Old 09-04-2013, 05:16 PM   #15
swift996
swift996's Avatar
Could be oil (perceiving as white)..do you have any oil pressure gauge or reading?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 09-04-2013, 09:12 PM   #16
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
I don't know how relevant this is, but what you're describing sounds exactly like what my Mazdaspeed3 did when some seal was blown and a bit of oil was burning in the turbine. It was a somewhat common issue and my turbo was replaced under warranty.
I know they say oil makes blue smoke, but it just looked like a big white cloud to me. It also wasn't constant. If I recall correctly, when my A/C compressor would kick in, the smoke would increase. Basically, under a slightly higher load, the smoke would come on. And it wasn't blasting out clouds of it while I was driving or anything.
Wild Weasel is offline   Reply With Quote
Old 09-05-2013, 04:43 AM   #17
1slo_frs
Drives: 2013 FRS 6mt
Had white smoke on my wrx a few months ago. Turns out the turbo had shaft play. Give that a look.
Sent from my HTCONE using Tapatalk 2
08 civic si coupe (sold) 12 Wrx Hatchback limited (sold)
03 Wrx sedan (sold) 02 is300 (sold) 13 Frs (Current) 08 e90 328i (current)
1slo_frs is offline   Reply With Quote
Old 09-05-2013, 04:51 AM   #18
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
Turbo? Subaru engine? White smoke? Ahhh i'm having cracked ringlands flashbacks
the.big.kahoona is offline   Reply With Quote
Old 09-05-2013, 05:42 AM   #19
cf6mech
Drives: FRS Silver LS1 swapped.
Do you have the forward cat installed?,....when my forward cat came apart I was blowing white smoke.
cf6mech is offline   Reply With Quote
Old 09-05-2013, 10:05 AM   #20
Synack
Boosted
Synack's Avatar
Drives: Sideways
Oh my god you described it perfectly. I'm gonna yank it off and send it to Precision after what you just described.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-05-2013, 10:22 AM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you check with Precision to see if you should be running a restrictor? It seems most modern turbos need a restrictor, but I would have thought that if you needed one D3PE would have put one in. I would have to say that your turbo is the most likely source.
Old 09-05-2013, 10:57 AM   #22
Synack
Boosted
Synack's Avatar
Drives: Sideways
I was just told that restrictors void the warranty of the turbo. Good thing it never had one.
Old 09-05-2013, 11:00 AM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am researching that now. What model and type Precision turbo do you have?
Old 09-05-2013, 12:57 PM   #24
Synack
Boosted
Synack's Avatar
Drives: Sideways
It's a custom Precision turbo, the model doesn't officially exist as a production turbo. Its unofficially a 5534e model though.
Old 09-05-2013, 01:00 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That doesn't help. What style center cartridge is it?
Old 09-05-2013, 01:53 PM   #26
canu_50
canu_50's Avatar
Drives: Scion fr-s
5534 are usually journal bearing, which don't need restrictor..
He probably only had the billet wheel upgrade or something like that.
Usually a restrictor is needed on a Ball bearing turbo I.E GT/GTX garrett series, B&W EFR series, All Precision BB turbo!
But they usually comes with it at the same time!
canu_50 is offline   Reply With Quote
Old 09-05-2013, 02:41 PM   #27
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yes and I'll probably upgrade to BB when I send it back in for warranty.
Old 09-05-2013, 05:35 PM   #28
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
sounds like a blown headgasket
FastLane1000 is offline   Reply With Quote
Cloud of white smoke on startup wawro569 Issues | Warranty | Recalls / TSB 25 01-16-2015 12:55 PM
Ceramic White Exhaust Tips hybrid4g Cosmetic Modification (Interior/Exterior/Lighting) 2 05-25-2013 12:44 AM
White M/T FRS with exhaust $23k yayforaddison Cars for Sale/Trade 1 03-29-2013 09:59 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 02:59 AM
Smoke from new USA TRD exhaust DaveFTW Engine, Exhaust, Transmission 22 10-03-2012 04:03 PM
