Old 09-03-2013, 08:25 PM   #1
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Exclamation OEM dash or center console buttons, help identifying.
I've found the body group on this site:
http://www.villagescionparts.com/
But having some trouble finding specific part numbers, and any assistance would be helpful. Their reference to REFER TO FIG 84-01 doesn't help.
http://www.villagescionparts.com/sho...category=19377
I noticed in the US version it has 3 working buttons, but in my Australian GTS version only the bottom two are functional. So would like to be able to get a funcation 3rd button for future use.
Also the center console button, the center one isn't used and that could be an alternate option if I could get a version with the working middle switch.
Rumbaar is offline   Reply With Quote
Old 09-03-2013, 09:21 PM   #2
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
The Subaru part number for the switch by the gauge cluster is 83001CA040.
The Subaru part number for the switches by the shift surround is 83245CA020 (for the automatic version, manual transmission car only has two buttons).
If I remember correctly, these part numbers may require you to order from a US seller. They may not translate to other countries.
More importantly, I think these switches are CAN bus switches. Best of luck in using them for something else.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Rumbaar (09-04-2013)
Old 09-04-2013, 03:46 AM   #3
Rumbaar
Rumbaar's Avatar
Thank you for that, I don't mind ordering from the states and figured I would have to anyways. Just finding the correct part number to order was a challenge.
I was hoping I could frankenstein the switch and only retain the top part and use other components behind them to perform other functions. I guess I should really look at my current ones.
button, console, dash
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Center Console Seat Heater Buttons larryt1026 Electronics | Audio | NAV | Infotainment 15 07-31-2013 12:21 AM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 08:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 09:56 AM
FR-S / FT-86 Colors, Instruments, and Center Console/Dash Now Revealed Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 202 11-25-2011 08:21 AM
