Old 08-24-2013, 10:37 AM   #16941
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Hmm... Carbon fiber lip kit? Maybe... Carbon fiber trim/spoiler to go with? Or stay color-matched? *Thinkthinkthink*
Nevermore is offline
Old 08-24-2013, 11:04 AM   #16942
serialk11r
Drives: '06 AM V8V Coupe
I know they can do powder metallurgy with it (I've seen selective laser sintering with Ti, if they can do selective laser melting with it then they can probably powder forge it), so maybe. But I don't know how they deal with the gas absorbing problem. If there are fluxes and/or deoxidizers in the powder or if they need to do it in an inert chamber.
That would save a lot of the machining problems, but that doesn't mean the new process isn't still freaking expensive.
Selective Laser Melting (3d printing with metal) gives me a major tech boner.
Never heard of fluxes, I'm guessing they do it in a argon atmosphere?
I think the cost in Ti is the super high amount of energy required more than anything else, so 3d printing would probably not work so well.
serialk11r is offline
Old 08-24-2013, 11:46 AM   #16943
Dimman
Kuruma Otaku
Dimman's Avatar
They could do it in vacuum, too. Laser doesn't need an electrically conductive medium like arc welding.
The 3d printing of sintered Ti has been used for a while now to make medical and dental implants. The fact that sintering isn't 100% density is probably an advantage there so bone can grow into the parts or something.
With selective laser melting/fusing, they are fully melting the powder so the parts are 100% density, basically the same as cast. I've seen Inconel parts made this way.
I'm guessing that Ti could be SLM printed as well, which would be awesome. However part size and machine prices are not where I would like them to be. Heh...
Because titanium.
Dimman is offline
Old 08-24-2013, 01:33 PM   #16944
wrxgoose
WUB WUB
Drives: 2013 Firestorm
I'd think that needing to do it in a vacuum chamber, + all the support that means would make it expensive as hell, wouldn't it?
wrxgoose is offline
Old 08-24-2013, 01:40 PM   #16945
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Crowded traffic. So the state decides to build another bridge. Bigger, wider, more lanes. And the possibility (since it is 6ft away from the old bride) that each bridge will be for one way traffic...
Nope they tore down the other bridge and the only difference it they added a shoulder on the new one. Hooray for re-establishing the same traffic flow (or lack of.)
Kiske is offline
Old 08-24-2013, 02:55 PM   #16946
Dimman
Kuruma Otaku
Dimman's Avatar
I think a fully purged argon chamber would be cheaper because it doesn't need the better/stronger sealing that vacuum needs. But I think that aerospace does electron beam welding in vacuum because of higher quality, maybe? And the powder is probably fancy and expensive, too.
I still think that they can do it in normal atmosphere if they include fluxes and deoxidizers in the powder. The lasers can do fancy things really quickly with how they pulse. A flux just floats on top to provide a physical barrier from atmosphere when the metal melts, but leaves a slag on top when cool. Laser could be setup to fire different strength and duration. First pulse is set up to melt the metal and flux. It cools leaving metal under slag. Second pulse is set up to vaporize just the slag on top, leaving just the pure metal for the next powder layer to cover. Something like that.
Edit:
@serialk11r
Did I read above about you saying positive things about the 2GR? I thought I mentioned before that there is a member on here that has/had a 2GR-swapped Spyder and you were all 'meh'?
Was it @Rampage ?
Because titanium.
Dimman is offline
Old 08-24-2013, 04:54 PM   #16947
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Damn it! Song "Sail" stuck in my head...
ichitaka05 is offline
Old 08-24-2013, 06:59 PM   #16948
serialk11r
@serialk11r
Was it @Rampage ?
I think Rampage has the 2ZZ swapped Spyder, the person with the the 2GR is uspspro. I think?
I don't like the 2GR stock, that's for sure. In a Spyder, it's too much power for my taste. In a bigger car like the Evora, let that thing spin to 8000 and then we're talking.
Old 08-24-2013, 07:03 PM   #16949
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
That was me last week i swear
Kelbyat07 is offline
Old 08-24-2013, 07:25 PM   #16950
Dimman
Kuruma Otaku
Dimman's Avatar
I want a Spyder with a 2ZZ or 2GR now.
I'm pretty sick of my clutch in the Supra. It was selected for when the the car is tuned to take advantage of the turbo's 400whp capability. So now I have worse than normal lag, a heavy and grabby clutch, finicky idle and tip-in at low rpm and only about 300whp.
If I get the standalone and tune, I lose the idle and tip in issue, gain 100whp, but still have the unpleasant clutch and lag.
A 2GR Spyder with D4-S (not sure if that works with a transverse layout, though) ends up with only very slightly worse power-weight, better handling and fuel economy, stock engine/clutch drivability and no lag.
Woulda, shoulda, coulda...
Because titanium.
Dimman is offline
Old 08-24-2013, 07:46 PM   #16951
OrbitalEllipses
Drives: Attitude
Ssshhh child. We'll learn you yet.
OrbitalEllipses is offline
Old 08-24-2013, 08:20 PM   #16952
wrxgoose
WUB WUB
we can dance if we want to,
we can leave your friends behind.
because your friends don't dance and if they don't dance well
they're no friends of mine
wrxgoose is offline
Old 08-24-2013, 09:07 PM   #16953
serialk11r
Can't get the 2GR-FSE in transverse, can't get the 2GR-FSE in manual. But the 2GR-FE is not actually that much worse. The fuel economy is interesting, Toyota increased the low torque efficiency of the 2GR-FE so much that it is more efficient at the same loads than the older MZ/JZ engines I believe, while having more displacement.
A 2GR Spyder would have a 40-60ish weight distribution, it would hook up the rear tires pretty well. Lotus lets them rev up to 7200rpm with the sport button, meaning you could likely drop in some slightly bigger cams that make peak power at 6500 or so and get over 300hp (probably want a standalone to unlock more horses though as the stock ECU probably dumps way too much fuel down the exhaust at high rpm). Actually speaking of rich AFRs, I wonder if using E25-30 increases horsepower on a stock vehicle because I think ethanol is supposed to do better when running ultra rich than gasoline.
lol. I mainly say that because in 1st gear the clutch springs get loaded up just from letting off on the throttle a tiny bit, even with my shit Primewell rear tires. It's extremely uncomfortable. I think a 2ZZ would make me happy, though I would get the cams regrinded for less low rpm torque for the same reason. Not hard to hit 5000rpm and get the real power.
Old 08-24-2013, 10:53 PM   #16954
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Waldo is back! Oh how this forum has grown.
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
