Old 08-20-2013, 10:14 PM   #239
SkullWorks
Drives: SSM LT MT BRZ
Yeah,
From a mechanical fuel pump under the black plate. Not my words, it's in the fire report something I'm sure I can share when I get my copy.
John
So Where's the report?
I'm sure you also fully disclosed to the investigator that you had a part on the car not 6 inches from the pump which is known to leak fuel under pressure too right? and that it is your kit? because any less could be considered fraud.
So about that report...
Old 08-20-2013, 11:17 PM   #240
accelerated
Drives: Scion FR-S
Im getting fa20clubs line next week. I have the uodated kit so the sensor is the same as their kit.
Does anyone know if the diameter changed from the first sensor to the updated? If it didnt then fa20club's line should work for everyone.
Sent from a Motorola DynaTAC 8000X
The older 12568450 or 12570260 GM sensors had different size inlet/outlets but those sensors are all but obsolete. As long as you're using a current GM sensor, you'll be in great shape to use the @FA20Club.com kit.
accelerated is offline   Reply With Quote
The Following User Says Thank You to accelerated For This Useful Post:
Yruyur (08-21-2013)
Old 08-23-2013, 08:43 AM   #241
Visconti
Drives: 05 STi
I posted this in my other thread but we have some line update instructions located in our support console. If you didn't already get a email about it you will before the end of the day
Originally Posted by mikalem View Post
I believe it is - Goodyear 65128 SAE 30R7 Fuel Line/ PCV / Emission Control Hose:Amazon:Automotive
Sent from my SGH-M919 using Tapatalk 4
I'm not 100% sure if this is the line we are using BUT the lines we are using is 100% ethanol compatible. We knew this was going to be a question and we have documentation from the manufacturer stating its ethanol & methanol compatible
Visconti is offline   Reply With Quote
Old 08-23-2013, 09:42 AM   #242
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Updated parts install guide here. Also added to the first post.
post_break is offline   Reply With Quote
The Following 2 Users Say Thank You to post_break For This Useful Post:
Nightbringer (08-23-2013), Sensisnow (08-23-2013)
Old 08-23-2013, 10:13 AM   #243
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
I'll post up my solution soon for those that do not want to go anywhere near that pipe cutter.
Sent from my electric hamster
enouf is offline   Reply With Quote
Old 08-24-2013, 09:11 AM   #244
enouf
Mr. Grumpy
enouf's Avatar
Finally got around to overhauling the double clamped set up. As if to reinforce the fact the hoses were incorrectly sized, they slid right off as if greased on the inside. For the new hoses, I had to do quite a bit of wiggling in order to get them onto the hardline. Parts list for those that don't want to cut the metal hardline and non US customers:
1 metre of 5/16" (7.9mm ID, 14.2mm OD) Goodyear SAEJ30R9 fuel injection (EFI) hose
2x 6AN female to 5/16" hose adapter (Speedflow, Aeroquip etc)
2x 12-14mm EFI hose clamps (also re-used 2x OEM EFI clamps, they have 13.5mm printed on them)
Total: $45 AUD
I'll let the photos do the most of the talking:
The Following 3 Users Say Thank You to enouf For This Useful Post:
KamalT (08-28-2013), mikalem (08-24-2013), Sensisnow (08-24-2013)
Old 08-24-2013, 09:21 AM   #245
Yruyur
Yruyur's Avatar
Very nice.
Does anyone know what the barb diameter on the original or upgraded sensor is? Will a 5/16 house fit on it or will I need those an adapters you used?
Ill be doing similar today. I was even thinking of removing the an fittings all together and going to straight clamp.
I picked up some line from goodspeed in az where we are doing a dyno day and got to see 4 of the fa20club setups.
The local shop provided this line which they said they would use if they did my install. Its ethanol friendly and exceeds the pressure rating.
Old 08-24-2013, 09:24 AM   #246
Yruyur
Yruyur's Avatar
Old 08-24-2013, 09:28 AM   #247
accelerated
Drives: Scion FR-S
Glad you were able to fix this. A very nice and much needed correction and the write-up / photoshoot is clear and concise. Only thing I'd add to it is something for abrasion resistance but that's just me.
http://mr-gasket.com/inferno-shield-...ing-black.html
Take care!
enouf (08-24-2013)
Old 08-24-2013, 09:34 AM   #248
enouf
Mr. Grumpy
enouf's Avatar
I've added the OEM abrasion sleeve to the hose going to the fuel rail and might do something as well for the contact points near the engine connection and the part touching the plastic box thingy (no idea what that is).
@Yruyur, the barb on the sensor seems bigger than 5/16", could be 3/8". BUT that metal barb is a quick disconnect barb and should not be clamped. You will need to buy the adapters as I have if you want to clamp on the sensor ends.
Also I thought about reusing the fittings from the kit but ultimately decided it would not be safe to use braided hose fittings with a rubber hose.
The Following User Says Thank You to enouf For This Useful Post:
Yruyur (08-24-2013)
Old 08-24-2013, 08:04 PM   #249
enouf
Mr. Grumpy
enouf's Avatar
You know something is terribly wrong when you have this much left over from installing a flex fuel kit by John Visconti - it's an absolute joke:
Old 08-28-2013, 10:58 AM   #250
KamalT
Drives: Pearl 86 GT
Which shop did you buy the parts?
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 08-28-2013, 11:54 PM   #251
enouf
Mr. Grumpy
enouf's Avatar
Bought all the stuff off ebay - links below:
Goodyear SAEJ30R9 hose:
http://goo.gl/ZFyK6F
Speedflow 6AN 5/16" fitting:
http://goo.gl/7vaeJW
EFI clamps stainless steel:
http://goo.gl/TLP6YK
One of the quick connect to 6AN adapter attached to the sensor seems to be leaking a tiny tiny bit (noticed it when I still had the old hose on). I've tightened it to the point where if I do any more it'll start stripping threads off the 6AN head. Looks like I may have to change that out as well
The Following 2 Users Say Thank You to enouf For This Useful Post:
JiB (08-29-2013), KamalT (09-04-2013)
Old 08-29-2013, 03:19 AM   #252
JiB
JiB's Avatar
Drives: GT86
cheers for the links what size clamps?
JiB is offline   Reply With Quote
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
