Old 08-25-2013, 12:02 PM   #3137
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Originally Posted by FiRStsc10n View Post
Does anyone know if there is a way when you grab door handle to unlock it unlocks passenger door as well? I'd rather not have to push button on fob or on door. In my lexus this setting is on the nav screen
I would like to know this as well. Thanks for stepping up and post this question!
#944_10_Series_FRS is offline   Reply With Quote
The Following User Says Thank You to #944_10_Series_FRS For This Useful Post:
FiRStsc10n (08-25-2013)
Old 08-25-2013, 12:29 PM   #3138
Luis_GT
try this
http://www.ft86club.com/forums/showp...01&postcount=4
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
#944_10_Series_FRS (08-25-2013), FiRStsc10n (08-25-2013)
Old 08-25-2013, 12:31 PM   #3139
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Originally Posted by #944_10_Series_FRS View Post
I would like to know this ask well. Thanks for stepping up and post this question!
I found the solution. Really should have done my research before asking the question but I was on my mobile. Really quick and simple fix.
Step 1: Open door with car off
Step 2: On key fob hold down the Lock and Panic button for 5 seconds. There will be a constant beeeep sound for those 5 seconds and once 5 seconds is up there will be another beep.
Step 3: You're done. Close the door and test it out. Passenger door unlocks
The gf will be more excited about this than any other thing I will do to this car lol.
FiRStsc10n is offline   Reply With Quote
Old 08-25-2013, 12:31 PM   #3140
FiRStsc10n
FiRStsc10n's Avatar
Haha posted same time I tried that out. Thanks anyway
Old 08-25-2013, 12:33 PM   #3141
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Smart Key 101.......
Correct Procedure here.
To have both doors unlock at the sametime do this procedure.
1- Stand outside of your car.
2- Now lock the car.
3- Now with the doors locked press and hold down the lock and unlock buttons on your key fob at the sametime till you hear 2 beeps from your car.
4- Confirm that they are both unlocking by opening the driver's door with your hand.
Now to reverse this feature do this.
3- Now with the doors locked press and hold down the lock and unlock buttons on the key fob at the sametime till you hear 3 beeps from your car.
4- Confirm that only the driver's door is unlocking by opening the driver's door with your hand.
[ame]http://youtu.be/nDDGlvBS3h0[/ame]
:happy0180:
The Following 2 Users Say Thank You to TRD-X For This Useful Post:
FiRStsc10n (08-25-2013), mush (08-26-2013)
Old 08-25-2013, 01:09 PM   #3142
#944_10_Series_FRS
it works.... Thanks very much
Old 08-25-2013, 01:28 PM   #3143
FiRStsc10n
FiRStsc10n's Avatar
@torqdork Did you ever end up putting the PIAA yellows in for your fogs?
Old 08-25-2013, 03:54 PM   #3144
torqdork
torqdork's Avatar
Drives: RV-7
Not yet. After reading different opinions about possible heat problems with the plastic factory housing, I'm hesitant to install the 55W PIAA's. When I first mentioned them it would've been with the glass Subie housing that might be more heat tolerant. Now I'm not sure which way to go. What is the rating of the factory fog bulb, 35W, right?
torqdork is offline   Reply With Quote
Old 08-25-2013, 09:53 PM   #3145
tomsfrs85
Drives:
Hi all,
Has anyone changed out the stock radio? I put my pioneer avh 5500 in and noticed that the wiring harness that powers the EL display can only be used with the stock unit. I'm curious, has anyone modded the harness or hooked it up to an aftermarket switch to retain the EL display?
Sent from my iPhone using Tapatalk - now Free
tomsfrs85 is offline   Reply With Quote
Old 08-26-2013, 04:34 PM   #3146
remorse87
Car will be here this week! Been a long wait since the end of April/beginning of May
remorse87 is offline   Reply With Quote
Old 08-26-2013, 04:46 PM   #3147
FiRStsc10n
FiRStsc10n's Avatar
I feel for ya and it sucks that I've seen some just sitting at dealers without a happy owner to take it home. Hope this week goes by fast for your sake
Old 08-26-2013, 04:58 PM   #3148
SixSpeed
Drives: '14 Toyota Corolla S
True. There's 2 at my dealership & I am nowhere close to affording one yet!
SixSpeed is offline   Reply With Quote
Old 08-26-2013, 07:58 PM   #3149
southbaym3
Drives: e36 m3
why so long?
I'm in the same boat, I ordered early April believe it or not! Since its an employee order I gotta wait till lasttttttttttt such a horrible wait
southbaym3 is offline   Reply With Quote
Old 08-26-2013, 08:41 PM   #3150
frs10
Drives: tezla
wait, how did you guys order this car? i thought all 10 series were allocated?
frs10 is offline   Reply With Quote
2014, brz, fr-s, gt86
Limited edition WedSports GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-17-2013 02:03 AM
Limited Edition FT86 Oil Cap #127 phenom86 Engine, Exhaust, Bolt-Ons 2 12-12-2012 04:30 PM
Toyota TRD GT86 Special Edition Announced for UK Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 56 07-18-2012 11:23 AM
Limited Edition Colors? bambbrose Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 03:23 PM
