could rotate 360 degrees. Not a deal breaker. It's usually reserved for more expensive gauges.
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Oil Pressure Observations - Anyone else using a gauge? Dave-ROR Engine, Exhaust, Transmission 29 01-20-2014 12:56 AM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 05:32 PM
