Old 08-21-2013, 11:38 AM   #169
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
I have a different electronic controller, the Subaru OEM sensor (plug and play with the car, connects to the EVAP connector, your tuner will set boost control with the map) but some people don't like the fact the boost is set in the tune, can't be controlled by hand. The GFB G Force II can be found on Rallysport Direct.
The 3 BAR map sensor was included with the AVO kit, but you can snag one on Ebay for around $90-$120. Look for 3 BAR OMNI MAP sensor for 06+ S2000.
The 4bar map sensor i saw was about $117 before shipping. Worth buying?
JackSmiley is offline   Reply With Quote
Old 08-21-2013, 11:44 AM   #170
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Quick ebay search:
4 BAR OMNI
2.5 BAR OMNI
Old 08-21-2013, 11:49 AM   #171
JackSmiley
JackSmiley's Avatar
Quick ebay search:
4 BAR OMNI
2.5 BAR OMNI
[ame="http://www.amazon.com/gp/product/B006ID4TAU/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A2PHW9L9E GK1GF"]http://www.amazon.com/gp/product/B006ID4TAU/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A2PHW9L9E GK1GF[/ame] same thing?
Old 08-21-2013, 11:50 AM   #172
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Any of you guys running a EBC/MBC or a boost solenoid? What would you guys recommend? Also is a 4bar map sensor overkill? Im gathering up what i'd need when i get the turbo kit.
This one has been discussed before. You will get verying opinions on the three options. Some people swear by each solution. I am running the GFB G-Force II EBC and a 3 bar Omni Power MAP sensor. I don't see myself ever running over 29 psi, so the 3 bar is fine.
JackSmiley (08-21-2013)
Old 08-21-2013, 11:51 AM   #173
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That should work. Just remember your ROM needs to be setup for that MAP sensor, so make sure you have one from your tuner before you install it.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
JackSmiley (08-21-2013), Sportsguy83 (08-21-2013)
Old 08-21-2013, 11:54 AM   #174
JackSmiley
JackSmiley's Avatar
Does the stage 1 base kit come with an upgraded map sensor or no? So before putting a 3bar map sensor, i'd have to contact LJ and ask for a ROM for this map sensor?
can you save maps in the GFB EBC for a specific boost level? lets say in the morning i wanna run 9psi and then in the afternoon i wanna run 14psi.
Old 08-21-2013, 11:55 AM   #175
Sportsguy83
Drives: Limited BRZ
Yes
Base kit AFAIK, does not upgrade MAP sensor. Yes, you'd contact LJ and he send you the map with that MAP sensor calibrated.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 08-21-2013, 11:57 AM   #176
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As far as I am aware none of the Full Blown kits have come with upgraded MAP sensors. This is one of the critisisms of his kit by some fired up tuners. I am pretty sure @FullBlown can get you a basemap for a 3 bar MAP sensor though.
Old 08-21-2013, 11:59 AM   #177
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yes. That is one of the main advantages of a simple EBC. The G-Force II has 6 presets that can each have different duty cycle, gain, and sensativity settings. You can swap through them with a single press of a button on the controller.
Old 08-21-2013, 12:01 PM   #178
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes we can supply the map for a 3 bar. We use other methods to set a boost cut without a map sensor.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Old 08-21-2013, 12:01 PM   #179
JackSmiley
JackSmiley's Avatar
Wew! The things that i learn everyday. Thanks @Sportsguy83 and @King Tut
The Following User Says Thank You to JackSmiley For This Useful Post:
Old 08-21-2013, 12:18 PM   #180
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
BTW IM THE NOOB LOL
Sent while popping Mollys
Old 08-21-2013, 12:40 PM   #181
Dipstik-sportech
Dipstik-sportech's Avatar
Full Blown Turbo Kit Owners Topic
So is the main reason for a 3 bar or anything over stock just for boost cut protection? Like would it make tuning it easier or more accurate?
I've got a Full Blown MBC on my car it's nice cause its black and hides well in the bay.
Old 08-21-2013, 01:34 PM   #182
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It doesn't really make tuning any easier. The car does use the MAP sensor for some correctons, but really it is so the tuner/user can datalog and know what boost level was being run at the time.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
