#533 | |
Drives: '06 AM V8V Coupe
#534 |
Kuruma Otaku
Hmmm, I highly respect @ZDan 's and @arghx7 's technical opinions, plus @serialk11r is pretty damn smart himself. There are probably some operating conditions misunderstandings or assumptions here.
Because titanium. |
#535 | |
Drives: car
Funny how this forum has the little "mentions" thing which basically begs you to jump into some thread.
After the cat has warmed up, it will usually be hotter than the rest of the exhaust due to exothermic reactions (heat-producing reactions inside). So there are two main things you have to do to keep the cat from burning up: You limit the feed gas temperature. The way to limit this is to adjust your compression ratio, spark timing, and AFR. Higher compression ratio=more thermal efficiency, which lowers exhaust temperature. More compression ratio also increases knock tendency, meaning more retarded spark which raises exhaust temperature. Richer mixtures lower catalyst feedgas temperature. But here's where it gets tricky, where @ZDan has a good point. The exothermic reactions will heat up the cat. This happens when you load up the cat with LOTS of oxygen and CO. How does that happen? Two main ways. Deceleration fuel cut will fill up the catalyst with oxygen, and under certain conditions you can have reactions occur as a result of that loading. The cat has an oxygen storage capacity based on the amount of cesium inside. This is what's modeled when the ECU is trying to figure out whether to throw a P0420 (Catalyst Efficiency) code. Where it really gets confusing, and where I think @ZDan meant to go, is when you have high O2% and CO% (in terms of ppm concentration) in the feed gas under load. When does that occur? Scavenging operations. When you have a lot of overlap under the right conditions, intake pressure exceeds exhaust pressure. Unused air gets blown out the exhaust valve as you evacuate spent gases. What this does is raise your O2% in the exhaust. This might make you have an engine-out lean mixture, but the ECU can target a richer tailpipe mixture and "mask" the extra oxygen with more fuel. Rule of thumb is, when O2 concentration exceeds 1% you are going to have a lot of oxygen that can cause exothermic reactions. The final results is, the wideband misleads you. It says some AFR, but really the exhaust is loaded with oxygen (from the scavenging) and depending on the in-cylinder AFR, lots of CO. So you get reactions in the exhaust and exothermic reactions in the cat which degrades. The only way you'll ever really see this is in an engine dyno lab with thermocouples and pressure sensors, all through the exhaust, a $250k gas analyzer tapped into multiple points on the engine, and a wideband with backpressure compensation. TL;DR Rich can keep the engine-out exhaust temps down. If there is a lot of Oxygen in the exhaust (which can't always be detected by a wideband) you can get reactions inside the cat which degrade it. |
#536 | ||
Drives: '23 BRZ
The purpose for factory tunes being rich is all about saving the engine from detonation, accounting for possible fitment of lower-restriction intake/exhaust, while allowing as high a compression ratio as possible. It is NOT to preserve the cats. |
| The Following User Says Thank You to ZDan For This Useful Post: | LSxJunkie (08-23-2013) |
#537 |
Drives: FR-S 6MT
I owned 4 vettes in the last 14 years.. My last one was a 08 with Z51 and NPP option. Loved the car and hated it.. Loved the power.. Pulls like a freight train down low and keeps pulling at high rpms too.. Never stops pushing u back in the seat.. Comfortable and good looking.. Hated the run crap tires. I ditched them early on for some normal performance rubber.. The run flats got better with each vette I owned.. But I still prefer normal tires..
The vette is very rigid.. It gives you that one piece feel you need in a sports car.. But I always found the corners too heavy.. The damn wheels and tires are too big and heavy.. I always had road trammel going on.. And I never liked that in normal driving.. The damn thing is a target too.. Cops, Honda civics.. They all want to either give you a ticket or race you.. And parking it was always a hassle.. Not the best grocery getter... But it had lots of cargo space and one of the best hwy cruisers ever.. I found myself driving slower in the vette than in my beater car.. You can't play with it as much cause its too fast.. Put ur foot down for 2 seconds and your breaking speed limits and other laws.. I went with the FRS because it makes more sense on the street.. I can push it and have more fun with its low grip, low power all day long.. And I like the narrow tires MUCH better for everyday use.. While I miss the power of the LS3 and that V8 rumble.. I like driving the FRS more.. And being able to wind it out all the time.. It also feels more nimble than the vette.. Sometime less is more.. And driving a slow car fast is more fun than driving a fast car slow.. |
| The Following 2 Users Say Thank You to Mikem53 For This Useful Post: | bestwheelbase (08-22-2013), dem00n (08-23-2013) |
#538 |
Drives: car
There is a knock preservation aspect to having a richer in-cylinder mixture. However, engines do exist that run stoich almost all the time. The current Audi 1.8L, found only in Europe, is turbo with port + direct injection and basically runs 14.7:1 under WOT.
#539 |
Drives: 2013 Fr-S
i am liking it a lot
#540 | |
Drives: TBD
Needed to hear that, thanks - thoughts of dropping $60k on the C7 have been dancing through my brain lately.
#541 | |
Drives: FR-S 6MT
Seriously.. I enjoyed all my vettes... But I'm finding that you don't need all that to have an enjoyable driving experience.. I do miss my 0 to 60 blasts in the vette.. But the FRS has many virtues that can be enjoyed more often.. |
| The Following User Says Thank You to Mikem53 For This Useful Post: | bestwheelbase (08-22-2013) |
#542 |
BRZerhood Lurker #13
Drives: 15 DGM BRZ Premium
I've been reading and watching every review with awe. This car is amazing but I wish GM would come out with a mini Corvette. Something that's 3/4 the size, weight (2600lbs), power (345), and 2/3 to 3/4 the price (35-40k). It could be a Nissan Z, BRZ STi, future 16X RX-? competitor.
Yes I know the Camaro ocupies that price bracket but it's a heavy muscle car not a true sportscar. Two different demographics that occasionally overlap and cross shop but there's enough room in their line-up for both cars to co-exist.
Yesterday is history. Tomorrow is a mystery. Today is a gift and that's why it's called the present.
#543 |
Praise Helix!
Just remember this when you're telling your significant other that you would like to purchase a fun, economical car that you can also take to the track on weekends.
| The Following 2 Users Say Thank You to n2oinferno For This Useful Post: | bestwheelbase (08-22-2013), Dadhawk (08-22-2013) |
#544 | |
THE CORVETTE KING!
Drives: 2013 FR-S, and 2016 FR-S!
| The Following User Says Thank You to meadowz06 For This Useful Post: | LSxJunkie (08-23-2013) |
#545 | |
Apostle
Drives: JesusMobile
I believe they cut oil to the hydraulic lifters, an impressively simple way to do it as opposed to dual rocker arms / lost motion springs / extra cam lobes like VTEC. Different valvetrains, different techniques. I'm wondering if Corvette will ever get cam in cam technology like the Viper. I don't know if Chrysler has those patents locked down or if someone like Dephi owns that. |
#546 | |
| 2014 Chevrolet Camaro Z/28: The Trans-Am Racer Returns! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 53 | 02-24-2016 10:55 AM |
| OEM Chevrolet Corvette 17x9.5 +56 | BII302 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 06-07-2014 01:52 AM |
| Marc08EX Detailed: 2007 Chevrolet Corvette Z06 - Black | Marc08EX | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 07-11-2012 10:57 PM |
| 2011 Chevrolet Corvette Z06 Carbon slots in right below ZR1 | vh_supra26 | Other Vehicles & General Automotive Discussions | 2 | 03-14-2010 09:09 PM |
