Old 08-29-2013, 02:55 AM   #57
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Originally Posted by zoomzoomers View Post
I've been paying attention to this type of solution. Hope they release one for the AT's.
Couldn't you source this from other Subaru parts and create your own? Or would that be too difficult to accomplish?
They have updated it!! it is available for Autos now
ahaghshenas is offline   Reply With Quote
Old 08-29-2013, 03:02 AM   #58
zoomzoomers
zoomzoomers's Avatar
How much?
Old 08-29-2013, 05:52 AM   #59
ahaghshenas
Drives: Subaru BRZ
How much?
On Cusco website it is 58,000 yen about $592
Old 08-29-2013, 02:25 PM   #60
zoomzoomers
Still a little pricy for what you get, but not bad I guess.
Old 08-29-2013, 04:03 PM   #61
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Where can I buy one for the AT?
No oil leaks, no chance of oil cooler damage with an off-road excursion.
Who has one for sale? Anyone?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-05-2013, 09:40 PM   #62
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Has anybody actually installed this kit? I bought one from @FT-86 SpeedFactory and can't seem to find the "Engine Water Inlet Pipe Flanged Section". I'm thinking it is under the intake manifold. Any ideas?
http://www.cuscousainc.com/downloads...rz_zn6_zc6.pdf
1010110 is offline   Reply With Quote
Old 09-06-2013, 10:25 AM   #63
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. That is the piece that @Frs300 had to have repaired on his blown motor. It is a cast aluminum piece that carries coolant across the top of the motor and supplies it to both sides of the motor and the throttle body. It is definitely under the intake manifold. Sounds like you can reach it without removing the intake manifold:
For easier access to this Flanged Section, remove the intake manifold vacuum hose from the brake booster and its bracket.
Old 09-06-2013, 11:56 AM   #64
1010110
Thanks Tut. I saw that in the instructions, but I though maybe I would be able to at least see that part before removing those pieces. I'll remove and see.
Old 09-09-2013, 11:40 AM   #65
zoomzoomers
So has anyone successfully installed one of these yet? If so, what's the result?
Old 09-10-2013, 05:14 PM   #66
tonystewart
Cusco Oil Cooler AT Version
Unpacked
Automatic Transmission Version
Cut New Perrin Hoses but don't cut the top one short like the directions say or you'll be stuck with a hose that won't reach the block
Easy install, remove you need a tool to remove factory oil filter threads
Top Radiator hose
Bottom Radiator Hose
I used these directions to replace the hoses
http://www.ft86club.com/forums/showt...radiator+bleed
Old 09-10-2013, 06:38 PM   #67
robispec
Drives: Black frs project
this is the part that everybody replaces on their can't keep it cool Sti's...
sorry about the troll.. lol
these just don't have enough surface area...
Robi
robispec is offline   Reply With Quote
Old 09-10-2013, 07:08 PM   #68
zoomzoomers
So are you saying this will not do what it's advertised to do robi? I think we all trust your opinion so let her rip.
Robi
Old 09-11-2013, 04:51 AM   #69
Seattle944t
Drives: Sc10n
Originally Posted by tonystewart View Post
Soon
Cool - looking forward to hearing the difficulty of the installation with the AT cooling hoses and how effective the setup works.
Seattle944t is offline   Reply With Quote
Old 09-11-2013, 11:34 AM   #70
1010110
I installed the cusco oil cooler (MT) along with an innovate supercharger on my car last night. While on the car's shakedown run, which included some spirited driving, the maximum temp reached was 200F. In between spirited runs the oil temp quickly stabilized.
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
New Cusco oil cooler ahaghshenas Engine, Exhaust, Transmission 11 04-02-2013 10:48 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
