go_a_way1
Old 08-28-2013, 11:57 PM   #575
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by 636 View Post
18x9.5 +38
225/35/18
Spacers coming soon. :x
Hi-Res Here!
DAAAYMMMMM!!
Love the red!
The Following User Says Thank You to Wes For This Useful Post:
636 (08-29-2013)
Old 08-29-2013, 05:54 PM   #576
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Volk ce28ns
Front: 18x8.5
Rears: 19x9.5 and 25MM H&R wheel spacers.
Tires (I'm guessing stretched) are 225/40 Michelin Pilot SS
Not sure about the offsets, staggered.
No rubs until now, aggressive or what? haha.
Yamajee is offline   Reply With Quote
Old 08-29-2013, 07:26 PM   #577
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Originally Posted by SLICVIC View Post
haha google up some good ol tricks of the mcpherson set up. Alot of guys only getting -3ish up front i got -9 , tucking 18x10.5 +6 with plenty room, can prolly throw a 10mm or 15mm spacer even and still tuck. And i can still get waayyyyyy more camber without having to use lower arms
What trick is this? I've read something about using washers.
Kwise1 is offline   Reply With Quote
Old 08-29-2013, 07:36 PM   #578
ZionsWrath
Thanks
ZionsWrath's Avatar
Must be a troll, why 25 mm spacer the rear and ruin the look. And not even camber to tuck it in.
I see what you did there.
Old 08-29-2013, 09:27 PM   #579
djliquidsteele
Drives: Scion FR-S
Originally Posted by Yamajee View Post
Volk ce28ns
Front: 18x8.5
What tails are those?
djliquidsteele is offline   Reply With Quote
Old 08-30-2013, 01:18 AM   #580
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
Double stagger huh? Not bad.
I would go for a smaller spacer or lower/camber it a bit. That's a lot of poke at that height, looks like it will rub on the tread almost.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 08-30-2013, 03:17 AM   #581
Yamajee
Yamajee's Avatar
Hahaha, ain't trolling at all. Ruin the look? well thank you for your opinion I guess. This setup is just for show and I ain't driving it a lot at all, whenever I need to drive the car for a trip or for a few days then I just take off the spacers and everything goes back normal with the right amount of camber I need I guess.
Spyder smoked.
Yeah as I said, the spacers are just for show, forgot to mention that it has an eibach 1" drop, camber was adjusted for non-spacer setup so can't fiddle with that every time I need to remove the spacers and whenever I need to put them back on. Looks like it but, until now, no rubs at all!
To those wondering why I did this, I always loved seeing aggressive setups with just the sidewall of the tire sticking out a little bit more than the fender for some reason.
Old 08-30-2013, 05:25 AM   #582
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
19s
Staggered Stance setup, here you go.
Zardoman is offline   Reply With Quote
Old 08-30-2013, 10:48 AM   #583
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Volk ce28ns
Front: 18x8.5
Is this your car? Because those specs don't sound right considering how much that's poking.
I run 18/9.5 with a 20mm spacer on the rear and mine doesn't poke anywhere near as much as that. Plus those tyres look super stretched, looks more like a 215 or even 205.
My apologies if it is your car and my presumptions are incorrect.
Either way, LOOKS BOSS!
JordanWho is offline   Reply With Quote
Old 08-30-2013, 02:45 PM   #584
jedichimp
jedichimp's Avatar
Drives: yes
I dig it @Yamajee, the rear looks awesome.
panda cheez
Old 08-30-2013, 03:34 PM   #585
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
SLICVIC is offline   Reply With Quote
The Following 2 Users Say Thank You to SLICVIC For This Useful Post:
jdmasfcuk (09-01-2013), stancypants (08-30-2013)
Old 08-30-2013, 04:04 PM   #586
Yamajee
Yamajee's Avatar
Yes indeed it's my car. I'm quite sure of the specs as I've seen the boxes and have ordered them myself, I heard about different offsets and having more poke because of them, is this true?
Don't forget your offset might be in the late positives and your wheel might not have a lip so that would not cause it to poke as much. Tires are 225/40 and I'm certain, I can take pics for you if you really like the setup and want to see more =).
Thank you!
Wanted to mention you after I attached the pictures but forgot, let's say my setup is the mini version of yours .
The Following 2 Users Say Thank You to Yamajee For This Useful Post:
JordanWho (08-30-2013), SLICVIC (08-30-2013)
Old 08-30-2013, 04:06 PM   #587
lp87
Drives: 2013 swp brz
lp87 is offline   Reply With Quote
The Following User Says Thank You to lp87 For This Useful Post:
Old 08-30-2013, 05:33 PM   #588
JordanWho
JordanWho's Avatar
My apologies .... I though I read they were +38. My mistake.
What offset are your wheels if you don't mind sharing.
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
