Old 09-05-2013, 09:17 PM   #15555
AzFranz
Az to Nm to Az
AzFranz's Avatar
@40flash does the window auto up-down feature that runs off the door switch cause any problems? i.e. is the door is harder to close because the window is up because the car thinks the door is already closed?
Sent from my GS4.
See...not many of us would of thought of that. Because if you open the door and push the button the window goes up the rest of the way. So if the switch is in the "quiet the buzzer position" and someone forgets...splash goes the glass. Maybe.
It's a sleeper...I launch, it feels like it's asleep.
AzFranz is offline   Reply With Quote
Old 09-05-2013, 10:46 PM   #15556
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
Sent from my GS4.
No, The window does go back up as soon as you close the switch but it doesn't seem to be an issue. Can't really tell any difference in the way it closes.
I don't know what percentage of cars have windows that go up and down every time the door is opened but I do know that cars survived for a lot of years without this feature. The rubber seals are not a bank vault. They don't seal well enough to break the glass when you shut the door.
40flash is offline   Reply With Quote
The Following User Says Thank You to 40flash For This Useful Post:
Ninjin (09-05-2013)
Old 09-05-2013, 10:47 PM   #15557
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Originally Posted by AzFranz View Post
I distinctly remember your shit not being craftsmanned so well on dyno day...yes craftsmanned, I said it, it's now a word.
It actually needs to enter into somewhat common usage to become a word.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
Old 09-05-2013, 10:50 PM   #15558
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
We'll call that user error. I took the car back to them and they confirmed the header had been craftsmanned correctly. It needs a particular install procedure though.
Sent from my GS4.
Old 09-05-2013, 10:57 PM   #15559
40flash
John 1:12
40flash's Avatar
Originally Posted by JesseE View Post
Might be useful to do this for couple days after tint is done... but I wouldn't keep it like that personally
I'm confused by your comment. Are you thinking this permanently disables the buzzer or the automatic window system? If that is what you're thinking it doesn't. The switch is just for those times when you want the door open for whatever reason and don't want to listen to the door buzzer. Until you manually hit the switch everything operates just as it did from the factory. The rubber bumper you add to the door even shuts off the switch when you close the door so it's back to normal the next time you open the door.
Old 09-05-2013, 11:00 PM   #15560
AzFranz
Az to Nm to Az
AzFranz's Avatar
We'll call that user error. I took the car back to them and they confirmed they header had been craftsmanned correctly. It needs a particular install procedure though.
Sent from my GS4.
Hmmm...I'm wonder how particular their items are that it wasn't sealing up. We talking re-torque after an initial heat cycle? I mean most bolts have a torque pattern to ensure proper seating/sealing, but were talking 3 bolts? right? Per side....
Old 09-05-2013, 11:02 PM   #15561
40flash
John 1:12
40flash's Avatar
[QUOTE=redsuns03;1191421]This is a mod that would be great before HIN for me. Lol.[/QUOTE
If you don't have time to do the mod before HIN you could pull open the panel behind the door switch and just unplug the wire off of the switch. The switch is normally closed. It opens to shut off the light when you close the door. Unplugging the wire would keep it from chimming during the show with your door open. Would take you two minutes at the show.
redsuns03 (09-05-2013)
Old 09-05-2013, 11:02 PM   #15562
AzFranz
Az to Nm to Az
AzFranz's Avatar
Well I used it and then Ninjin used it...it's becoming common. I will then write to Merriam-Webster and ask for an inclusion!
Old 09-05-2013, 11:03 PM   #15563
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Initial installation should be torqued in a particular pattern, then re-torqued after the header gets nice and hot.
Apparently its a Subaru thing.
Sent from my GS4.
The Following User Says Thank You to Ninjin For This Useful Post:
Old 09-05-2013, 11:06 PM   #15564
AzFranz
Az to Nm to Az
AzFranz's Avatar
Sent from my GS4.
Figures...It would've been fine if it were a "Toyota" thing!
Old 09-05-2013, 11:16 PM   #15565
40flash
John 1:12
40flash's Avatar
Now you've done it. You've corrupted Ninjin's otherwise perfect diction! lol
Old 09-05-2013, 11:22 PM   #15566
Bigedb
Drives: 2013 frs 6spd asphalt
So I spotted two frs's and one brz at chandler fashion mall parking lot today! Awesomeness! I ordered my full exhaust and pulley and intake from vivid! Should be in tomorrow and install hopefully Monday! Ordered all their own parts and have black exhaust tips. Think that will look good with a color matched rocket bunny kit with the wing and wheels? And why can't we upload pics from the app anymore?!?
Bigedb is offline   Reply With Quote
The Following 2 Users Say Thank You to Bigedb For This Useful Post:
Ninjin (09-05-2013), redsuns03 (09-05-2013)
Old 09-05-2013, 11:33 PM   #15567
SpyderMS
SpyderMS's Avatar
Drives: 2014 BRZ - Crystal Black Silica
I've been using the imgur app to upload pics, then posting them in Tapatalk using their link. Kind of a shitty workaround but it gets rid of dual-pics when attached, and the imgur pics are likely higher quality.
SpyderMS is offline   Reply With Quote
The Following User Says Thank You to SpyderMS For This Useful Post:
Ninjin (09-05-2013)
Old 09-05-2013, 11:55 PM   #15568
jeffsides
AZ FRS 86
jeffsides's Avatar
Sunday Sept 15th, show up as early as 8:00am
Text me for address and info 480-414-1334
See you all there!!!
Just a count for tech day on who is planning on attending and projects to complete.
Projects
1. Bonks86 - headlight painting
2. Redsuns03 - pulleys, snorkel
3. Yruyur - caliper painting
4. dsrttigr - vinyl
5.
Guests/hangout
1. Jstunna
2. 448hpsti
3. SpyderMS
4. KIMMMIdrvr
5. Rpg1031
6. Nelsmar
7. Chrisbfrs
8. FR-Shadow
9. Fst86frs
10.ninjin
11.
12.
13.
14.
15.
Sent from ARIZONA86 HQ
@AZFRS86
