| Member's Car Journals Car journals by our members. |
SPCorBUST's Built Motor Boosted BRZ | STI | Cusco | JR | E85
Function > Form
Well I've been following the BRZ since the concept. It was a long wait but I finally pulled the trigger back in May 2013, and picked up my 2013 Satin White Pearl Manual Limited BRZ in June from Clint at Heuberger Subaru. I started my "build" in June of 2013. I'm going for an "ego" street and track build using Cusco, STi, and Perrin as the main brands in my build, going for a classy, but low key exterior, and nearly every piece from the nuts, bolts, and bushings, to the brakes, coilovers, and interior upgraded. I want the car to feel communicative and balanced, but razor-sharp and frenetic when I want and need it to be. I don't expect the engine bay to win any awards, as its not my primary focus and I don't want it to look too crazy/clean under there on purpose. I want it to look stock-ish (save for a few flourishes) for when I get my hood popped again, so I'm going (a little) out of my way to make it appear as such by being careful about what draws attention under the hood. On to the good stuff! SETUPS Setup 1: KW C38, Grams 550, 4bar, Delicious FlexFuel tune Setup 2: NA, stock injector, Moto-East FlexFuel tune Setup 3: JR C30, DW 700, 3bar, Moto-East FlexFuel tune Setup 4: JR C30, HBP, DW 700, 3bar, Church FlexFuel tune Setup 5: JR C30, HBP, DW 700, 3bar, Delicious FlexFuel tune, Built Motor Setup 6: JR C30, HBP, DW 700, 3bar, Delicious FlexFuel tune, Closed Deck FA20, 1/2" Stud and Machined Head Work, JE Proseal, Built Motor MOTOR Jackson Racing C30 Supercharger Kit Jackson Racing High Boost Pulley Jackson Racing Oil Cooler Perrin Crank Pulley Perrin Accessory Pulleys Perrin Radiator Hoses Outfront Motosports Closed Deck JE ProSeal Gaskets 1/2" ARP head studs CP Pistons 12.5:1 King bearings Carrillo Rods GSC Beehive spring kit Reimax Oil Pump Gear OmniPower 3bar MAP sensor Fumoto Quick Drain Oil Valve Velox Cam Plate ENGINE DRESS-UP STI Oil Cap STI Oil Filter STI Radiator Cap STI Battery Tiedown Perrin Brake Cozy Perrin Foam Filter Nameless DI Ecu Cover Subaru Blue Engine Cover APR Carbon Radiator Cooling Plate ZSPEC Scion FRS / Subaru BRZ Fastener Dress-Up FUEL Deatschwerks DW300 fuel pump Deatschwerks 700cc injectors Moto-East FlexFuel Kit EXHAUST Perrin 2.5" Resonated Catback Exhaust Perrin Overpipe Perrin Front pipe (catted) Gruppe-S UEL header DRIVETRAIN STI Transmission Mount STI Short Shifter STI MT Shift Knob TRD Quick Shift Kit (Instructions) SouthBend Stage 3 Daily Clutch Velox Billet Clutch Fork Velox Billet Pivot Ball Velox Bell Housing Cover MTEC Clutch Spring MTEC Stainless Steel Clutch Line MTEC Shifter Springs DSS Aluminum Driveshaft Motul Gear 300 (trans and diff fluid) SUSPENSION STI Steering Rack Hardware (longer bolts, nuts, subframe fills/spacers) STI Steering Rack Bushings STI Rear Subframe Bolts TRD Door Stabilizers Cusco Front Lower Arm Cusco Lower Control Arms Cusco Sway Bar Front Cusco Sway Bar Rear Cusco Strut Tower Bar Front Cusco Strut Tower Bar Rear Cusco Power Brace Engine Cusco Power Brace Front Cusco Power Brace Rear Side Cusco Rear Crossmember Brace Cusco Rear Differential Brace Perrin Rear Shifter Bushing Perrin Steering Rack Lockdowns Perrin Rear Endlinks with Spherical Bearings Buddy Club Racing Spec Coilovers BRAKES Stoptech stainless steel lines Stoptech pads Motul RBF 600 (brake fluid) INTERIOR STI Steering Wheel STI Steering Wheel Cover STI Vent Grills STI Center Panel Ornaments STI Door Grips STI Red Door Armrests STI Shift Lever Cover STI Engine Push Start Button Perrin Trunk Pull Handle (red) 2015 Subaru Series Blue Dash panel 2015 Subaru Starlink Stereo System 2015 Subaru center console kneepads 2015 Subaru speaker grille and kneepads Toyota EDM Center Armrest Wheelhaus Fiberglass High Mount 3rd Brake Light Diode Dynamics 5k LED door lights Diode Dynamics 5k LED dome light GCS Door Hinge Covers EXTERIOR STI Front Lip (Instructions) STI Skirt Lip STI Sideskirts (Instructions) STI Rear Aprons (Instructions) STI Dayliner Extensions STI Fender Garnish STI Ornament Front STI Ornament Rear STI Gurney Flap STI Valve Stem Caps STI Series Blue Wheels TRD Aero Stabilizer Rising Cover Instructions Tom's USDM tail lights Valenti 3rd brake light red/chrome Diode Dynamics Always-On Module Diode Dynamics 5k LED side marker bulbs Diode Dynamics 6k CREE LED fog lights Grimmspeed Tow Hook License Plate BeatSonic v2 Shark Fin Antenna Bayson R rear diffuser (STI rep) Window Tint INSTALL QUEUE: Perrin Positive Steering Response System (Offset) Whiteline Roll Center and Bump Steer Kit Whiteline Positive Traction Kit Cusco Power Brace Rear End M.O.R. Quick Bumper Disconnect PARTS TO PURCHASE: STI Rear Subframe Bushings TRD Lightweight Flywheel TRD LSD TRD Fender Extensions Cusco Rear Pillar Power Brace Cusco Exhaust Bushings Cusco Rear Differential Cover Cusco Rear Differential Carrier Strengthened Collar Cusco Rear Trailing Arm Cusco Shift Lever Retainer Bushings Cusco Grounding Kit Cusco Front Lower Arm Plus Rexpeed Carbon Hood Damper Kit Rexpeed Heated Wide Mirrors Velox Non-aggressive Rear Diffuser Velox Fog Light Brake Kit Ace 4-2-1 Type A Header 350 OP AP Racing Sprint BBK Radium PCV Line Oil Catch Can w/ Petcock Kit Seibon TS Hood Whiteline Rear Sway Bar Mount Support Chargespeed Mirrors Revolution Subframe Centering Bolts 18x9.5 +38 Weds SA10R Blue Chrome or 18x9.5 +35 Enkei NT03+M SBC POSSIBLE ALTERNATES JRZ RS Pro Double Adjustable Clubsport Dampers/Coilovers Cusco Alternator Pulley Cover (needs modification) Cusco Accessory Pulley Cover (needs modification) Cusco Steering Rack Stays (vs Perrin PSRS) Cusco Steering Rack Bushings (vs STI or TIC solid) Cusco Transmission Mount Collar (vs STI transmission mount or Whiteline Positive Traction Kit) SPOON Rigid Collars (vs STI Rear Upper Spacer or Torque Solutions Rear Subframe Bushings or Whiteline ) LegSport Super-Lock Rear Subframe Support Kit (vs Whiteline Positive Traction Kit) TRACK EVENTS 9/14/2013 - Subiefest, Roval course California Speedway 2/28/2015 - 86cup, Buttonwillow PREVIOUSLY Delicious SC tune (old setup) Moto-East SC tune (old setup) Moto-East NA tune (old setup) KraftWerks Supercharger Kit - C38 (sold) Grams 550 cc injectors (sold) 4bar Map (sold) TopSpeedAuto catback (sold) Bayson R front lip (sold) Bayson R sideskirts (sold) SWP BRZ Fenders w/ Chrome (sold) Bayson R rear aprons (sold) Helix clear side markers iJDMTOY Chrome LED side markers STI Flexible Draw Stiffener (sold) TRD Air Filter SWP BRZ Front Bumper (one driver side tab broken) FOR SALE SOON: Bayson R rear diffuser (Chargespeed Rep, matte black) K&N Air Filter Subaru Valve Stem Caps Whiteline Gearbox Positive Shift Kit Perrin Rear Shifter Bushing Perrin Reverse Lockout STI Series Blue Rims (comes with stock Primacy's and TPMS) STI Rear Subframe Upper Collars (unused, not compatible with Whiteline Positive Traction Kit) Rallyarmor mud flaps Grams 265 fuel pump Perrin T-bolt Clamps (Black) Unused stock oil pump gear
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor Last edited by SPCorBUST; 05-23-2018 at 05:10 PM. |
#2 |
Here's Bridgette:
Car wash ![]() Home ![]() California Speedway ![]() Buttonwillow
#3 |
Reserved.
#4 |
I drove the SRT-4 before the BRZ which was a FWD beast, having full bolt ons, a big wheel stocker, e85 and a fuel system to support it, a built suspension and just clean all-around. It still sits in the garage and is driven as my second car. Her name is Sloan, and here's a pic:
![]() Family resemblance?
| The Following 2 Users Say Thank You to SPCorBUST For This Useful Post: | sroby (09-03-2019), WhiteFRS69 (07-17-2015) |
#6 |
that's the best way to go on a srt4 stock turbo with a big turbine. bigger turbos usually break the car
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
| The Following User Says Thank You to charged86 For This Useful Post: | SPCorBUST (09-01-2013) |
#7 |
#8 |
I agree. Typically I drive the SRT-4 hard in the canyons, so the turbo can make enough power yet still be really responsive.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | charged86 (09-01-2013) |
#9 |
Drives: 2013 WRB Subaru BRZ Limited
Nice car man! Any pics of the Valenti's by any chance? I wanna see the 3rd brake light.
#10 |
#11 |
Stumbled upon this. Mind sharing dyno sheets and your overall feel of the SC? Reliability?
Latest pics of the car? Thanks! |
#12 | |
![]() [ame="https://www.youtube.com/watch?v=7LKYP99djJQ"]Parts and install review[/ame] [ame="https://www.youtube.com/watch?v=MQo8Tj3t5-c"]Drive along review[/ame] Last edited by SPCorBUST; 07-07-2015 at 02:47 AM. |
#13 |
Kraftwerks C38 kit is out, and Jackson Racing C30 kit is in.
| The Following User Says Thank You to SPCorBUST For This Useful Post: | *LongFella (04-03-2015) |
#14 |
Drives: WRB BRZ
I'm interested to see how it goes for you. I was seriously considering your c38, though carb is a concern. So i'm definitely looking forward to a comparison opinion.
| The Following User Says Thank You to RawrSoft For This Useful Post: | SPCorBUST (03-30-2015) |
