Old 08-30-2013, 09:35 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
LSD noise when cold - normal?
I've noticed this noise for about as long as I can remember, bought the car with 5 miles on it. It's only the first one or two very low speed 90 degree turns, when I'm starting from a dead stop or very slow speed, I hear kind of a dragging/growling sound coming from the driver's side rear wheel area. After the first two turns, no noise whatsoever. Only does this after cold start-up.
Anyone else have this, and is normal? I figured a high performance LSD is gonna make a little racket.
smbstyle is offline   Reply With Quote
Old 08-30-2013, 09:40 PM   #2
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
This is my second rwd LSD (LS2 GTO). They both have done it.
TheseColorsDontRun is offline   Reply With Quote
Old 08-30-2013, 09:41 PM   #3
smbstyle
smbstyle's Avatar
Good to hear! Now I can sleep easy tonight. lol. thanks.
The Following User Says Thank You to smbstyle For This Useful Post:
TONYpepperon1 (10-08-2013)
Old 08-30-2013, 10:17 PM   #4
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I like the noise. Reminds me I have an LSD. I don't think it matters if it's cold or not.
Old 08-30-2013, 10:32 PM   #5
Suberman
Drives: Subaru BRZ Sport Tech Satin White
The Torsen in this car is a 4:1 bias which is REALLY tight. The noise you hear is the tires in tight low speed turns. This same bias kicks the tail out if you really floor it in the same turns.
Suberman is offline   Reply With Quote
Old 08-30-2013, 10:34 PM   #6
Suberman
Not an LSD. Torsen is a torque sensing diff. An LSD locks up after a certain wheelspeed differential occurs. A Torsen biases torque to the slower spinning wheel. If you are on ice or have one drive wheel off the ground you will surely notice the difference.
Old 08-31-2013, 12:44 AM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
I do believe it is normal when cold on cars is rear differentials to make a small chirp or noise when cold, they need to be warmed up first by the friction of the gears and the heat spreading through the fluid.
Old 08-31-2013, 01:19 AM   #8
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
so thats what that gear noise is. i only hear it when i first move the car after a cold start.
garfull is offline   Reply With Quote
Old 08-31-2013, 07:45 AM   #9
Mikem53
Drives: FR-S 6MT
Sounds like the clutch packs in the diff.. Just need to heat up..
I know the Torsen diffs are different.. But on a normal LSD they sometimes add a friction modifier to ease the noise you get with tight turns.. It allows the clutch packs to slip a bit more so it doesn't make noise..
Mikem53 is offline   Reply With Quote
Old 08-31-2013, 09:23 AM   #10
BRZnut
Drives: BRZ DGM Limited
On tight low speed turns I get the rear sound too. Sounds like rear tires are "skipping" over the pavement, if that makes any sense. I especially notice it each morning as I turn out of my development.
Old 08-31-2013, 02:17 PM   #11
CSG Mike
CSG Mike's Avatar
Totally normal
Old 08-31-2013, 04:04 PM   #12
Suberman
No clutch packs in a Torsen. The diff spider gears are helical one way gears (think of worm gears, non reversible) that develop their torque transfer effects by binding inside the carrier. Because they move axially slightly in one direction under load and in the other direction on overrun they can be made to slip more easily on overrun but tighten up under load, which creates the bias ratio.
Not a true LSD because they transfer torque by accelerating the slower spinning axle rather than braking the faster spinning axle. If you have no grip at one wheel you'll get no drive at the other wheel because zero torque remains zero no matter what the transfer ratio might be. This is the Achilles heel of Audi's vaunted Quattro drive. It relies on at least two wheels having grip, one at each end of the car. There has to be a wheel with grip to allow torque to transfer to another wheel. Quattro drive is also useless in reverse as you will find our Torsen diff to be if you get stuck going forwards. Torsen don't limit slip in reverse very well.
I found this helpful:
Be patient, it looks goofy and geeky but the explanation is first rate.
Old 09-17-2013, 11:42 AM   #13
cevin45x
cevin45x's Avatar
Drives: '13 BRZ Limited
The exact noise the OP stated just started to happen to me this morning. Got me really worried. Sounded like a scrapping noise at low speed, left and right turns. And yes it got colder today (63 degrees)
But in my head it sounded like it was coming from the front right of the car. No sounds on the freeway or going on a ramp tho. Idk whats happening, debating if I should have it checked out.
Had the car since July 30th 2012. Been through one winter and no noises until today.
'13 BRZ Limited - CBS MT
STX Build - OFT Stage 2 EL 93oct (etune)/TRD intake/HKS EL catless/Motiv OP/Invidia FP catted/Perrin CBE resonated/All complete Whiteline bushings/MTEC trans & clutch springs/Kartboy SS & mount/Perrin 19mm f & 16mm r/Perrin crank & assessory pulleys
cevin45x is offline   Reply With Quote
Old 09-17-2013, 12:12 PM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by Suberman View Post
Not a true LSD because...
Everything else you said is right but that because it's opinion. As long as the inside tire is connected to the ground and has traction the Torsen Diff will bias torque. That is the definition of limiting slip and quite succinctly so. It seems to me that your definition is that of a "locker" or a "locking differential". I know I'm being pedantic but I just want to clarify the semantics. (and now I'm rhyming...)
The Torsen Diff does meet the definition of a slip-limiting device.
There are even torsen diff's (like the WaveTrac) that utilize an internal arc ramp so that the diff functions even when the inside wheel becomes unloaded, which is something would have been nice on this car.
PRO86 | WTCC | STL
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 03:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
