Old 09-03-2013, 04:46 PM   #71
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by jet86 View Post
So guys I have acquired a fb25 short block and I've got numerous fa20 heads. I threw the heads on the fb25 block and well.. they fit quite well. Only issues I can see with this setup is the combustion chamber may need to be ported (probably cnc) a you have to take it out 8mm bigger. And the other thing is the starter motor location is missing off the fb25. Everything else is identical.
Sent from my GT-I9505 using Tapatalk 4
How's the total width compared to the fa20?
Will the oil pan from the fa20 bolt on to the fb25 allowing it to sit as low in the chassis?
Old 09-03-2013, 05:29 PM   #72
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Apart from starter motor location and a random thread missing in the fb their identical externally
jet86 is offline   Reply With Quote
The Following User Says Thank You to jet86 For This Useful Post:
Calum (09-03-2013)
Old 09-03-2013, 05:46 PM   #73
Calum
That Guy
Awesome!
Old 09-03-2013, 05:53 PM   #74
Noob4Life
86 Noob
Drives: Firestorm FR-S
No pics?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
Noob4Life is offline   Reply With Quote
Old 09-03-2013, 05:56 PM   #75
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
I picked it up last night so didn't have very good lighting for pics. Il take some this arvo and probably make a new thread on it.
The Following 3 Users Say Thank You to jet86 For This Useful Post:
meeks (09-04-2013), Noob4Life (09-03-2013), Snake (09-04-2013)
Old 09-04-2013, 02:10 AM   #76
Kostamojen
Get pics ASAP!!!
Check the coolant passages too between the head and the block, use the headgaskets to check.
Old 09-04-2013, 04:47 AM   #77
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
lets do this!!!!!
NYCsubaruBRZ is offline   Reply With Quote
Old 09-05-2013, 11:19 AM   #78
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Without getting into detail, there are 'issues' with it. It isn't like comparing EJ engines where it was basically bore and stroke changes within the same block.
-Micah
3MI Racing is offline   Reply With Quote
Old 09-05-2013, 12:10 PM   #79
Calum
That Guy
-Micah
Ok. So is it reasonably possible? Or is this off the able for most of us?
Old 09-05-2013, 02:54 PM   #80
3MI Racing
3MI Racing's Avatar
It wold be possible, sure...would I see it as something marketable, no. I'll hold off and see what the factory turbo engines offer before sinking into it.
Heck, people aren't even into playing with the available longer stroke crank (would make it a 2.1) nor playing with cylinder heads...hint hint
-Micah
'Homemade WRX'
Old 09-05-2013, 06:45 PM   #81
Calum
That Guy
-Micah
'Homemade WRX'
More stroke on this engine doesn't seem like a good idea to me, the stroke to rod ratio is already bad enough from what I understand. Do you feel the longer stroke would be a good idea? What do you see in the heads that can be improved upon? Are the FB heads better in some way?
We've had too many conflicting stories from people that have shown themselves to be untrust worthy. An educated opinion would be really nice. At this point there are just too many unanswered questions for me to even begin to know where I'd like to end up power wise. Hell, I don't even know if I want to stay NA or go FI yet.
Old 09-05-2013, 08:58 PM   #82
Dimman
Kuruma Otaku
Dimman's Avatar
-Micah
Would you by any chance have a stock FA20 CFM number (@28" of water or other pressure reference) that could be shared?
Because titanium.
Old 09-18-2013, 03:09 AM   #83
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
k so the guy doing the franken motor needs to link us to his thread with pics a.s.a.p
boxer 2.5 is offline   Reply With Quote
Old 10-25-2013, 12:01 PM   #84
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Subbing for future developments.
My shits going to blow eventually. This is the research ill be turning to.
Deadspool is offline   Reply With Quote
Would you guys prefer FB20 or FB25 for NA FT? tranzformer Engine, Exhaust, Transmission 89 07-20-2011 04:00 PM
FT-86 to be "introduced" for early 2012! Press conference clip from Geneva Motorshow ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 32 03-05-2010 02:07 PM
Design Proposal for a New VW Corrado from the Imaginary World of "What If?" vh_supra26 Other Vehicles & General Automotive Discussions 2 02-13-2010 06:26 PM
