View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-20-2013, 07:16 PM   #2605
FRS1010
Drives: 2013 FRS
Yeah screw that I'm not going to take it back. Just rather deal with it and on special occasions buy some ethanol free gas or octane booster.
FRS1010 is offline   Reply With Quote
Old 08-20-2013, 07:21 PM   #2606
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
replacing the pump is not going to fix the issue
just saying. May get rid of it for awhile but overall...not effective.
Had mine after filling up with 93 with 10% because I had no choice. I usually do 91 0% and have no crickets. As soon as I got into town on that 93 10% tank I heard the crickets. Not saying it is entirely all gas, but it seems to be the issue with most people here. Filled up with 91 0% after I ran the tank close to E, no more crickets.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 08-20-2013, 09:01 PM   #2607
sierra
Drives: Skoda Yeti DSG diesel 4x4
It only happens in countries where ethanol is commonly available.
That is the cause.
sierra is offline   Reply With Quote
Old 08-20-2013, 09:04 PM   #2608
Khazzy
Khazzy's Avatar
That is the cause.
I am very sure it is the cause. People will continue to deny it though.
The Following User Says Thank You to Khazzy For This Useful Post:
sierra (08-20-2013)
Old 08-20-2013, 11:24 PM   #2609
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Just an update regarding the new pump I got installed.
After getting the High Pressure Fuel Pump replaced I had no problems. However, I have been using Lucas Oil mixed in with my gas. I might add that since the change I only used BP gas. I don't know why since I usually was a Mobile gas user with my 1998 Camaro Z28.
Anyway, a week ago I needed to get some gas and I filled up on Mobile gas. By the time I got home I had the beginnings of the dreaded cricket chirp coming back. Since I didn't have a bottle of Lucas oil with me when filling up I figured that's why the chirping had started. Though I never had a bottle with me at other times I was filling up. I put in 4 oz. The next day the engine was chirping as I arrived at work and later as I arrived at home. I was like, "WHAT THE F**K!!!" Well, once I got down to a 1/4 tank of gas I added another 3-4 oz. of Lucus oil and the chirping went away. The next day I fueled up at a BP and added another 3 oz. or so. Thus far, no chirping at all. After this tank I will go back to adding 4 oz. of Lucas Oil at every fuel filling at BP.
I believe that around the Chicago land area BP is the better gas for us over Mobile regarding this problem. I can't say about other gas stations, but I will be sticking to BP and Lucas Oil for the time being.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 08-21-2013, 12:58 AM   #2610
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
update
Bp isn't that great. I heard sone bad things. They turn your spark plugs orange, they add additives to the gas. Shell I heard has thr most consistent fuel you can purchase
Toyota/scion of naperville, IL informed me of a new revised pump. Blah blah blah.
Also replacing the pump does effect my drivability. I noticed thay my car starts up smoother Nd that with the chirps my idle will drop from 600 to 400 a lot at stop lights.
Kosmos is offline   Reply With Quote
Old 08-21-2013, 04:35 AM   #2611
sierra
That's interesting.
Maybe they could shut them up by turning the direct injection off from idle to 5,000rpm instead of just from 3,000rpm to 5,000rpm as it is now?
Port injection could easily cope with that.
Old 08-21-2013, 10:11 AM   #2612
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Man, it may help the crickets but adding oil to your gas seems sketchy to me. Doesn't oil lower the effective octane of the gas it is mixed with? I know when you suck oil into your intake you effectively lower the octane level of the intake charge.
DylanFRS is offline   Reply With Quote
Old 08-21-2013, 10:27 AM   #2613
HunterGreene
Hail Magnet
HunterGreene's Avatar
It would also produce more post-combustion soot and sludge that will eventually degrade the engine performance, if its not managed.
It has priests in it?
Old 08-21-2013, 10:39 AM   #2614
tinma
Drives: '13 BRZ
just started having the chirp recently...around 3000km into the car...i dont hear it inside the car but its pretty loud outside...pretty annoying
tinma is offline   Reply With Quote
Old 08-21-2013, 10:42 AM   #2615
sierra
2 stroke oil is designed to lubricate and then combust with zero ash in certain ratings. A 1:1000 mix has stopped the chirps in some cases and I would suspect any effect of that tiny amount on the octane rating would be of no consequence.
Old 08-21-2013, 11:17 AM   #2616
HunterGreene
Hail Magnet
Its also "designed" for use in 2-stroke (or 2-cycle) engines. I'm not saying you are entirely incorrect, but using something outside of what it was designed for (using 2 stroke oil in a 4 stroke engine) can get you different results than what you may expect.
To make an extreme example, an Airplane is designed with travel in mind, but specifically air travel. You could use it to travel on a freeway, but it wouldn't perform the same as in the air.
Old 08-21-2013, 12:02 PM   #2617
Lizai
Lizai's Avatar
I will try E free after I finish the half tank. The first time I got chirp was after I filled my car up with shell 93. After pump replaced is was good for a week. Then I went to another shell for 93. Noise came back. I will try Lucas ethanol solution with the current half tank and then E free after that
Lizai is offline   Reply With Quote
Old 08-21-2013, 12:16 PM   #2618
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It's also regularly used in rotary engines. When's the last time you used duct tape for a duct?
The thing that bugs me is that 2-stroke oil is designed to be combusted, not put through a high pressure fuel pump, I don't think I've even seen a fuel injected 2-stroke motor in person... But after quick googling they do exist.
ineedyourdiddly
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
