Old 08-21-2013, 03:08 PM   #3151
redsuns03
Originally Posted by bruizerrob View Post
Where did you get the frs plate?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
You can get a custom one from @yospeed
Sent from my SGH-T999 using Tapatalk 4
The Following User Says Thank You to redsuns03 For This Useful Post:
yospeed (08-21-2013)
Old 08-21-2013, 06:24 PM   #3152
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Originally Posted by lickitysplit View Post
Based on how this went on, how hard do you think it would be to take off if, say, I didn't like how it looked after I put it on? Thanks
I don't think it would be too hard. I changed out the 3M tape that came with the plate to regular double sided sticky tape. Using a thin piece of some rigid plastic (as to not scratch anything) I think prying the plate off would be easy.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 08-21-2013, 06:30 PM   #3153
DIM
Originally Posted by CamryDS View Post
Took some more pics of the car:
Looks good.
And is that Iishii's motor or Scion's fog light set?
DIM is offline   Reply With Quote
Old 08-21-2013, 06:47 PM   #3154
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Originally Posted by DIM View Post
Looks good.
ishii motor's version. Rather have the stalk than the "button"
CamryDS is offline   Reply With Quote
Old 08-21-2013, 09:10 PM   #3155
DIM
I wanna get their's too, but hesitating about the install since you need to remove the steering wheel. Was it hard to install?
Old 08-21-2013, 09:53 PM   #3156
CamryDS
It was not hard, I think I wrote a review in addition to the "remove your steering wheel" bit.
The only thing that you REALLY need to worry about is to make sure you don't turn the sensor while removing it -- otherwise it'll screw up your steering wheel alignment.
3 small holes that you can take a thin long flathead screw driver and pop the airbag off.
After you take off the airbag by unclipping the sensors you'll turn the steeringwheel to lock it
Then you will take a deep socket ratcheted wrench (17mm) and continue to loosen the nut, it'll take some strength to do.
that's basically it -- just make sure you unplug the battery "-" from the car before hand. Leave the "+" on, no need to take that off.
Old 08-21-2013, 10:25 PM   #3157
kALMIGHTY
Drives: TRD Ultramarine '13
Originally Posted by bear89103 View Post
That's awesome!!!
Haha thanks!
Originally Posted by Demandred7 View Post
Is that an overlay or stencil? Or something else?
It came in a sticker form, with the sticker backing on both sides. You take off the backing and put it on the mirror however you want to place it, then remove the other backing on the top. It just leaves the vinyl letters behind.
Originally Posted by suaveflooder View Post
LOL, funny and ironic on an FRS. This is a popular sticker on the cobra forums....then again, they are all pushing 500+ horse.
I'm kind of hoping to take a picture of a really fast car in that mirror. Hopefully I have a Lamborghini driving behind me sometime soon haha.
The Following User Says Thank You to kALMIGHTY For This Useful Post:
suaveflooder (08-21-2013)
Old 08-21-2013, 10:26 PM   #3158
torqdork
torqdork's Avatar
Drives: RV-7
Cleaned and lubed brakes, installed Carbotech XP10/XP8 Fr/Rr, rotated tires.
torqdork is offline   Reply With Quote
Old 08-21-2013, 10:34 PM   #3159
Originally Posted by torqdork View Post
Cleaned and lubed brakes, installed Carbotech XP10/XP8 Fr/Rr, rotated tires. ....
Good job!
What did you lube..?
Old 08-21-2013, 11:39 PM   #3160
torqdork
torqdork's Avatar
Drives: RV-7
Good job!
Thanks. All metal-to-metal contact points, piston faces, pad backing and caliper index grooves lubed with hi-temp (2,000°F) anti-seize copper formula per Mike Jr. @Carbotech recommendation.
The Following User Says Thank You to torqdork For This Useful Post:
humfrz (08-22-2013)
Old 08-22-2013, 12:32 AM   #3161
Amir Ghadiri
Amir Ghadiri's Avatar
Wheels today. Enkei RPF1 Tony Angelo edition, Falken FK453 265/35/18. Going to lower the car more and roll fenders on Saturday. Will also camber if needed, but I don't think it will be. I love it though, they look great in person and the car handles MUCH better
Amir Ghadiri is offline   Reply With Quote
The Following 3 Users Say Thank You to Amir Ghadiri For This Useful Post:
bear89103 (08-22-2013), HotLeopardMama (08-22-2013), jbravo373 (08-22-2013)
Old 08-22-2013, 12:42 AM   #3162
Nice ! ... looks ready to do business ....
Old 08-22-2013, 02:59 AM   #3163
hotpanda1
hotpanda1's Avatar
Drives: 2013 scion FRS
installed the ARK Grip exhaust and ARK test pipe, sounds so good!! and looks top notch.
hotpanda1 is offline   Reply With Quote
The Following 3 Users Say Thank You to hotpanda1 For This Useful Post:
Egyptn (09-21-2013), Nsot (08-22-2013), TRD-X (08-22-2013)
Old 08-22-2013, 09:35 AM   #3164
Diode Dynamics
Diode Dynamics's Avatar
^^^Nice!
I like the "titanium burned blue" tips
Any vids of the exhaust yet?
Nick C.
John C.
Diode Dynamics
