Old 09-06-2013, 02:22 AM   #15
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
does the avo catch can work with the innovate supercharger? which is ideal, dual or single?
1010110 is offline   Reply With Quote
Old 09-06-2013, 03:00 AM   #16
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Originally Posted by BenArmstrong View Post
More info? link?
http://www.ft86club.com/forums/showthread.php?t=19462
reyruiz191 is offline   Reply With Quote
Old 09-06-2013, 10:42 AM   #17
utekineir
blowhard
Drives: frs, project forester
Not really seeing the point of paying $$$$ on a subaru platform for a vta catch can. The interface in a nutshell consists of a couple hose barbs and zip ties.
This isn't like other platforms where the kits may include a nice adaptor plate that has to be designed and machined.
You're paying $300 for a couple hoses, fittings, bracket, empty tank with just a mesh baffle at the opening and a couple dollar filter that sits on top.
After having owned a few catch cans on other platforms including vta at first glance i'd be concerned about a couple things on the d3 kit being mentioned.
1) Draining, draining doesn't look to be clean or dead nuts simple. For $300 on a can, bracket and hoses i'd expect dead nuts simple draining.
My solution in the past to draining a vta can was to remove the filter, enlarge one of the mesh holes at the top, and stick a syringe and hose down into the can. I know vta doesn't fill fast, it does eventually fill though especially in colder climates.
2) No way of looking at level. Not at all necessary with how slow vta fills (outside of winter), and a diy dipstick is easy. But still, at $300 for a bracket, can and hoses, it would be nice.
3) vta does make the bay dirty over time, and sometimes you will breathe the fumes, not while driving, but while idling or going slow it does happen. Put a lot of miles on a vta can, especially in the summer cruising around or sitting in traffic with the windows down, you'll see.
For a non race application, not really sure i'd use vta again, effective, sure. But it has its compromises for dd use.
That said, despite being expensive the radium can looks nice, overkill as fuck, but nice. But is its "filter media" steel wool?
I'd like to see one of these rigged up to work. Down the road when the fi dust settles if i make the jump i'll run one.
http://www.idparts.com/catalog/produ...oducts_id=2334
Here is an old diy from a tdi application. Not an exact carryover at all and the guy got a bit carried away on the hoses. But it gives an idea of what can be rigged with a can and hardware store fittings/hoses.
http://forums.tdiclub.com/showthread.php?p=846480
utekineir is offline   Reply With Quote
Old 09-19-2013, 09:15 AM   #18
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Originally Posted by AVOturboworld View Post
We do ours in black, with black hoses, and is actually baffled.
So is it a sealed unit? Got a drain or recirculate ? Link? Tell us more.$? I'm not after radium cost or bling, seeking function first and proven under fi on our cars, painted black box is exactly what I seek.
448hpsti is offline   Reply With Quote
Old 09-19-2013, 09:18 AM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Look at the breather tank kits
http://www.avoturboworld.com/avoshop...p33k94kgihal61
The Following User Says Thank You to Sportsguy83 For This Useful Post:
448hpsti (09-19-2013)
Old 09-19-2013, 09:51 AM   #20
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Has anyone used the avo sandwich in conjunction with a Perrin oil cool or mocal sandwich? I would love to see a cut away of the interior baffles, Paul.
Old 09-19-2013, 03:44 PM   #21
xjohnx
Grip>Slip
xjohnx's Avatar
I talked to Radium today. The BRZ kit is next on their list.
charged86 (09-19-2013)
Old 09-19-2013, 05:30 PM   #22
charged86
charged86's Avatar
im about to run Phastek catch can off the pcv valve to manifold and I run the one under the ac compressor to atmosphere
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
need an oil catch can for vortech\innovate superchargers? Benn0r Forced Induction 8 01-17-2014 01:50 AM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 04:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
