Old 09-06-2013, 07:43 PM   #1443
Kodename47
Kodename47's Avatar
Drives: UK GT86
We don't get E85 here in the UK. My car lives on 99RON though so equivalent to decent 93 figures, hence asking about normal pump figures
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-06-2013, 07:45 PM   #1444
DriftEm
DriftEm's Avatar
Originally Posted by sw20kosh View Post
Yes, moto-mike just talked to deatschwerks and they are finding that just using 2 O-rings (no spacer) is not enough.
This is my case compounded by one of the 2 O-rings being busted...
See here for proper Deatscherks Pump install:
http://www.ft86club.com/forums/showt...ight=fuel+pump
So not having the stock spacer installed causes what? I'm not having any issues with just 2 o-rings and I'm running e85.
DriftEm is offline   Reply With Quote
Old 09-06-2013, 07:47 PM   #1445
phloozy
phloozy's Avatar
Drives: Scion FR-S
Ah ok, well I am fairly certain pump will yield 225, if it doesnt it 100% will on the new 70mm pulley
phloozy is offline   Reply With Quote
Old 09-06-2013, 07:51 PM   #1446
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks guys. @phloozy aren't you running E85? Any pump fuel figures or links to graphs? Anyone else?
I'd like to aim for 220/225hp and 180lb.ft at the wheels. Just trying to work out if cat removal is going to be legal here to help get those figures.
I put down 225/192 on my very first E85 dyno, and that tune was quite a bit off target. 225 will not be a problem on E85. I'll have some better E85 number tomorrow.
Old 09-06-2013, 08:01 PM   #1447
sw20kosh
Drives: 2013 Black FR-S
I would highly recommend reading the link I provided. You may not have a bad seal now but you could later. My car was fine for months and within the past month has been having wierd starting issues and fuel starvation issues while driving.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
DriftEm (09-06-2013), xjohnx (09-06-2013)
Old 09-06-2013, 08:36 PM   #1448
xjohnx
Grip>Slip
xjohnx's Avatar
what he said. either use the stock spacer w/ 2 o-rings, or put on 2 extra o-rings (4 total, NAPA part 2-12093 for 2 of them).
Old 09-06-2013, 10:03 PM   #1449
phloozy
phloozy's Avatar
Drives: Scion FR-S
Sorry for jumping in late, is this only for people with the aftermarket fuel pump?
Old 09-06-2013, 10:06 PM   #1450
xjohnx
Grip>Slip
xjohnx's Avatar
yeah, but even more specifically only for people with the dw 65c. some other pumps use different combinations
phloozy (09-06-2013)
Old 09-07-2013, 08:35 PM   #1451
diss7
Drives: AE86, 2x GT86, TE27
I've been keeping quiet on my situation, but now I thought I should say something about the hub issue, as I received a second sc the other day, and it had the same problem. So either I'm the only one that has noticed the issue, or I'm the only one saying anything, or its just a coincidence that the two units I now I have are the only ones with poorly machined hubs. See my build thread for more info.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
jamesm (09-07-2013), OmarGC (09-07-2013)
Old 09-07-2013, 09:54 PM   #1452
xjohnx
Grip>Slip
xjohnx's Avatar
How did the serial numbers compare?
Old 09-07-2013, 10:24 PM   #1453
FRSRAVEN
Anyone else experience issues with the hub on their supercharger? Anyone know how much runout would be ok in this application?
FRSRAVEN is offline   Reply With Quote
Old 09-07-2013, 11:37 PM   #1454
sw20kosh
what would be a symptom of this issue?
Old 09-08-2013, 12:18 AM   #1455
FRSRAVEN
Possibly increased belt wear or the belt coming off the pulley. Perhaps some increased bearing wear on the hub assembly itself due to balance issues. But the question becomes.
Is the .4mm of runout reported by diss7 enough to cause these issues? I don't know.
Old 09-08-2013, 12:44 AM   #1456
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
No issues on mine.
tech4pdx is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
