#1303 | |
Drives: 2016 Subaru WRX
E85 in high heat on this kit IMO is a must! Down here since Phoenix sources its gas from CA, we get all the additives and extra detergents due to high CA emissions. We saw first hand that Tucson fuel was better than what we have just north in Phoenix. Even at that its still not enough to keep the motor going for a long life span. It may be okay once the IC is released and an oil cooler is added. Those of you that have 93 are lucky. I gained roughly 41hp over 91 pump on the corn with me only being around E70 on the dyno. All in all it is better to run than e10 due to its cooling capabilities. If its accessible to anyone on any FI setup than opt for it.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD Last edited by evo4g63; 08-29-2013 at 11:42 AM. |
#1304 | |
I Love custom Turbo kits
Drives: Limited BRZ
#1305 |
Drives: Scion FR-S
I will be upgrading my injectors to handle e85 with my innovate kit. Do I need a new fuel pump as well?
My build thread, slowly but surely http://www.ft86club.com/forums/showthread.php?t=40509
#1306 |
The pump is a must in every case. Some tuners are using stock port injectors and upgrading the pump. I would get both but your tuner should let you know what it can be tuned with/on.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#1307 |
Drives: Scion FR-S
Tuner recommended the injectors but didnt say anything about the pump, I'll ask.
#1308 |
I'm getting between 21-23mpg on E85. It's still too new for me to feel comfortable with running it full time (not to mention I couldn't do to the distance from me) but it does seem to run a lot better. More power and smoother. I'm still hopping to get my 93 tune ironed out though.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#1309 | |
-2016 Subaru WRX
#1310 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
what pump are you all using these days? still on two o-rings or have we moved onto a cleaner install now?
#1311 | |
Drives: Limited BRZ
This is my thread http://www.ft86club.com/forums/showthread.php?t=33993 And the perfect DIY for the DW 265c pump by @xxscaxx http://www.ft86club.com/forums/showthread.php?t=41770
#1312 | |
Grip>Slip
#1313 |
Grip>Slip
#1314 |
In Test:Oil Fed SC
I'm not down with more than one oring, never have been never will be...so I need to find another solution for my tracking peace of mind. Not yet convinced I need one but have yet to start tests with e85. Does one such pump that fits without more than one oring actually exist? :-(
#1315 | |
Drives: Limited BRZ
That's how I have it installed but didn't even mention it because he wants it as OEM as possible. Gem, the SBD I'm selling installs with the white OEM spacer and one O ring. Sorry if this posts has mistakes, I'm on the phone!
#1316 |
Drives: 2013 BRZ limited SWP
Look what showed up today!!!
![]() Sent from my DROID RAZR using Tapatalk 2 |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
