Old 08-22-2013, 10:44 PM   #1
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
DIY: Tom's Racing hood damper
Please let me begin with a BIG THANKS to Will over at @468Power for obtaining these things. I believe he may have 1 left! Click Here for more info.
YEAH....because JDM
Install Time: 20-30 mins
Tools Required:
12mm Socket & 3/8" ratchet
5mm Allen (hex) socket
Flathead screwdriver
and some good fingers
Start by Removing these two clips that hold your hood latch cable and washer fluid hose.
Notice the clips that were removed
Next remove the two 12mm bolts that hold the hood onto the hinge. Do one at a time as it will make it easier to install the next piece.
This we will call bracket 'A' which mounts to the hood hinge. Pivot ball on top, facing the center of vehicle.Mount Bracket 'A' to the drivers side of the hood hinge. It should look like this.
Notice the brackets and bolts shown for next part.
Bracket 'C' is installed as shown under the fender with the little handle facing forwards. Make sure the last bolt is on the outside when installing and slide in where red arrow is showing.
Next place Bracket 'B' against the rail where you removed the two clips earlier. **Make sure notch is facing upwards** Use two 5mm allen bolts with a washer on each to tighten Bracket 'B' against the rail catching the nuts on Bracket 'C'. Make sure you reroute your hood cable and washer fluid line through the notch on Bracket 'B'.
Lube pivot ball points
remove clip before installing. When you put this this onto the pivot ball make sure it snaps into place before re-installing the clip
When installing the damper assembly the rod should be facing down with the Tom's logo facing you. And thats it. Now the other side is a repeated process except there are no clips on the passenger side to worry about ENJOY these wonderful things to hold your hood from now on
FINISHED PRODUCT LOOKS AND PERFORMS WAY BETTER!
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 08-23-2013, 12:03 AM   #2
red1993sol
Drives: 2013 white BRZ
Looks good!
red1993sol is offline   Reply With Quote
Old 08-23-2013, 12:56 AM   #3
Simply_the_best
Tom's Racing ADDICT
Originally Posted by red1993sol View Post
Looks good!
Thanks!
Old 09-01-2013, 12:01 PM   #4
scraejtp
Drives: 2013 Subaru BRZ
What comfortable do you feel closing the hood now? I like to slightly drop the hood to close it, and don't like putting pressure on top of the hood with how flimsy the aluminum feels. I imagine you now have to push on the top of the hood to close it?
scraejtp is offline   Reply With Quote
Old 09-01-2013, 12:09 PM   #5
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Always thought about doing that to mine
Kelbyat07 is offline   Reply With Quote
Old 09-02-2013, 10:32 AM   #6
468Power
Drives: POWER, PERFORMANCE, & PASSION
YEAH....because JDM
Tools Required:
Time to do it then Brah - I only have 1 set left. Only 3 sets imported into the USA!!!
468Power is offline   Reply With Quote
Old 09-02-2013, 10:42 AM   #7
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
How much?
Old 09-02-2013, 10:54 AM   #8
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Love it! Very similar to the Syms version with its mounting hardware and locations. You can always tell the real engineering that goes into pieces like these. Keep up the good work!
Beyer Subaru is offline   Reply With Quote
Old 09-02-2013, 03:37 PM   #9
468Power
How much?
Click here for the for sale thread...
http://www.ft86club.com/forums/showthread.php?t=44625
Cheers!
Will @ 468Power
Old 09-02-2013, 04:23 PM   #10
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Oh my, this is *something* I do miss from my old car. Will consider as more are imported.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 09-02-2013, 04:35 PM   #11
RIPTRD71
RIPTRD71's Avatar
Drives: Raven FR-S 6MT
where did you get that toms rad cap?
Originally Posted by wootwoot View Post
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next.
RIPTRD71 is offline   Reply With Quote
Old 09-02-2013, 06:13 PM   #12
Simply_the_best
Tom's Racing ADDICT
How much?
about $250.
Old 09-02-2013, 06:15 PM   #13
Simply_the_best
Tom's Racing ADDICT
From 468Power here on the forums. Tom's makes some quality parts.
Zeta Performance - Hood/Bonnet Damper Kit ZetaPerformance Exterior Parts - The Rest 56 05-03-2013 03:27 PM
Zeta Performance - Hood/Bonnet Damper Kit ZetaPerformance Cosmetic Modification (Interior/Exterior/Lighting) 6 03-28-2013 06:14 PM
FS: Gimmick Motorsports Black Hood/Bonnet Damper kit green_comet Australia Classifieds 1 11-06-2012 09:59 PM
Hood Shock Carbon Fiber Damper Set? Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 24 08-10-2012 02:31 AM
