Old 09-06-2013, 11:14 AM   #71
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by charged86 View Post
are you still having rattling problems? mine is horrendous im thinking of removing header and selling it
I thought you were having a custom overpipe made? Contact P&L.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-06-2013, 01:20 PM   #72
charged86
charged86's Avatar
I did now the overpipe hits the head I can line it up fine with the front end off the ground then it seems the outlet on the header is pulled rearward and then rest over pipe on head. I also re adjusted to make sure I had clearance everywhere, then made metal braces that bolted to outlet of over pipe to a trans bolt. still moves and makes contact. I have been under the car 3 times and today will make 4. something to take note is the subframe was not made in mind of having a larger exhaust run around it. Very frustrating. if I cant get adjusted correctly today which I doubt I can my fabricator will re visit what he has done to make adjustments
I would like to note to anyone a motiv overpipe to P&L header is completely out of question.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-06-2013, 01:58 PM   #73
Hawaiian
That guy
Hawaiian's Avatar
Hmm, I could have sworn someone was running the Motiv overpipe and the P&L header with no problems. If you lived closer I would have you swing by so I could take a look at it.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 09-06-2013, 02:06 PM   #74
charged86
charged86's Avatar
Well I uses the overpipe for the basis of the new overpipe build as soon as I installed it the first time, the stock motiv was pinned very hard ibln every direction
Old 09-06-2013, 02:08 PM   #75
Hawaiian
That guy
Hawaiian's Avatar
Is the Motiv a wider diameter?
Ultramarine mt FR-S
P&L stage 1 turbo
Old 09-06-2013, 03:17 PM   #76
charged86
charged86's Avatar
nope its 2.5inch so is my new one.
Old 10-18-2013, 05:34 PM   #77
madpcsupreme
Drives: 95 accord
So, is there a known brand of overpipe that will fit the P&L header w/o rattle besides the stock one?
I have having the same ratlle problem w/ motiv OP in low rpm
madpcsupreme is offline   Reply With Quote
Old 10-18-2013, 06:40 PM   #78
grostoine
Drives: Subaru BRZ
A big thanks for these review!!! I might think to buy those perrin motormount. With some forced induction, the motor must dance under the hood with stock mount!
The problem is the downpipe of the headers, you should send it back to p&l so they can correct it! I can clearly see on one of the F1point4 photo's that the flange of the header is too much on the passenger side and maybe to low.
Mine goes out today. Hope to get a good one back.
grostoine is offline   Reply With Quote
Old 10-18-2013, 07:45 PM   #79
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Nice write up, and great pics.
Touge Factory is offline   Reply With Quote
Old 04-24-2021, 01:16 PM   #80
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Does anyone know the bolt specs for the Perrin engine mount?
B T is offline   Reply With Quote
Old 04-24-2021, 05:28 PM   #81
B T
7/16 - 14 thread and 1" long of anyone needs to know.
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 06:38 PM
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated P&L Motorsports Engine, Exhaust, Bolt-Ons 244 09-24-2015 05:44 PM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 06:36 PM
SOLD: P&L Motorsports Equal Length 4-1 Header yamsta Engine, Exhaust, Bolt-Ons 18 08-07-2013 11:24 AM
Borla Releases Equal Length Header, Catless Huehuecoyotl Engine, Exhaust, Transmission 1 04-05-2013 10:44 PM
