Old 08-30-2013, 03:32 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Odd Gremlin with Fuel Light ON
This is a weird question that maybe someone here who has modified their ecu + fuel system has a simple answer to.
Twice now I have lost throttle control while cruising on the freeway when the fuel low level light was on. Both times were several minutes after the light came on.
A. It will drop me out of Cruise Control and I will not be able to accelerate.
B. Car will coast for a few secs (engine still on) and then abruptly I'll have throttle control back again.
C. A few secs later I will lose throttle control again.
D. This cylce repeats.
Both times I pulled over to a gas station and filled her up with gas. Issue disappears after that.
I am thinking it must be a fueling issue but can't figure out what it may be? I haven't touched the fuel system since the Innovate Supercharger and Deatschwerks Fuel Pump install 3-4 months ago.
The car runs perfectly otherwise. AFR's are spot on. Fuel trims look good. No hesitations or loss of fuel to the engine when the tank is filled. No codes.
Old 08-30-2013, 03:45 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Twice now I have lost throttle control while cruising on the freeway when the check engine light was on. Both times were several minutes after the light came on.
how's the rail fuel pressure look?
Old 08-30-2013, 03:50 PM   #3
s2d4
s2d4's Avatar
probably due to the shape of the fuel tank.
Old 08-30-2013, 03:55 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It doesn't make sense that it happens at cruising. If it were going sideways on the track ok, but cruising it should have nothing to do with tank shape.
Old 08-30-2013, 03:57 PM   #5
Dezoris
Dezoris's Avatar
Log when it happens is timing getting axed?
Old 08-30-2013, 07:15 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What is the Check Engine Light you are getting when this process starts?
Old 08-30-2013, 07:32 PM   #7
sw20kosh
Sorry typo. Meant to say Fuel Low light.
Old 08-30-2013, 08:10 PM   #8
mike the snake
Sounds to me like your fuel level meter maybe didn't go back in correctly and even though it shows you having a little fuel left, you're actually running out of fuel.
That would explain why it works fine while the gas light isn't on.
The Following 3 Users Say Thank You to mike the snake For This Useful Post:
mad_sb (08-31-2013), nix (09-01-2013), Sportsguy83 (08-30-2013)
Old 08-30-2013, 09:39 PM   #9
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Do you usually fill the take completely after this happens? If your fitting over 12.5 gallons your fuel light might be coming on a little late. Mine comes on after about 10.5 gallons.
Grymm86 is offline   Reply With Quote
Old 08-31-2013, 12:08 AM   #10
sw20kosh
When I filled up the last two times when this happened, it only filled up to 10.2 - 10.5
I will data log it but have to wait till fuel is low.
Old 08-31-2013, 12:46 AM   #11
Dezoris
Dezoris's Avatar
If it it is ecu, fuel or timing related you will see it. Could be mechanical/pump related too. But log and check first before taking anything apart.
The Following User Says Thank You to Dezoris For This Useful Post:
evo4g63 (08-31-2013)
Old 08-31-2013, 02:23 AM   #12
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
+1
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-31-2013, 02:51 AM   #13
ft_sjo
Drives: GT86
Are you running RaceROM?
Old 08-31-2013, 03:42 AM   #14
sw20kosh
Yes I am. You have a suspicion about something?
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 09:33 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
Premature low fuel light WolfpackS2k BRZ First-Gen (2012+) — General Topics 76 06-21-2013 10:45 AM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
