Old 08-26-2013, 02:44 PM   #897
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Originally Posted by thill View Post
Yes. There is at least one person here that worked with fa20club to get the new est stock (01C) calibration. This is what makes it ironic. The tuner market has access to something most dealers don't and it is clearly installed on newer builds from at least February, so the whole thing is rather ridiculous..
So if I got Ecutek, flashed in the new calibration from fa20club (or who ever) but then flashed my car back to stock for a dealer visit it would obviously be back to the old calibration correct?
@thill if we ever meet in real life I'm buying you a beer :happy0180:
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 08-26-2013, 02:51 PM   #898
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Originally Posted by forwallblakmail View Post
They gave you a new ECU? I'm assuming with the updated calibration, or was it for something else?
It was when all the lights light up on the dash, I guess that's what they do with everyone that has that issue.. At least I seen it on here as a common fix.. Ecu replacement.. I'm not sure the tune/map that's on it.. Took 2 days to get the ecu and all.. I had the same CEL light before and after the ecu replacement
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
forwallblakmail (08-26-2013)
Old 08-26-2013, 02:52 PM   #899
CSG Mike
CSG Mike's Avatar
The dealer will know.
Unsure if Ecutek changes the handshake protocol on the FRS/BRZ like it does on other platforms, but I wouldn't be surprised.
Old 08-26-2013, 03:10 PM   #900
forwallblakmail
Troll Level: Expert
This is a god damn nightmare.
By the way, I can't believe I forgot to mention this:
Once I go to the paddock and parked the car, I'd let t run for a minute or two then shut it off between sessions. If I started it again, shut it off, then started it again, the CEL shut off. Never once did I go back out on track with the CEL on. Again, it always came back on 4-5 laps into the session.
I ususally don't push it until lap 2-3.
I'm leaving work now and using my friends scanner to read the stored codes.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 08-26-2013, 03:58 PM   #901
forwallblakmail
Troll Level: Expert
Not what I was expecting....
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 12-02-2013, 11:32 PM   #902
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Any update on this?
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Lonewolf (12-03-2013)
Old 12-03-2013, 08:26 PM   #903
Carwhisperer
Drives: A lot of supercars.
I've gotten this code before right as my Direct Injectors started leaking back over the past summer.. I keep my rpm's high 4k+ normally. Never tracked my car though.
Carwhisperer is offline   Reply With Quote
Old 03-05-2014, 01:25 AM   #904
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
would changing to an aftermarket injectors solve this problem?
Margovincent_22x is offline   Reply With Quote
Old 03-05-2014, 01:28 AM   #905
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's the DI's. There aren't aftermarket injectors for that.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 07-03-2014, 10:30 AM   #906
Margovincent_22x
I had Subaru PH change my seals and after 3 days the popping sound came back so I ran out of options but to find a new engine. Its taking a toll on my mind, might get carzy.
The stuff I did:
Change coil pack FAIL
Change spark Plug FAIL
Change Sensors FAIL
Change Fuel FAIL
Change All injector Seals/ Insulators/ stc WORKED for 3DAYS then FAIL
Change Port injectors FAIL
Flashed to latest corrected tune from Subaru/Toyota FAIL
Tune using 100% PI FAIL
Tune using 100% DI FAIL
Did compression test and it passed
Planning to change to stock crank Pulley
Planning to Change engine if nothing happens with the next plan of changing the pulley
Until now I get no CEL/codes but just full of popping sound that is dangerous to the heart when driving.
Old 07-03-2014, 11:22 AM   #907
Marrk
Drives: Honda Fit
@Margovincent_22x: What makes you think that a new engine won't have the same defects? [Serious question. No sarcasm intended.]
Marrk is offline   Reply With Quote
Old 09-14-2016, 06:23 PM   #908
pepe
Drives: gt86
there is already a solution for this problem?
how to prevent it?
pepe is offline   Reply With Quote
Old 09-15-2016, 10:31 AM   #909
pepe
Drives: gt86
you think a header uel catted can damage the injectors?
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
