Old 08-24-2013, 03:22 PM   #71
ZionsWrath
Thanks
ZionsWrath's Avatar
The light seems to reset if you park at home with the wheels nearby. However even when it is on it doesn't bother me, just check your pressure regularly.
Old 08-24-2013, 03:23 PM   #72
ZionsWrath
Thanks
ZionsWrath's Avatar
Anyone running these with Eibach Prokit and 245 front 265 rear? want to know if I'm gonna rub if I get springs ^_^
Also anyone running with front crash bolt, what size tire, and are you dropped?
Old 08-24-2013, 03:42 PM   #73
TRD_86
Drives: 2013 86 white
I'm not sure about's crash bolt?
Anyway, I have prokit and I will go for that 245 fr/265 Rr setup for this wheel. (255 will be stretched on 18x9.5 rim ~ 1/2"). I see mostly 235 for front, but 245 is also fit per that photo w/o any problem on Sportlines.
TRD_86 is offline   Reply With Quote
The Following User Says Thank You to TRD_86 For This Useful Post:
ZionsWrath (08-24-2013)
Old 08-24-2013, 03:44 PM   #74
TRD_86
So it's an option not to have TPMS mounted on the ordered wheels b/c it cost $$$ !
Old 08-24-2013, 03:51 PM   #75
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by TRD_86 View Post
So it's an option not to have TPMS mounted on the ordered wheels b/c TR charges $248 !
It is not required. They have to recommend it because it's a "safety" equipment. But if you can check your pressure and don't mind the light in dash you don't have to waste money on it. Besides it only tells you when pressure is low, not your current pressure so it is kinda useless IMO.
Old 08-24-2013, 03:53 PM   #76
ZionsWrath
Thanks
ZionsWrath's Avatar
OK plz post when you get them. Yes I have 235/255 wish I had a 265 rear because the stretch i don't like and considering a 245 front also.
Old 08-24-2013, 04:20 PM   #77
mike the snake
I have this setup. 18x8.5 front. 18x9.5 rear. 45 offset front and rear.
Michelin PSS 245/35/18 front. 265/35/18 rear.
Lowered 1.5" with ST coilovers.
The Following 5 Users Say Thank You to mike the snake For This Useful Post:
GuerillaRacing (08-25-2013), pumice (03-16-2016), Retro86 (08-24-2013), TRD_86 (08-24-2013), ZionsWrath (08-24-2013)
Old 08-24-2013, 04:21 PM   #78
ZionsWrath
Thanks
ZionsWrath's Avatar
Nice.
Coils won't rub hope someone with springs will post up
Old 08-24-2013, 04:26 PM   #79
BcRuZn
Drives: 2017 Brz Series Yellow
I would like to see 18x9.5 square. Have yet to see anyone try it with these wheels.
BcRuZn is offline   Reply With Quote
Old 08-24-2013, 04:59 PM   #80
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Even a 1.5" drop and meatier tires no rub? That's cool
Old 08-24-2013, 08:21 PM   #81
itdansharpe
itdansharpe's Avatar
Fit fine.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 08-25-2013, 02:16 PM   #82
mike the snake
I had to grind the little fender tabs on the rear but after that no rub.
Old 08-25-2013, 02:41 PM   #83
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Looks proper !!
GuerillaRacing is offline   Reply With Quote
Old 08-25-2013, 02:44 PM   #84
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
My next to-do list!
I hope they worth premium over xxr 530!
hanabie is offline   Reply With Quote
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 12:37 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 04:51 PM
Enkei Raijin Mesh Wheels - 18x8.5 / 18x9.5 in custom 5x100 FR-S / BRZ fitment GuerillaRacing Wheels and Tires 193 05-26-2015 06:55 PM
Enkei Raijin Wheels: IN STOCK - 18x8.5 & 18x9.5 Concave Touge Factory Wheels and Tires 27 04-03-2015 06:33 PM
enkei raijin 18x8 raven frs thebear21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-06-2012 04:03 PM
