View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-22-2013, 01:28 PM   #2633
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Originally Posted by sierra View Post
Great.
I used 1gal = 4L from memory but it's 13.21gal as you say.
First time you are treating the complete tank, after that just what you add when you fill up.
Call it 1.7oz for the first time. Still 0.13oz per gallon after that.
That's a lot less than the 4oz of Lucas oil that NICOLA is adding every fill up. Even double that to 1:500 is only 2.6oz for a 10gal fill up but best to use the minimum needed to hopefully shut it up.
Just to add; Lucas Oil says to use 3 oz. for every 10 gallons. I use 4 oz. because we have slightly over a 13 gallon tank. Basically, 1 oz. for every 3.33 gallons of gas. Also, Lucas claims that over treatment (adding more then recommended) will not hurt the engine or other parts in any way. I try to keep it at 3 to 4.
It has been helping I think. However, last week when I filled up with Mobile gas things started up again. The chirp is dying down to near non-existence, but it shows up now and again since that day. I think I need to really purge my fuel tank to very low levels to get rid of that Mobile gas. Who can say? I just know that I had no issues after getting the new pump and using BP gas exclusively with Lucas Oil. The moment I used Mobile.....Bang!!! Crickets came back. Go figure!?
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 08-23-2013, 09:38 PM   #2634
archaeauto
Drives: BRZ, 1968 Chevrolet Impala Coupe
Just got my pump replaced with a *new* part
Just got home after picking up my BRZ from the dealer. Here is the meat of the invoice:
CUSTOMER REPORTS A CHIRPING NOISE COMING FROM THE HIGH PRESSURE FUEL PUMP (CHECK AND REPORT).
200 REPLACED HIGH PRESSURE FUEL PUMP
71 WSU1
1 16625JB000 PUMP ASSY FUEL HIGH PRESS
1 17540AA340 PIPE AY FUEL DLVY
1 17555AA040 GSKT FUEL PIPE
2 14035AA610 GSKT INT MANIF
1 16175AA420 GSKT THROT CHMBR
9000 TEST DROVE VEHICLE AND CONFIRMED CHIRPING NOISE. FOUND TSB 09-54-12R FOR CHIRPING NOISE FROM HIGH PRESSURE FUEL PUMP. RECOMMEND PERFORMING TSB. REPLACED HIGH PRESSURE FUEL PUMP AND ASSOCIATED PARTS PER TSB 09-54-12R. ROAD TESTED AND CONFIRMED THAT CHIRPING NOISE WAS GONE.
Apparently it's about a one hour job, and the cost of the new pump is about $600. Anyway, thought this info might be useful to compare with when you bring in your car for this warranty work. Service-wise, my dealer has been a pleasure to work with.
archaeauto is offline   Reply With Quote
The Following User Says Thank You to archaeauto For This Useful Post:
BrokenNocturne (08-24-2013)
Old 08-23-2013, 09:46 PM   #2635
infinite012
Drives: 13 DGM BRZ Ltd
71 WSU1
They'll be a pleasure until SOA tells them to stop replacing your pump. I'm on my 3rd one and SOA has said no more.
infinite012 is offline   Reply With Quote
Old 08-23-2013, 11:00 PM   #2636
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
I've tried the Lucas Oil lubricant. Didn't help lessen the crickets for me. I used the smaller bottle. Half the first fill up, the rest on the second.
Sent from my XT912 using Tapatalk 2
Terrapin77 is offline   Reply With Quote
Old 08-26-2013, 01:29 PM   #2637
Lizai
Lizai's Avatar
E free gas in. No chirp up to now. But I only put in 30miles. Moreover, the dealer called and they would like to put a updated fuel pump in for me.
Lizai is offline   Reply With Quote
Old 08-27-2013, 12:55 AM   #2638
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
So my FRS started to have the crickets in the 2k mile range. I am a little over 3k and I havent heard them for a couple weeks now. Mostly use Chevron, but occasionally Shell. Anyone have them stop and come back?
tunami is offline   Reply With Quote
Old 08-27-2013, 01:48 AM   #2639
fistpoint
Drives: Supercharged Golf Cart
So, you want ME to read through 122 pages to answer that? Well...OK. The answer is yes, quite a few people.
I've been reading thread this since the beginning.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
sierra (08-27-2013)
Old 08-27-2013, 02:47 AM   #2640
tunami
tunami's Avatar
Haha, fistpoint thanks for the response and reading the 122 pages for me!
Old 08-27-2013, 08:56 PM   #2641
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Is there any real final fix for this problem yet?
tripjammer is offline   Reply With Quote
Old 08-27-2013, 09:13 PM   #2642
sierra
Drives: Skoda Yeti DSG diesel 4x4
Make sure the fuel is completely free of ethanol until they make the HP pump compatible with it or add a lubricant to the fuel to compensate.
sierra is offline   Reply With Quote
Old 08-27-2013, 10:17 PM   #2643
thill
Ethanol free = no crickets for me.
With ethanol = crickets came back.
There does seem to be something to this. Of course it is also much hotter here this week..
Old 08-27-2013, 10:32 PM   #2644
Luis_GT
No crickets at almost 1500 miles... I only have ethanol free gas available here
Old 08-28-2013, 09:00 AM   #2645
HunterGreene
Hail Magnet
HunterGreene's Avatar
Temperature definitely plays a role as well. Humidity may be a variable as well, since it was very muggy and warm here today, but I didn't have any crickets coming into work.
It has priests in it?
Old 08-28-2013, 10:12 AM   #2646
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
i took my car in about 2 weeks ago and they put a tbs on the fuel pump or something. I just dropped it off and they are putting a whole new and improved unit in it
sweetfrs is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
