Old 06-13-2013, 01:43 PM   #99
Evan@D3PE
Evan@D3PE's Avatar
Drives: 1969 Opel GT
Originally Posted by sierra View Post
I was quoting from the article that you posted which says oil does come out of this catch can and that's why they vent it to the atmosphere, to stop that oil going back through the intake.
Here it is again.
That oil is vented to the road[atmosphere]
Also even with a can to catch the oil, the air going into the intake stream will still have oil in it, this will coat the inside of your IC pipes or intake on a na application. We vent ours to the atmosphere, leaving your engine sucking nothing but fresh air.
http://www.d3peparts.com/ProductDeta...e=D3PE-FRS-CC2
The pressure is vented to the atmosphere which can contain oil particles which is why the can is baffled and filtered before the atmosphere unlike closed loop systems
I looked up your Provent 200. It has a removable filter element inside the can and is only setup for a single in and a single out so in reality you will need two of them. The D3PE filters it before it vents to atmosphere and the Provent can either do that or filter it before it goes back into the engine. A catch can isn't rocket science, so buy the one you want.
Thank you! lol :happy0180:
Evan@D3PE is offline   Reply With Quote
The Following User Says Thank You to Evan@D3PE For This Useful Post:
charged86 (06-13-2013)
Old 07-31-2013, 12:46 PM   #100
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I put the filter back in its original place.
Old 07-31-2013, 03:34 PM   #101
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Ditched the extend pipe ?
Old 07-31-2013, 03:36 PM   #102
Sportsguy83
Drives: Limited BRZ
Yes, got rid of the horse's dong
Old 07-31-2013, 06:44 PM   #103
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What made you decide to do that? I wish I got to see yours like that while I was down there to see how much comes out at idle compared to mine.
Old 07-31-2013, 09:27 PM   #104
SmsAlSuwaidi
Boosted
Why ?
Old 07-31-2013, 11:05 PM   #105
Sportsguy83
Drives: Limited BRZ
After looking at my filter after Dyno day, I can say at high PSI I am most probably also seeing a good amount of blow by.
Why ?
Was looking at the car while on a lift, saw the filter stained with oil and the way the filter seated, if the car ever for any unexpected reason wanted to throw a lot of oil at the catch can, it was going directly towards the tires, so basically a safety concern. Maybe overkill, or overthinking it, but just thought better smell some fumes than loose control of the car at 100 mph.
Old 08-01-2013, 12:15 AM   #106
SmsAlSuwaidi
Boosted
Better safe than sorry , a bit of fumes .... because race car i guess
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (08-01-2013)
Old 08-21-2013, 10:39 AM   #107
BolognaWalrus
Drives: too soon junior
Originally Posted by JoeBoxer View Post
We are getting taxed for sure on certain items, this car is under $30k and some parts are priced like they are for a GTR. I'm not rich by any means but i want quality parts, there are a few companies out there looking out for us middle class folks.
Gotta pay to play bro. $300 isn't bad, you should be glad companies are making quality parts for these cars. Now stop whining.
BolognaWalrus is offline   Reply With Quote
Old 08-21-2013, 10:53 AM   #108
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So did I, and I cleaned it and oiled it like a K&N so it is full of purple goodness now.
Old 08-21-2013, 10:56 AM   #109
Sportsguy83
Drives: Limited BRZ
Always 1 upping me Tut... The oil is a good idea!
BTW, post here http://www.ft86club.com/forums/showthread.php?t=44832
Old 08-21-2013, 11:01 AM   #110
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No menton in the second post. I am disappoint.
Old 08-21-2013, 11:04 AM   #111
Sportsguy83
Drives: Limited BRZ
No menton in the second post. I am dissapoint.
Thread was initially called South FL registry so I tagged all from last South FL meet. It was later changed to ALL FL but didn't go back to tag. I'll tag yo to the thread which is more unversal and important than an earthly post tag
Old 08-21-2013, 11:23 AM   #112
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You might have more posts, thanks, thanked, and mentions, but I gots you in Taggeds.
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
~D3PE FRS/BRZ Catch Can System~ Evan@D3PE Engine, Exhaust, Bolt-Ons 26 06-12-2013 03:39 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
For those who were compensated, what's the catch? TurnOne Issues | Warranty | Recalls / TSB 27 02-08-2013 01:20 PM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
