Old 08-22-2013, 08:37 PM   #29
Dephective
Drives: '13 Whiteout FRS
Originally Posted by jamesm View Post
My point remains though. A 2.5" overpipe isn't going to flow as much air as a 3" overpipe just because you bolt a 3" front pipe to it, and all of the exhaust still has to go through it, it's still the limiting factor so to speak.
Yes, 2.5" pipe will not hold as much gas as a 3" section at any given time. But, the amount of flow doesn't necessarily always favor the 3". The exhaust gas velocity is really what you should considered, as the gas has to move faster to make way for more gases to take its place since the amount it can hold in a given space is less than larger diameter piping, therefore more gases can move through the system at a given time. Diameter, and changes that occur throughout the piping (diameter, bends, obstructions, etc) all change the velocity of the gas, for better or worse. These things work together like a sliding scale.
I don't profess to be an expert, but generally how things work.
P.S. The faster the exhaust gases move, the more of a vacuum effect it has on MORE gases coming out of the engine. This allows for more air/fuel mixture to complete it's burn and move out if the system rather than some exhaust being left in the combustion chamber along with the mixture, giving a less efficient burn, and resulting most notably torque loss. It quite literally pulls more of the gases out.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
The Following User Says Thank You to Dephective For This Useful Post:
jamesm (08-23-2013)
Old 08-22-2013, 08:49 PM   #30
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Nice to see how far general knowledge of NA tuning has advanced on the internet...
How to maximize power on an NA engine: put a turbo on it
campy is offline   Reply With Quote
The Following 2 Users Say Thank You to campy For This Useful Post:
Dimman (08-22-2013), jamesm (08-23-2013)
Old 08-22-2013, 08:56 PM   #31
Dephective
Soon. I'm enjoying the lack of all the hassle of having FI for a while.
Previous:
'01 Accord-daily
Old 08-22-2013, 11:36 PM   #32
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by FR-S Matt View Post
That's technically not true.
that's not true.
Originally Posted by Dephective View Post
Incorrect.
False.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-22-2013, 11:44 PM   #33
Dephective
Originally Posted by Anthony View Post
False.
Certainly helpful...
Previous:
'01 Accord-daily
Anthony (08-22-2013)
Old 08-22-2013, 11:53 PM   #34
Anthony
Weight Nazi
Anthony's Avatar
I try.
The Following User Says Thank You to Anthony For This Useful Post:
FR-S Matt (08-23-2013)
Old 08-23-2013, 01:40 AM   #35
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So, from what I have read thus far from both pages of this thread is that everyone agrees that they disagree.
Turkish is offline   Reply With Quote
Old 08-23-2013, 03:18 AM   #36
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
To some point...
JimmyMac is offline   Reply With Quote
Old 08-23-2013, 06:20 AM   #37
FR-S Matt
There, end of discussion. Yes, that's a 3" flange going to the cat.
Old 08-23-2013, 08:56 AM   #38
jamesm
I think the difference here is I'm talking about an ideal fluid in a tube, you're talking about an exhaust with all of its extra considerations. You're presuming less than ideal flow, like in a real exhaust. I'm just saying that the absolute maximum amount of fluid a system of tubes can move, all else equal, is limited by the size of the smallest diameter tube.
Yes, in an exhaust header where 'tuned flow' not 'max flow' is the goal, stepping diameters can be helpful. If you wanted max flow, though, you'd run a header with an infinite primary diameter, or to say none at all.
A2.5" overpipe flows what a 2.5" overpipe flows at max, regardless of what it's bolted to, and if that's less than ideal (which on a turbo car it is) then that's still the overall limiting factor of how much exhaust can get out of that engine for a given pressure.
Old 08-23-2013, 12:54 PM   #39
Dephective
Who's 3" is that? And do you have any dyno info on that? I'd really like to accept that 3" is okay for n/a in our case, so I don't have to end up swapping out after I go FI.
Previous:
'01 Accord-daily
Old 08-23-2013, 01:05 PM   #40
FR-S Matt
Nameless. The only dyno info came from one of their prototype header tests with a full 3" exhaust.
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
FS: j2 quad tip exhaust 2.75" NEED THIS GONE "price updated" FRSex Engine, Exhaust, Bolt-Ons 23 07-28-2013 10:07 AM
My Wife Found a New "Cat Back" Exhaust Toyota86Fan Other Vehicles & General Automotive Discussions 6 10-15-2012 08:17 PM
Pacquiao vs Bradley fight outcome YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 06-16-2012 08:25 AM
