Old 08-27-2013, 02:55 AM   #57
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
Originally Posted by Hawaiian View Post
Tell me about it. At 32k miles and a few Autox I NEED to change my brakes and fluid. Also, it's time for Stainless lines. I was waiting to do it all in one go.
I can fit my pinky in between the nub and the cat. My others, not as well. I can get my pinky in to about the nail by the crossmember before it gets too narrow.
I know what you mean. I've been under the car enough to not want to get back down there, but in the name of trying to help people I was willing to give it a go. Unfortunately I've had the heat shield off so many times that it seems I've messed up one of the bolt threads for the undertray. I will need to have it tapped. I blame the Harbor freight tools, and working on jack stands.
I don't know about a "nice video". When I watched it, it felt like a Michael Bay film. All shaky and filled with odd camera angles. It's a good thing I'm not Vtuned anymore or there would have been the matching explosions.
One more thing that I thought of while I was puttering around today (after I filmed the video). Stand in front of the car and imagine the header as your legs. Now put your left arm out at an angle to match the downpipe with your arm slighly bent. Holding that angle, lift your arm up and down by only rotating your shoulder. That's your Vband clamp. It gives you a bit of adjust-ability but when you're dealing with a 3cm space above the Cat, and a 2-3mm space under the overpipe it really needs to be spot on.
If your cat is contacting the block, then your "arm" is lifted too high. The Vband needs to rotate down a little. If it's contacting the cross member and pushed to the passenger side, it's rotated too far "down" and needs to rotate up a little.
As I said in the video, the easiest way for me to get everything perfect was to leave the Vband loose, and the rest of the exhaust as well. Then I locked the overpipe in place (because it has the smallest margin for error), once that was positioned properly, I tightened the front pipe to it (the bolt to the trans is still loose at this point), then I tightened the Vband down. The last step was the bolt to the trans hanger.
I also had a cross threaded screw that ultimately ruined the thread. As a result my skid plate was loose, and banging around. I thought that was the overpipe, but when my car was on the lift @ P&L I mentioned it to Tyler. He looked up and spotted the bolt right away. He started pounding my skidplate with his fist and it made a metal on metal rattling noise. He Bolted it all back the right way with an impact gun, and the last little noise went away.
If I can help even one or 2 of you with this issue, then it was worth the time spent under the car today.
Wow, you have so much more clearance than me on the overpipe. I left the vband loose, but still had issues. when i had enough overpipe clearance on the crossmember, the vband fit was way off. With the vband flush, i barley got a millimeter clearance. The guys at Infamous Performance did a great job and got the best clearance they could.
thx for the video
P&L EL headers and over-pipe, ARK Grip front-pipe and cat-back exhaust, Delicious Tune, Rays Gram Lights 57DR 17x9 +35 wrapped in Bridgestone RE11a's
SoCal SD 86 Club Admin
https://www.facebook.com/groups/socalsd86/
siXXtoes is offline   Reply With Quote
Old 08-29-2013, 12:24 AM   #58
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Is P&L revising their OP? Grinding out sections of the subframe is not something I would want to do but certainly understand why you did. Looks awesome but why are those details not found in development?
Old 08-29-2013, 12:28 AM   #59
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I never ground anything on my chassis. So far I just bent a piece a metal out of the way. I think the reason why P&L did not find this in R&D phase was because like any manufacturer, they just had to make their product fit with the OEM overpipe and their overpipe. It would be awesome if they bought all their competitors products to make sure they fit, but I understand why they didn't.
I talked to Dylan and he said they are investigating it right now.
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
OICU812 (08-29-2013)
Old 08-29-2013, 10:38 AM   #60
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I had my car in there all day the other day while I was at work, and they were taking more measurements and fabing a few things up.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
F1point4 (08-29-2013)
Old 08-29-2013, 07:17 PM   #61
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Thing is though...if the header genuinely exits on location with the stock header...anything that works with the stock header would then work on the P&L. We should be able to position the downpipe flange to match the stock location within a reasonable margin.
@Hawaiian given that I have less clearance all around with the stock overpipe than you do with an aftermarket, maybe P&L's jigging isn't producing consistent weldments.
Mobius357 is offline   Reply With Quote
Old 08-29-2013, 10:20 PM   #62
charged86
charged86's Avatar
does anyone have the p and l catted with a motiv overpipe
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-29-2013, 11:35 PM   #63
Dezoris
Dezoris's Avatar
Thanks for the amazing thread!! In my last video on track we have a bad vibration under full load left hand turns only. I also hear a faint knock cold starts. We were pretty confident it was the perrin over pipe hitting the sway bar (strano) but now it maybe frame from seeing this. Will report back on it. (Factory header)
Old 08-29-2013, 11:45 PM   #64
F1point4
Photo Specialist
F1point4's Avatar
Thanks, we are here to help each other out! Glad we have the support of vendors and other folks like @Hawaiian
Old 08-30-2013, 12:14 AM   #65
Dezoris
Dezoris's Avatar
I met him at my last autox. He was telling me all about PL which is only 40 minutes from me. I ruled them out because they were late to the FA20 party but now they clearly are on point.
Want to use them for something, sent my buddy there for his alignment after we installed his camber kit and said they were great.
The Following User Says Thank You to Dezoris For This Useful Post:
F1point4 (08-30-2013)
Old 08-30-2013, 01:08 AM   #66
Hawaiian
That guy
Hawaiian's Avatar
Sometimes i go on a bit... there should be more soon.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 09-03-2013, 12:11 AM   #67
F1point4
Photo Specialist
F1point4's Avatar
Motor Mount Comparison
I don't have the means to record video of the engine while driving so idle videos will have to do. Despite this, you can see a clear difference in the mounts.
Note: the vehicle with the OEM mounts is NA, while my car with the Perrin Mounts is Vortech Supercharged. Logically, if the mounts were the same, the supercharged motor would vibrate more.
You can see my motor barely moves on ignition and during applications of throttle. My mate's car, his motor moves a bit.
Perrin Engine Mount
[ame="http://www.youtube.com/watch?v=m4E0JH1KhiY"]86 Motor Mount Comparison - Perrin Performance Motor Mounts - YouTube[/ame]
OEM Engine Mount
[ame="http://www.youtube.com/watch?v=CDw1XPzUqRU"]86 Motor Mount Comparison - OEM Motor Mounts - YouTube[/ame]
Old 09-03-2013, 12:19 AM   #68
wootwoot
Drives: FRS
Does your top cover not fit with the Password JDM strut bar? Or did the mounts raise the engine a bit? Or is it just not on the car...?
Old 09-03-2013, 12:27 AM   #69
F1point4
Photo Specialist
F1point4's Avatar
Just not in the car. I messed up one of the tabs trying to take it off, and it kinda moves when its in there. So i took it out.
Sorry for the confusion
Old 09-06-2013, 09:56 AM   #70
charged86
charged86's Avatar
are you still having rattling problems? mine is horrendous im thinking of removing header and selling it
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 05:38 PM
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated P&L Motorsports Engine, Exhaust, Bolt-Ons 244 09-24-2015 04:44 PM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
SOLD: P&L Motorsports Equal Length 4-1 Header yamsta Engine, Exhaust, Bolt-Ons 18 08-07-2013 10:24 AM
Borla Releases Equal Length Header, Catless Huehuecoyotl Engine, Exhaust, Transmission 1 04-05-2013 09:44 PM
