Old 09-06-2013, 01:20 PM   #1121
ftc~brz
Done
Drives: WRB BRZ
I'm done. a front lip in the future is a maybe, but aside form that, E85 tune tomorrow and its all done.
front lip = pia to get car into shop & on a lift…..(SCRAPPPPE) but looks sooooooooo good
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Sportsguy83 (09-06-2013)
Old 09-06-2013, 03:15 PM   #1122
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I may or may not have seen some numbers on my phone at lunch. They are still working on it. Make sure you get the Dynojet files before you leave so you can make some good dyno plots instead of cell phone camera pics of a blurry computer screen.
why are ur his friend but not me
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
ftc~brz (09-06-2013), Sportsguy83 (09-06-2013)
Old 09-06-2013, 03:34 PM   #1123
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I didnt bring a usb drive
Tony will grab them for me....
Final numbers where kind of weird....
We did a couple of runs in the 340 WHP 260 WTQ range, but then started messing with the EBCS and going back and forth with the Manual. I had initially not set the EBCS correctly and it was not opening WG. Hit 3 runs of 23, 21, 21 psi....
WTQ numbers where awesome during those runs LOLOLOL.
But at this time we were running out of MAF (and obviously I didn't want to be in the 20 psi range)...
We then went back and forth between the manual and the EBCS, but now the torque curve looks different. I am hitting a peak WTQ awesome, but then dies down at the end. WG spring pressure is also only 8 psi, so I will look into getting a bigger one. Still debating if I will keep the EBCS or jsut go back to Manual and call it a day.
Final numbers were: 325 WHP, 295 WTQ with the EBCS.
I need a bigger spring, the boost goes all over the place from a very small peak of 18 down to 13.
You are a friend too, just was sending out a really bad pic. Hopefully Tony grab the charts and I can upload them here.
Old 09-06-2013, 03:45 PM   #1124
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Wow. That's the 1st time I've seen e85 give amazing tq and lik no hp. But love how balanced the numbers r
lbroskee is offline   Reply With Quote
Old 09-06-2013, 03:58 PM   #1125
Sportsguy83
Drives: Limited BRZ
Yea, the top HP will go up as the EBCS is dialed in, but my GOD the car feels so stupid right now... WOW
I'd also honestly say the numbers will be closer to the 340/260 pass. Fuel was not changed after that, it was just messing with the EBCS and obviously that was giving different psi, peak psi, psi was dying down at the end, etc....
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
ftc~brz (09-06-2013), lbroskee (09-06-2013)
Old 09-06-2013, 04:07 PM   #1126
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
"I'm done"
Famous last words...
But seriously, great build and I'm excited to see those dyno plots soon!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
Old 09-06-2013, 04:11 PM   #1127
ft_sjo
Drives: GT86
8 psi spring should be fine for the target boost you're looking for.. sounds as if the EBC needs some work, unless the wastegate is fundamentally the wrong size (which I doubt). Good numbers, I bet it's fun!
The Following User Says Thank You to ft_sjo For This Useful Post:
Old 09-06-2013, 04:11 PM   #1128
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Sportsguy's FI Blue Dream
Awesome numbers man
I heard the ebcs is not that good with ecutek and thats why my tuner told me not to get one
Dyno day for me is Thursday
I bet @King Tut will be happy to see some numbers on e85
Sent from my iPhone using Tapatalk - now Free
The Following User Says Thank You to whitefrs For This Useful Post:
Old 09-06-2013, 04:32 PM   #1129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Cause he sent me his phone number when I went down and stayed and his house, haha. Send me yours, and I will sext you as well.
Old 09-06-2013, 04:36 PM   #1130
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Awesome numbers man
I have told him I am not a fan of EBCS many times. I think he will see the light eventually, but I forgot, he is "done". With the 5 psi boost drop as RPM increases I can completely understand why his horsepower numbers don't match with his torque numbers. The torque curve is going to start falling as soon as the PSI does and horsepower is just a calculation of torque and RPM.
Old 09-06-2013, 04:38 PM   #1131
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Dont u own an ebcs?
Old 09-06-2013, 04:41 PM   #1132
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Dont u own an ebcs?
I own an EBC (GFB G-Force II) which does utilize a solenoid, but it is not EcuTek controlled. It is controlled by my fingers inside the car.
Old 09-06-2013, 05:23 PM   #1133
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
ohhh
Old 09-08-2013, 10:14 AM   #1134
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
You have know idea how beneficial chronicles like yours are to someone just getting to know this platform. I have zero knowledge base or experience with small displacement performance enhancements and you have definately assisted with the learning curve by sharing !
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 2 Users Say Thank You to Deep Six For This Useful Post:
@Art_Mighty (08-31-2014), Sportsguy83 (09-08-2013)
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
