#477 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I've had the WORKS AB-M axleback since April: http://www.ft86club.com/forums/showp...&postcount=326 ...and I've had a JDL UEL header on order for 119 days so far
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (08-28-2013) |
#478 |
@ATL BRZ what catch can are you using? I was considering the investment in one.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#479 | |
This one, specifically: http://amzn.com/B004K9BIY4 It does its job well and features an easy drain valve with a rubber stopper. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | swift996 (08-28-2013) |
#480 | |
Snow Don't Hurt!
#481 |
Silver oil cooler core is going back to Perrin; no reason besides color preference...
![]() Black core is getting installed with rest of kit. ![]() Project Mu Club Racers arrived, will be bedding them in soon for track duty ![]() Two new 5 gallon jugs for E85 transport to the track. Test fitted them; like a glove! |
#482 |
![]() Cooling down on the lift in the air conditioned shop. She's so spoiled. |
#483 |
After the garage got down to a cool 70 degrees, the first order of business today was the oil change over to Millers Nanodrive CFS 0w30 NT.
![]() Installed Fumoto F-108S oil drain valve ![]() Added some dive mesh to both of the brake cooling ducts to keep the bugs and debris out. Thanks again @smbstyle for the mesh. ![]() Installed Perrin Oil Cooler kit with the new black core from Mocal ![]() ![]() I installed the kit from below with the help of the lift so I didn't have to remove the bumper; way easier just pulling the under trays off. Everything went on according to the instructions and I used high temp thread sealer on all the fittings. First test run around the block with the cooler installed I had small leaks from both fittings on the cooler. With the heat expansion and contraction after cooling back down I guess I didn't get them tight enough so I tightened them again and wiped everything clean and went on another test drive and ended up tightening them again another 1/4 turn from the fittings and I made it 25 miles home completely dry with no leaks. Advice to anyone installing this kit just make sure you get the fittings REALLY tight and then re-tighten them at least once after a short test drive and keep those two wrenches in your car for the first few drives. Oil temps are significantly lower now! Cruising home the oil temp hung out right around 180F in the 95 degree ambient temps that we have today where before the cooler I would run 220-230F cruising around. Previously at the track I'm certain the oil was getting to 270F+ since I could feel the timing being pulled and the car began to lose power late into my sessions in the summer heat. I shouldn't have that issue anymore! Power will be consistent all the time which makes the cooler worth it. ![]() Speaking of power, it might be placebo, but the car does feel a little better up top with the Nanodrive 0W-30 oil in it. Miller's did measure +6whp on a dyno with the same oil but 20 weight. It should make the most power after I thin it out a little more with some track time, which is conveniently only 20 days away! Next up is a MUCH needed wash and vacuum. She's filthy!
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | smbstyle (08-31-2013), Touge Factory (09-10-2013) |
#484 | |
Drives: tornado Grey Manuel
Happy Birthday Melanie
![]() Quote:
| The Following User Says Thank You to Salgts86 For This Useful Post: | ATL BRZ (09-01-2013) |
#485 |
Getting clean
![]() Love the sud gun. Last edited by ATL BRZ; 09-01-2013 at 09:44 PM. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (09-04-2013) |
#486 |
Drives: 2013 SWP BRZ
I meant to ask you; how big of a difference did the RCE Yellows and swaybars make? Any downsides to that combo? Was the car just as neutral as it was stock, or did it make it more prone to oversteer or understeer?
#487 | |
With and without the RCE hollow sways the car is very neutral 95% of the time, and it will progressively oversteer if pushed beyond the limit of tire adhesion. The sways are a great match for the springs as they benefit the handling greatly by getting rid of nearly all body roll. With decent negative camber front and rear the turn-in is razor sharp and the car is very fun on the track with sticky street tires without being too low/stiff to daily drive around town. If it were a dedicated track car with slicks or R-Compounds then I'd go with stiffer springs on a set of coilovers so I can set the ride height lower and run wider wheels/tires. For now though I'm very happy with the car the way it is. I have some track footage linked in the first post that may give some better perspective on how the car behaves at the limit around a couple different road courses. |
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | Racecomp Engineering (09-03-2013), smbstyle (09-02-2013) |
#488 |
Better shot showing how stealthy the black oil cooler core is
#489 |
Snow Don't Hurt!
I still tear up in my eyes when I see your car, even though I have a similar car with plenty of mods. haha It's always so clean! I can't keep mine clean for anything. Honestly, that's one reason I like winters in Alaska, because it's cold and cars pretty much stay clean except when caked with snow, which is easier to wash than dirt. And I have a warehouse I can dry my car off in.
| The Following User Says Thank You to chanomatik For This Useful Post: | ATL BRZ (09-04-2013) |
#490 |
:unamused:
Drives: 2005 WRB STi "Edna"
Oh my. Those rims are oh so pretty. Nice ride!
| The Following User Says Thank You to Stierzy34 For This Useful Post: | ATL BRZ (09-04-2013) |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
