Old 09-07-2013, 01:27 PM   #15639
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Originally Posted by 448hpsti View Post
I am 41... Older and fartier
Will be good to see you
Youngster.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
Old 09-07-2013, 01:42 PM   #15640
Kst092
Kst092's Avatar
Drives: Satin pearl Subaru BRZ
Does anyone have a low profile car jack that I could borrow for the day?
Kst092 is offline   Reply With Quote
Old 09-07-2013, 01:45 PM   #15641
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by SpyderMS View Post
I've been waiting for a hybrid sports car like the system that I'd read about Mitsubishi putting in the Eclipse, where there would be four electric motors, one on each wheel, which a gas engine powering them. This, to me, seems like a great idea; especially if they gave you the option of turning off the front two motors, putting it in RWD mode I'm sure I read about this like a decade ago... stupid auto industry
Edit: Found it: https://en.wikipedia.org/wiki/MIEV
Problem is, that is WAY more weight than just using a high powered gasoline engine to drive the car. As I recall, the fiskar karma does this, and has a solar panel roof to power all the interior electronics. It still has to have a bunch of batteries to store power for the electric motors, thus more weight. A KERS system would be better, but expensive to run in a street car, currently F1 and LMP cars use it.
Sent from...somewhere?
Old 09-07-2013, 02:25 PM   #15642
SpyderMS
SpyderMS's Avatar
Drives: 2014 BRZ - Crystal Black Silica
If you were using a small gasoline engine running at a constant RPM in order to generate electricity with the most efficiency though, then you may not even need huge batteries. Remember I'm talking about a hybrid system, rather than full-electric. Mitsubishi's system can be used in either. You'd also lose the weight from the transmission, driveshaft, and differential (although this would probably merely be offset by the weight of four electric motors... I'm not certain).
Edit: I looked up info on the Fisker Karma, and although it is also a hybrid, it uses the power from the batteries first, in full electric mode, and only then does it switch to the gas engine, which can power the car without the need for the batteries to be charged. The Chevy Volt works in the same way. I think they do this mostly to claim the benefits of a fully electric vehicle (never having to use gas for short distances, maximizing the money you save). The Fisker Karma is a bit confusing though... nobody buys a car like that because they're concerned about fuel economy... I suppose really rich environmentalists would be interested. For a pure sports car though, where you would want as little weight as possible, I think you would be just fine with a standard battery.
I would think KERS should be in 'every' Hybrid/electric car...
SpyderMS is offline   Reply With Quote
Old 09-07-2013, 02:52 PM   #15643
RedLeader
RedLeader's Avatar
I think a formula 1 style KERS system would be a blast in our cars. It's not technically a hybrid system, more of a regenerative electrically powered nitrous system. The best way I've found to describe it to people is an 80hp, (160hp on the newer versions) nitrous shot that recharges by kinetic regeneration (movement of the drivetrain, flywheel, axle, or wheels).
It'd add a lot of unsprung weight to our cars though, given the system weighs about 53lbs, not including batteries or capacitors.
The Following User Says Thank You to RedLeader For This Useful Post:
SpyderMS (09-07-2013)
Old 09-07-2013, 03:12 PM   #15644
Boblhead
Drives: Asphalt FR-S
That reminds me i recorded some f1 practice sessions which i need to watch
sent from
Boblhead is offline   Reply With Quote
Old 09-07-2013, 03:17 PM   #15645
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
@AzFranz had to remind me this morning that Monza is this weekend...I've been too busy.
Sent from my GS4.
The Following User Says Thank You to Ninjin For This Useful Post:
AzFranz (09-08-2013)
Old 09-07-2013, 03:24 PM   #15646
Cross
It's the Mad Cow
Cross's Avatar
Alright Switch Backs and the Reverse Light LED's are in, now I just need to get a set for the rear turn signals and the DRL's and I am done.
The Lowering Springs are on now, looks good for now but lets see what happens when I get rims for the car.
Now on to the rest of the weekends projects... after lunch.
The Following User Says Thank You to Cross For This Useful Post:
brenesk91 (09-07-2013)
Old 09-07-2013, 03:51 PM   #15647
Flight86
Flight86's Avatar
Drives: Scion Frs
Never done it b4 but guys is there anywhere were I can go learn how to drift my frs . I'm paid 25k for a car that I loved watching on YouTube cuz ppl would drift it even tho I know I don't know how to drift . But I got it with learning in mind now I wanna out this thing to good use cuz driving this as a dd is getting boring
Flight86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Flight86 For This Useful Post:
chrisbfrs (09-07-2013), SMOKETREES (09-07-2013)
Old 09-07-2013, 04:12 PM   #15648
Yruyur
Yruyur's Avatar
We can meet in a vacant lot somewhere and ill show you the basics.
Sent from a Motorola DynaTAC 8000X
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
chrisbfrs (09-07-2013), SpyderMS (09-07-2013)
Old 09-07-2013, 04:17 PM   #15649
redsuns03
I want in on this
Sent from my SGH-T999 using Tapatalk 4
The Following User Says Thank You to redsuns03 For This Useful Post:
Old 09-07-2013, 04:25 PM   #15650
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
My tattoo shop parking lot after subway closes we can drift like crazy
Moderninktattoos.com
chrisbfrs is offline   Reply With Quote
The Following 2 Users Say Thank You to chrisbfrs For This Useful Post:
redsuns03 (09-07-2013), Yruyur (09-07-2013)
Old 09-07-2013, 04:26 PM   #15651
Yruyur
Yruyur's Avatar
Lets set a time then. Tomorrow around 6?
Old 09-07-2013, 04:28 PM   #15652
chrisbfrs
chrisbfrs's Avatar
We'd have to either early before subway opens or after they close. They might not be too happy.
I used to be cool with the old management but they have new manager and they are sticklers
