Old 09-02-2013, 06:02 PM   #155
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Originally Posted by FRSBRZGT86FAN View Post
Maybe its time to invest in a better radiator before next summer? I mean these high compression FA20s run hot but I heard mishimoto and Koyo make good radiators that are actually better than stock.
I'd vote koyo/robispec. Seeing a lot of people with quality issues on the Mishimoto setup.
Nightbringer is offline   Reply With Quote
Old 09-02-2013, 07:20 PM   #156
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yea did some more research someone on here recently also had a problem with a mishimoto oil cooler exploding all over there engine bay, and they went to go look at it and it looked perfectly normal just kept spitting oil all over the place.
Old 09-02-2013, 10:41 PM   #157
Suberman
Drives: Subaru BRZ Sport Tech Satin White
High compression engines run slightly cooler. That's where the extra power comes from, more thermally efficient.
Coolant temperature should be as high as possible while still protecting the engine. Coolant temperature won't affect evaporation much, its when the system cools down that the dry air is drawn in which might cause evaporation.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
FRSBRZGT86FAN (09-02-2013)
Old 09-02-2013, 11:55 PM   #158
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I already have the Robispec setup, just haven't been able to install it because I'm still waiting for the oil lines and sandwich plate.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-03-2013, 12:55 AM   #159
xjohnx
Grip>Slip
xjohnx's Avatar
still? yikes, i thought @robispec was cranking those out pretty quickly now?
Old 09-03-2013, 01:07 AM   #160
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
If he is, he didn't send one to me.
Parting out HERE
Old 09-03-2013, 02:35 AM   #161
OrbitalEllipses
Drives: Attitude
@SkullWorks manufacturers those for Robispec, I believe.
Old 09-03-2013, 09:13 AM   #162
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yea, the last update I have from Robispec was at the beginning of August when he said he's going to send them to me by 86Fest. I ordered everything two months ago yesterday.
But now this is beginning to get off topic.
Parting out HERE
Old 09-03-2013, 01:35 PM   #163
SkullWorks
Drives: SSM LT MT BRZ
This is true,
We haven't completed our outstanding orders with Robi yet, We are working to get another batch in his hands early this week.
Mike
Old 09-07-2013, 07:23 AM   #164
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Are you doing all these coolant checks when the engine is hot or cold?
Just so that those who *think* they have a similar issue, I just checked my coolant level at cold (sitting overnight for 8+ hours in my garage) and it was about 1" above the low line, now I normally check it when it is warm/hot as the case may be and I am normally sitting about 1" below the high line. I am not having issues with losing coolant at this time. The temperature range that the coolant experiences and the amount of volume of the reservoir where we can see coolant levels have A LOT of room for change of volume. I just wanted to lend creedence to what @King Tut was saying. I hope the OP has had luck getting all the issues he's been experiencing resolved. Have a nice day/
Turkish is offline   Reply With Quote
Old 09-07-2013, 07:35 AM   #165
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Originally Posted by SkullWorks View Post
This is true,
Mike
You work for CBR?if so pm me
448hpsti is offline   Reply With Quote
Old 09-07-2013, 07:29 PM   #166
SkullWorks
Nope I work for me
Old 09-08-2013, 09:52 PM   #167
BRZnut
Drives: BRZ DGM Limited
With all this talk about coolant levels checked mine today before and after long drive. I have never added any. 6900 miles. Cold it was 1 inch above low mark. After 3 hr drive, 1 inch below the high mark.
Old 09-08-2013, 10:00 PM   #168
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
That's normal, fluid expands when hot. If you want to check it, check it when its always cold so its an accurate reading.
Parting out HERE
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
