Old 08-28-2013, 04:14 AM   #1
notout86
Drives: GTS 86 auto
Cruise control with Sport or VSC Sport mode
Like a lot of people I like to relax my accelerator leg and use cruise control everywhere.
I also like Sport mode.
With auto transmission, is there a mod to allow CC to be used in Sport mode without constant inactivation? Why can't they get along together anyway?
For that matter, why can't Sport VSC and CC get along?
Old 08-28-2013, 09:24 AM   #2
FRyeS
Drives: 2013 FR-S Asphalt 6MT
That doesn't make sense to me.
FRyeS is offline   Reply With Quote
Old 08-28-2013, 09:32 AM   #3
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
The reason they don't get along is that CC wants to travel in the most efficient manner (i.e. it tries to stay in the highest gear it can in order to maximize fuel economy) and Sport mode, well, doesn't. Thus they're at odds with each other in regards to shift logic.
I'm not sure what the rationale behind the whole VSC/CC thing is, but my guess is that they assume you're doing smooth highway driving when you've got CC on and not engaging in random drifts.
MVJ1975 is offline   Reply With Quote
Old 08-28-2013, 09:35 AM   #4
Mister
Mister's Avatar
Drives: Firestorm FRS
The car does not need to be in "Sport" mode in cruise control. Sport changes shift points and speed, something that should not matter in cruise.
You want CC you turn it on. You want Sport you turn that on, you do not need both on at the same time.
For the small amount of effort it takes to switch back and forth occasionally, I don't think it would be worth hacking up wires in your console.
If it just makes you tingle to see the extra lights on your dash, in that case I have no good answer.
Mister is offline   Reply With Quote
Old 08-28-2013, 05:27 PM   #5
SpyderDan
Toyota hoarder
SpyderDan's Avatar
Drives: 10 Series FR-S, 05 xB, MR-S GT-300
Having the transmission in sport mode changes the throttle-by-wire input processing (without sport mode the inputs get smoothed out for fuel economy). Cruise control takes over the throttle, and wants it smooth, so sport mode is disabled.
If using manual mode and switching back and forth from cruise control, remember that you need to be in "D" to properly select sport mode. Leaving it in "M" and pushing the Sport button won't do anything but turn on the "Sport" light on your gauge cluster. You need to pop the shifter over to "D", hit the sport button, and then back to "M".
It can be mildly annoying, but it only takes about 3 seconds. Chances are, if this is ruining your drive, it is probably a poor scenario to use cruise control in the first place.
SpyderDan is offline   Reply With Quote
Old 08-28-2013, 09:23 PM   #6
SLEEPER WRX
WOW - I've been doing it wrong!!!
Where did you learn this -
"Need to be in "D" to engage Sport mode"
SLEEPER WRX is offline   Reply With Quote
Old 08-28-2013, 09:36 PM   #7
bestwheelbase
Drives: 1985 P-Type
Right now I am picturing the most consistent figure 8 drifts ever.
The Following User Says Thank You to bestwheelbase For This Useful Post:
Efferalgan (08-31-2013)
Old 08-28-2013, 09:50 PM   #8
SpyderDan
Toyota hoarder
SpyderDan's Avatar
It is in the owner's manual. Page 175 (BRZ manual).
"If sport mode is changed to while the select lever is in the M position, the
“SPORT” indicator will come on but sport mode controls will not be carried
out. Shift the select lever to the D position."
Old 08-28-2013, 11:47 PM   #9
Dazza
Dazza's Avatar
Drives: Tornado Grey Toyota 86 GT
Its the sledgehammer approach to risk management based on the premise that in normal mode if the car loses traction it will reset the CC, therefore if you have VSC off the CC will assume you have lost traction.....easy but dumb
Dazza is offline   Reply With Quote
Old 08-29-2013, 12:12 AM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Buy a car with manual transmission?
Old 08-29-2013, 11:40 AM   #11
SpyderDan
Toyota hoarder
SpyderDan's Avatar
Originally Posted by StarshipPoopers
So if you start it up and turn off the nannies and turn on sport mode while still in park, and then on the way to shifting into manual you have to pass through drive, it will be activated?
Good question, but I am not sure.
I have adopted the habit of shifting to "D", then select Sport mode (along with VSC Sport), and then shift to "M".
Old 08-29-2013, 01:13 PM   #12
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 08-29-2013, 06:50 PM   #13
SLEEPER WRX
Thanks "Spyder Dan"
I'm looking for header recommendations - you have any?
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
Sport mode/traction control BushMan Scion FR-S / Toyota 86 GT86 General Forum 7 08-05-2013 04:54 PM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 06:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
