Old 08-21-2013, 03:41 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Great Read Regarding Oil Choice!
Its long, save up some time and read this. Its internet gold.
http://www.bobistheoilguy.com/motor-oil-101/
Thanks to @ATL BRZ, @dsgerbc and @mav1178 for posting it. One of the most informative things I've read on the internet regarding oils.
I did a 24/25 on the test BTW
Edit: More great info on Bob is the Oil Guy forum regaring 0w-20 Oil, thanks to @bluesubie (who I consider Subject Matter Expert on Oils) and @dsgerbc)
Originally Posted by dsgerbc View Post
here, as posted here by @bluesubie
Pay more attention to posts by Shannow and Molakule.
More great info:
Originally Posted by bluesubie View Post
The white papers written by Molakule in the Technical and White Papers forum are worth a read as well. "Tom NJ" also has a great write up on synthetics in that forum.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=postlist&Board=53&page=1
Those guys are experts. I'm just an oil geek. Occasionally at bitog you will see replies to threads by Doug Hillary. He has worked in Oz for many of the oil majors (Castrol, Mobil, Shell, etc.).
-Dennis
Old 08-21-2013, 03:58 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
Thanks for that information, I will have to read through all of it at some point.
It seems like you struck internet gold! lol
Nick C.
John C.
Diode Dynamics
Old 08-21-2013, 04:00 PM   #3
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
@dsgerbc
Gotta give credit where it's due: http://www.ft86club.com/forums/showp...04&postcount=3
Old 08-21-2013, 04:14 PM   #4
dsgerbc
Drives: BRZ(sold), STI
The link in that thread to 0w-20 oil talk on BITOG is also very useful, with lots of further links. Not sure it's worth linking that, but I thought I'd mention.
Old 08-21-2013, 04:21 PM   #5
Sportsguy83
Drives: Limited BRZ
Share it, I'll add it to the OP. Thanks for the find.
Old 08-21-2013, 04:26 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showp...84&postcount=4
-alex
Old 08-21-2013, 04:27 PM   #7
dsgerbc
Old 08-21-2013, 04:52 PM   #8
bluesubie
Drives: 2004 Subaru Forester 2.5XT
-Dennis
bluesubie is offline   Reply With Quote
Old 08-23-2013, 02:21 AM   #9
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
So let me try to understand what bob is trying to say.
0w-20 Synthetic oil is the better oil because it does not do as much damage on cold start as much as the other higher weight oils? And it really doesn't matter once it heats up because they all have the same pressure at normal-high operating temperature?
hmm... thank you Subaru/Toyota for making this car 0w-20.
LeeMaster is offline   Reply With Quote
Old 08-23-2013, 04:02 AM   #10
504
504's Avatar
Drives: 2014 86 GTS
That article gets linked on almost every thread in the mechanical maintenance section and no one bothers to read it. Definitely changes the way you think about maintaining your engine
504 is offline   Reply With Quote
Old 08-23-2013, 09:37 AM   #11
bluesubie
For clarity, it wasn't written by "Bob" or anyone that works in the oil industry. It was written by Dr. Ali Haas, a plastic surgeon. He does know a lot about oil though and an oil was named after him. (Renewable Lubricants Inc. 0W-30 Dr. Haas version, or something like that).
What he's trying to say is that most oils are too thick at start-up, but a 0W oil is usually thinner than say a 5W so it will flow more quickly at start-up.
I say usually because there are always exceptions. If you're talking start-up at 0C/32F, then there are 0W-'s thicker than 5W-'s and even 10W's thinner than 5W's. The first number is a representation of the apparent viscosity based on the results of the cold cranking test at -35C for 0W oils. Unfortunately, it does not tell you the viscosity above those temps.
http://www.pqiamerica.com/coldcrank.htm
But no, oils will not have the same oil pressure between different grades. Even within the same grade, a 0W-20 can have varying oil pressure based on the actual kinematic visocisty at 100C and High Temp High Shear. The second number on the bottle represents a range of viscosities but does not mean a specific viscosity.
A 20 grade oil (or 20 weight which people love to call it) can have a viscosity of anywhere from 5.60 cSt's to 9.29 cSt's. It's not correct to say that 0W-20 or 5W-30, for example, has a specific viscosity or thickness.
http://www.bobistheoilguy.com/viscosity-charts/
You have to find out the specific viscosity of the oil you're using by looking at the product data sheet for that oil. You can also do a virgin oil analysis.
HTHS viscosity affects oil pressure as well. You usually find HTHS on an oil manufacturers product data sheet. Here's a good write up on HTHS:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1988816
Unfortunately, it's also written by an oil geek and not someone in the industry.
Oh wait, here's some HTHS info written by someone in the industry.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=530501&page=1
-Dennis
Old 08-23-2013, 08:38 PM   #12
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That was well worth the read
G_Ride is offline   Reply With Quote
Old 08-24-2013, 07:02 AM   #13
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Good read. I just follow the owner's manual recommendations for every car I've ever owned and I've never had a problem in 50+ years.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 08-24-2013, 10:21 AM   #14
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Me too, only 40 years. Many of my own oil changes also. I stopped when the environmental regulations added the need for a return trip to the hazmat depot. That added enough time and effort to the job I just take it to the shop now.
Driven many of these cars over 100,000 km and currently own two at well over 200,000 km with no oil related problems. No engine I have owned from new ever used significant amounts of oil, except the Alfa which is designed to use oil. Correct break in and correct oil changed at the specified intervals, not more or less frequently than specified, pretty much guarantees a trouble free engine for the life of the car nowadays.
Suberman is offline   Reply With Quote
Great Article from Speedhunters yuicebox Scion FR-S / Toyota 86 GT86 General Forum 2 08-06-2013 03:53 PM
Rim choice Karl07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-19-2013 07:31 PM
Great article... a "must read" PNW FRS Scion FR-S / Toyota 86 GT86 General Forum 12 02-04-2013 03:49 PM
Great Shark Fin pre painted factory color great price marinjim Cosmetic Modification (Interior/Exterior/Lighting) 42 12-03-2012 11:49 PM
